LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
02-03-2019, 16:28 | #1 (permalink) |
Freak Poster Join Date: Apr 2014
Member: 2177146 Status: Offline Thanks Meter: 20 | problem with flash lg k series -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM37 Selected baudrate: 921600 Selected model: K350Z Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM212 Mode: Emergency Initializing flash...OK Model ID: LG-K350Z SW version: LGK350ZAT-00-V13v-GLOBAL-COM-JAN-24-2018+0 LAF Version: 1.1 Product ID: 0000000 IMEI: 00000 Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "K350Z10h_00_0124.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing preloader...Failed! Performed by 2.8.5 Software version. -------------------------------------------------------------------------------- Checking data...OK Platform: LG MTK Selected port: COM37 Selected baudrate: 921600 Selected model: K350Z Selected USB connection type Please, disconnect cable, reconnect battery, connect P999 cable (with 910k resistor) or Reconnect battery, press and hold "Vol+" for 10 seconds and connect Micro USB cable. Phone found at port COM126 Mode: Emergency Initializing flash...OK Model ID: LG-K350Z SW version: LGK350ZAT-00-V13v-GLOBAL-COM-JAN-24-2018+0 LAF Version: 1.1 Product ID: 000000 Target operator: GLOBAL Hardware: rev_10 Battery level: 50% Reading partitions...OK Checking security... Checking security passed! -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Writing phone firmware without real necessity is at your own risk. Downgrade may lead to phone damage! Please, make sure the phone's battery is fully charged. Disconnect all other devices from the computer (including phones, modems, etc.) and close all other running programs. To avoid errors in the flashing process, use a clean PC (without any installed drivers for other Qualcomm-based devices). You should not run any other programs or attach new devices to your computer during the flashing! -------------------------------------------------------------------------------- Opening "K350Z10h_00_0124.oct"...OK Setting options...OK Reading partitions...OK Formating USERDATA...OK Formating ENCRYPT...OK Writing preloader...Failed! Performed by 2.8.5 Software version. |
