Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > LG > LG Android based phones
LG Android based phones General LG Android phones discussion, firmwares, solution, root, help
Old 07-11-2014, 11:02   #1 (permalink)
Akhtar Ali Jatt's Avatar
Member: 953334
Sonork: 100.1614005
Thanks Meter: 15,424
Smile How to Flash LG KDZ file Greater Then 1GB Offline 100 % Tested 2014 Solution ;)
[B]How to Flash LG KDZ file Greater Then 1GB Offline 100 % Tested 2014 Solution
Method :
  1. Download the appropriate firmware file (link above) depending on the model number of your LG G2 and extract the ZIP (if applicable).
  2. Download and install LG USB Drivers on your computer: Download
  3. Make sure you phone has at least 70% battery juice.
  4. Enable USB Debugging on your device from Settings> Developers options. See detailed guide here.
  5. Download LG R&D Flash Tool and other files: LG_KDZ_FW-Update_OfflineFix.zip (Mirror Link)
  6. Extract the ZIP file and open the unzipped folder. It contains all necessary tools and files.
  7. Also download this ZIP and extract it: LGMOBILEAX.zip (Mirror Link)
  8. Now open LGMOBILEAX folder and copy its contents in C:\ProgramData\ LGMOBILEAX on your computer. The path should be as shown in the picture below. If you get “Update R&D Tool” error later, delete the contents of C:\ProgramData\ LGMOBILEAX folderand copy the new files to this folder from LGMOBILEAX you downloaded at Step 7.
  9. Go to C:\Windows/System32/drivers/etc folder.
  10. Now right click the hosts file and open it with WordPad or NotePad++ (I used the latter).
  11. Now add the following line at the end of the document: 127.0.0.1 csmg.lgmobile.com
  12. Save the changes and close the hosts file. If you are unable to edit the hosts file, do this: go to Notepad or Notepad++ program and open it as administrator on your computer, navigate to the hosts file, add 127.0.0.1 csmg.lgmobile.com at the end and save the changes.
  13. Open LG_KDZ_FW-Update_OfflineFix folder and install the msxml.exe file.
  14. Then open shttps folder and run http.
  15. Now start Windows Enabler and turn it on (system tray).
  16. Then launch UpTestEX_mod2_marwin.
  17. Now boot your LG G2 into Download Mode. To do this, turn off the phone, press and hold the Volume Up key and then plug the USB cable.
  18. As soon as your device get connected successfully LG R&D Test Tool will launch.
  19. Now click the folder icon at Select kdz file option and add the downloaded stock firmware with .KDZ extension.
  20. Then click the Normal web upgrade test button.
  21. You’ll see a new Read Phone Information popup window.
  22. Now click the Start Upgrade button.
  23. Just wait for a few seconds till you see another popup asking you to Select Country & Language.
  24. Finally, click OK to proceed with firmware installation.
  25. When the firmware flashing is done and your G2 boots up, do not forget to perform a factory reset. To do it, press and hold the Volume Down+Power buttons until you see the phone’s screen.
The Following 22 Users Say Thank You to Akhtar Ali Jatt For This Useful Post:
Old 09-04-2014, 06:24   #2 (permalink)
MUTUAL's Avatar
Member: 160928
Thanks Meter: 338
How to Flash LG KDZ file Greater Then 1GB Offline 100 % Tested 2014 Solutio...
hi i get this error what to do? every time when i try to flash i show me this?
Always saying disconnected
But phone is connected
Old 09-04-2014, 08:02   #3 (permalink)
Registered User
Member: 767472
Sonork: 100.1609877
Thanks Meter: 599
use another pc ........
Old 10-01-2014, 15:21   #4 (permalink)
NOKIA EXPERT's Avatar
Member: 2227489
Thanks Meter: 190
Old 10-08-2014, 14:55   #5 (permalink)
javaflasher's Avatar
Member: 1892139
Thanks Meter: 56
please help with this error.. many times, many try always got this error..I follow exactly this step by step but no luck..please guide me to any one who has successully update/downgrade with offline..thanx in advance
The Following 3 Users Say Thank You to javaflasher For This Useful Post:
Old 10-21-2014, 07:32   #6 (permalink)
Member: 953334
Sonork: 100.1614005
Use win7 .
The Following 2 Users Say Thank You to Akhtar Ali Jatt For This Useful Post:
Old 11-04-2014, 03:59   #7 (permalink)
Member: 1107593
Thanks Meter: 11
I'm starting to update my phone but always goes from 20 to 30%, I could help in some way
Old 11-04-2014, 11:59   #8 (permalink)
Member: 2286481
Thanks Meter: 3
Sometimes, the reason is your PC installed many phones' driver. Try to uninstall some of them that no need at the moment, then restart your computer and try again !
The Following User Says Thank You to tphat For This Useful Post:
Old 11-10-2014, 19:56   #9 (permalink)
Member: 2284524
Hi, I got to step 20 and when I clicked on
"Upgrade Start", I got a message saying:
"Please install csmg b2c Client TOOL
Select Tool -> B2C Client Setup menu"
Any idea what it could be?
The Following User Says Thank You to shawnpp For This Useful Post:
Old 11-20-2014, 07:24   #10 (permalink)
ZIYAAD STRYKER's Avatar
Member: 175945
Sonork: ziiyyaad
Thanks Meter: 704
same here any help plz? please install csmg b2c client tool!!!
Old 12-31-2014, 23:28   #11 (permalink)
Member: 177381
Sonork: 100.162218
Thanks Meter: 16
i was also facing same problem i used another pc with win7 installed and phone flashed fine
The Following User Says Thank You to nabeel_7152077 For This Useful Post:
Old 01-07-2015, 08:56   #12 (permalink)
ahmertelecom's Avatar
Member: 210880
Sonork: 100.1577765
Thanks Meter: 151
comport number to high plz selct comport under 20
Old 02-06-2015, 14:24   #13 (permalink)
Member: 1885839
Sonork: 100.1596918
Thanks Meter: 19
i've tried this solution on my LG L3, but it is always show error. i also tried it on other PC but i'ts still error.
Old 02-18-2015, 06:59   #14 (permalink)
saifjaan009's Avatar
Member: 2340225
Sonork: 100.1662389
Thanks Meter: 367
same hare bro no working i am also trying >>>>
Old 02-19-2015, 09:06   #15 (permalink)
Member: 2344389
plz tell me a best website of l.g stockroms
Page generated in 0.23046 seconds with 9 queries
