LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
09-22-2014, 16:22 | #1 (permalink) |
Junior Member Join Date: Jan 2014
Member: 2114221 Status: Offline Thanks Meter: 1 | LG P880 IMEI fix I have an LG P880 phone and when I check the IMEI inside it says "wait for a while ! " and it does not give the correct imei inside anytime at all. When I connect it to Octopus Box and try to fix IMEI it says; Selected model: P880 Opening "LGP880AT-00-V20c-AME-APR-18-2013+0.oct"... Please, connect powered OFF phone with P999 (with 910k resistor) cable and press power button...OK Initializing device...OK Reading info... Model ID: BS/P880/1 IMEI: 352967-05-658599-9 SW Version: LGP880AT-00-V10e-AME-XXX-OCT-16-2012+0 Sending preloader...OK Sending loader...OK Writing Firmware... Setting options...OK Sending hardware info...OK Sending psi.fls...Failed! Disconnected. How can I solve it pls ? Thank you very much in advance for your replies. |
