LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
05-27-2021, 12:30 | #1 (permalink) |
Freak Poster Join Date: Oct 2003 Location: Oslo Age: 41
Member: 41299 Status: Offline Thanks Meter: 16 | LG K20 LM-X120EMW problem entering the NCK code LG K20 LM-X120EMW unlock problem. I have the NCK unlock code. I put a non accepted SIM card, but the phone is not asking for unlock code. Second option (device doesn't ask for an unlock code with an unaccepted SIM) 1. Start the device with an accepted simcard (example LG K20 plus was bought in Orange you need to insert an Orange card) 2. Go to the dial screen and press “2945#*model number#” (the same way you enter a phone number) Example: the device is a P999 you need to enter “2945#*999#” or for KU990 you need to enter “2945#*990#” etc… THIS ALSO NOT WORKING. Third option (accepted simcard) 1. Go to dial screen and press 2945#*71001# or 2945#*20001# as if making a call 2. when a hidden window appears enter the unlock code THIS ALSO NOT WORKING. Phone is brand new. |
05-28-2021, 13:28 | #2 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | only direct unlock will work for this models..many box support it like octoplus..why did you bought nck when its not asking |
05-31-2021, 07:25 | #3 (permalink) |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | This model default counter is closed , no way to unlock via code at this moment Only direct unlock supported , furious gold box cheaper then octopus box |
05-31-2021, 07:58 | #4 (permalink) |
Member: 41299 Status: Offline Thanks Meter: 16 | a I've got the unlock codes for free from the carrier. Finally i foud a code what i had to type in: *#*#7465625#*#* than i was able to enter the NCK unlock code. |
The Following 2 Users Say Thank You to Greenhorn For This Useful Post: |
05-31-2021, 16:22 | #5 (permalink) |
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | its good to know it works finally they gave you the code but not the instructions to put it..i thought you bought the code..anyways congrats |
