Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > LG > LG Android based phones
LG Android based phones General LG Android phones discussion, firmwares, solution, root, help
Old 06-23-2013, 02:59   #1 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
[Guide] All LG Mobile phones Hard Reset Procedures
Lg Optimus G Eclipse E970 Hard Reset
if you perform a hard reset,all user applications and user data will be deleted
please remember to back up any important data before performing a hard reset
1.turn the phone off
2.press and hold volume down + power + lock key at the same time
3.release the keys when the factory hard reset screen appears
4.read the warning and press the power/lock key to confirm.press any other to cancel
5.press the power/lock key to confirm once more or press any other to cancel
6.your device will perform a hard reset
The Following 4 Users Say Thank You to Braycel For This Useful Post:
Old 06-23-2013, 03:03   #2 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
Factory Reset the LG Optimus S
The factory reset clears all user data and 3rd party applications, restoring the device to it's original factory settings. It's often recommended following a software update to help resolve or clear compatibility issues Prior to performing the reset, it is recommended to backup your personal data (see below) and then remove the SD card.
Note: This will not remove Operating System software from your device (Froyo, Gingerbread, etc.)
Factory reset steps:
1. From the main home screen, select Menu
2. Select Settings, then select Privacy
3. Select Factory Data Reset
4. Select Reset phone
5. Enter the password if prompted, and select Erase Everything
If the device is frozen, follow these steps:
1. Remove and reinsert the battery
2. The device will power on
3. Hold Volume down, Home, and Power buttons until the reset screen appears
4. Select wipe data/factory reset (using volume down) and press Menu
5. Select Yes and press Menu
The Following 3 Users Say Thank You to Braycel For This Useful Post:
Old 06-23-2013, 03:06   #3 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
Hard Reset LG Optimus L7 P700 to Restore Factory Settings
You can hard reset your LG Optimus L7 P700 to restore the factory default settings. Caution: If you perform a hard reset, all user applications and user data will be deleted. This cannot be reversed. Remember to back up any important data before performing a hard reset.
Switched off your phone then press and hold the Volume down key + Power key with your left hand.
When the LED on the bottom of the phone lights up, touch and hold the Menu key with your right hand. You need to do this immediately, before the screen displays the LG logo. Make sure your left hand is still holding the Volume down and Power keys. Then release the power key at vibration time.
When the LG logo is displayed on the screen, continue to hold the keys for
around 2 seconds, and then release all them at the same time, before the LG
logo disappears. Leave your phone for at least a minute while the hard reset is carried out. You will then be able to switch your phone back on.
Old 06-23-2013, 14:35   #4 (permalink)
Super Moderator
Member: 813309
Thanks Meter: 1,912
Hard Reset LG P705
1 - Open the version of Vygis LGI_1_9XSD
2 - Mark model KP100
3 - Connects only in ports & settings
4 - Click on reset phone with him and connected with the cable GS102
The Following 2 Users Say Thank You to Braycel For This Useful Post:
Old 06-29-2013, 10:56   #5 (permalink)
shuric's Avatar
Member: 444532
Sonork: 100.1576960
Thanks Meter: 214
How to hard reset Korean LG-F120L ? Help me, guys
The Following 2 Users Say Thank You to shuric For This Useful Post:
Old 07-25-2013, 16:11   #6 (permalink)
Member: 1986154
Sonork: Liltio
Smile
Hallow dont you have lg c105 hard reset code?
Old 08-22-2013, 10:06   #7 (permalink)
Member: 1994810
i want to know how i can hard reset my lg BL-44jn Cell phone
plzz help me
Old 08-30-2013, 16:34   #8 (permalink)
Member: 1268335
Thanks Meter: 36
Post lg p 970 hard reset solution urgent
Old 09-09-2013, 10:41   #9 (permalink)
zeeshan tayyab's Avatar
Member: 828294
Sonork: 100.1615866
Thanks Meter: 124
how to hard reset lg optimus ntt docomo l-05d?
Old 10-12-2013, 16:07   #10 (permalink)
Member: 1140831
Sonork: no
Thanks Meter: 232
this is e400 hard reset
LG L3 Optimus E400 hard reset - YouTube
The Following 3 Users Say Thank You to parmodparmod For This Useful Post:
Old 10-13-2013, 08:16   #11 (permalink)
Member: 2045288
Is hard reset the same as unlocking phone?
I need to unlock my Lg Optimus 5 E 610!
I need that code, so, if anyone can help me!
Thank you!
The Following User Says Thank You to Dragoinis For This Useful Post:
Old 10-13-2013, 08:30   #12 (permalink)
Member: 689050
Thanks Meter: 4
Arrow lg f320 s
how to hard reset lg f320 s.the fone is locked with pettren lock
Old 10-21-2013, 12:44   #13 (permalink)
Member: 2023257
Sonork: 100.1645975
how to hard reset Lg f120l plzzzzzzzzzzzzz
Old 10-26-2013, 09:50   #14 (permalink)
Member: 2053477
Lg gw300
I have tried all ways of hard reseting this ph and still no joy please help !!
and the ph is locked in Enter Security code stage .
Old 10-28-2013, 09:59   #15 (permalink)
Member: 2053477
or help me flash it as ive tried these methods and they dont work ?
The Following User Says Thank You to johnn28 For This Useful Post:
Page generated in 0.22760 seconds with 10 queries
