How to Root LG Optimus Slider – Tutorial LG Optimus Slider from the house of LG Electronics and Virgin Mobile can now be rooted so that one can make the most out of it by installing the custom ROM firmwares which we will be coming up with the same very soon on Android Advices. Please note that you need to ensure that once you root the device, the warranty will get void. The only way with which the warranty can be reclaimed is by re applying the device with the official firmware update. Disclaimer: We should not be held liable for any damage caused in the process of applying this rooting process in your device. It is very unlikely that your device will be damaged if you follow all the instructions to the point which are mentioned in procedure.Though it’s not compulsory but it’s highly recommended that you back up all the data present in your device with the help of manual steps mentioned below. Don’t backup the data with the help of PC Suites as it may not be able to detect after installing the custom ROM firmwares which we will be coming up in few days. SMS – Use “SMS Backup & Restore app”,http://cdn.androidadvices.com/wp-con...der-Banner.png Download & Install all the drivers for your LG Optimus Slider as it’s a must before you could proceed to the detailed guide. Enable USB Debugging in your LG Optimus Slider from the path “Settings > Applications > Development > USB debugging”. The USB Debugging option should be ticked. So assuming that you have followed all the above mentioned instructions, you can now proceed to the next section below where we have summed up procedure to Root LG Optimus Slider. Procedure to Root Virgin Mobile – LG Optimus Slider Android Phone:
How to Root LG Optimus LTE LU 6200 Android Phone – Tutorial Happy news for all the users of LG Optimus LTE LU6200 as you can now root easily with the help of below instructions which we will be checking out. Just in case if you didn’t knew then once the device is rooted, you can then easily install the custom ROM firmwares as well as the other apps which need the root access. Very soon we will be coming out with different custom ROM firmwares which will completely redefine your mobile experience. Disclaimer: We should not be held liable for any damage caused in the process of applying this rooting process in your device. It is very unlikely that your device will be damaged if you follow all the instructions to the point which are mentioned in procedure.Rooting Information: Please be informed that once the device is rooted, the warranty will get lost and the only way with which you can reclaim the lost warranty is by re applying the firmware update of ICS 4.0.4 which is an official release.
Procedure to Update LG Optimus LTE LU6200 Android Smartphone:
Note: Just in case if the device booted up or gets into the boot loop mode then you need to re follow the above mentioned steps with the help of above mentioned instructions.Do let us know in the comments section just in case if there are any issues faced in the process of rooting your LG Optimus LTE LU6200. Congrats you have rooted your LG Optimus LTE LU6200 with the help of simple steps. |
