LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
04-12-2013, 20:00 | #4 (permalink) |
Junior Member Join Date: Feb 2012
Member: 1720836 Status: Offline Thanks Meter: 3 | hi to all,, connect phone to lgtool select model, put usb cable and press connect in phone dial 3845#*920# select port setting and select third option when phone connected ok, press repair imei and after imei repaired press bluetooth repair and after completion these two steps press unlock when phone is unlocked, press disconnect and restart your phone hope u will have imei and network back 100% tested Last edited by ..::Nokian CareŪ::..; 08-27-2013 at 17:17. Reason: removed email id |
04-15-2013, 13:44 | #5 (permalink) | |
Freak Poster Join Date: Dec 2007
Member: 657233 Status: Offline Thanks Meter: 8 | Quote:
08-26-2013, 10:55 | #13 (permalink) |
Freak Poster Join Date: Mar 2008 Location: Poland - Jarosław Age: 37
Member: 735126 Status: Offline Thanks Meter: 11 | "Load the phone into normal mode(Android), type 3845#*920#, enter <Port Setting>, select <CP Image Download> and press Ok Device found Sending preloader Sending loader Setting up configuration Looking for GPT Connected Receiving phone info Dumping security area File: Invalid partition" flashed ap without any problem but every version when tried to connect ap no way to do that... anyone know where is problem? how to solve? |
09-03-2013, 21:27 | #15 (permalink) | |
Junior Member Join Date: Aug 2013
Member: 2009155 Status: Offline Thanks Meter: 0 | Quote:
Together with LG Tool, just try it! | |
6150 Network problem, please HELP! | ZF | Nokia Hardware & Hardware Repair | 4 | 07-06-2004 18:07 |
5110/6110 after unlocking see only network to which it was locked and ... | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 07-25-2000 00:51 |
6150 no outgoing calls | edis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-20-2000 20:19 |
How do I remove a network provider lock? | james.bond007 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-02-2000 22:59 |
no one can unlock 6110 05.40 25-5-99 | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 09-22-1999 08:03 |
