LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
11-05-2017, 09:00 | #1 (permalink) |
Crazy Poster Join Date: Sep 2016 Location: Swat, Pakistan
Member: 2619617 Status: Offline Thanks Meter: 9 | Lg h810 g4 frp bypass So here we go; When you stuck on configuring your phone. Simultaneously for 10+ seconds until it powers off. Restart phone. (Whenever the screen comes up that asks if you want WiFi on, turn it on. I'm not sure if that came before or after this next step). Press Accessibility Settings, then go to Switch Access. Make sure Switch Access is turned off. Now keep pressing Next until you're back to the Configuring your Phone screen.Then press and hold the Power, Volume Up and Volume Down keys. The option to skip should pop up. If it doesn't, press and hold just the Volume Up and Volume Down. When the Skip option appears, press Skip. Now you are able to set up the phone manually. I had all but given up, so I was shocked and thrilled when this worked. I hope it works for you, too. I'm going to every forum and site I came across someone else with this problem, when my phone was stuck on the Configuring Phone , and posting these instructions. Last edited by ilyaseen; 11-05-2017 at 09:05. |
