LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
03-14-2016, 14:31 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | LG Leon H345 & MS345 Network Searching problem after Reset Mobile from Settings. 01. These Mobile was Locked By Operator. 02. Then Use Device Unlock App from Mobile to "Permanent Unlock" for Unlock it. 03. It Showed "Unlock Approved : Mobile device is permanent unlocked" Restart Now. 04. then after 2-3 days using sim, it was work fine. but when it reset from setting. now show "Searching" only. ( I have Three Mobile like this, 2 pcs is H345 ( T-Mobile ) 1 pcs is MS345 ( Metro PCs ). 05. I was Flashed mobile with same version firmware, and try to Unlock again via "Device app Unlock" but not solved. 06. Need Solution for this Problem. |
The Following User Says Thank You to razib143 For This Useful Post: |
03-27-2016, 04:08 | #10 (permalink) |
Junior Member Join Date: Mar 2016
Member: 2550682 Status: Offline Thanks Meter: 2 | LG Leon H345 & MS345 Network Fail As I have understood this is the best forum phones in the world. I will bring my experience with this model. First of all I want to note that this model has an engineer menu from which you can observe several operating parameters. The access code is 277634 engineer menu # * # there you can see the ID of the cell, and the status of all parameters of the GSM modem. What I have observed in models that fail to connect is that they are not able to correctly identify the ARM canal, nor are capable of indicating the level of GSM signal reception and not perform network registration. All these failures occur a few days after the phone is unlocked. I've tried flashing, write QCN, hard reset, put another SIM. It was not possible to repair the connection. Unfortunately I did not keep the log radius of this phone but would be a helpful tool that GSM specialist analyze the log that creates this phone about the operation of radio. Maybe someone in the forum could provide a log. |
05-10-2016, 07:58 | #15 (permalink) |
Junior Member Join Date: May 2016
Member: 2570898 Status: Offline Thanks Meter: 2 | I have bought online H345 t-mobile usa phone. Since I live in Serbia - Europe, I have done unlocking via device unlock app. Phone was working normaly 2-3 days, than it restarted by itself and got stuck on network search. Than I noticed in some parts of town it can register to a network and works normaly, and than, when I move away from that area it lose network again. Please help... |
The Following 2 Users Say Thank You to atahuallpa For This Useful Post: |
