LG Android based phones General LG Android phones discussion, firmwares, solution, root, help |
04-05-2017, 06:50 | #1 (permalink) |
Moderator Join Date: Oct 2011 Location: U.A.E
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,713 | Unbrick LG G4 Brick hs-usb Qdloader 9008 Without Box Unbrick LG G4 Brick hs-usb Qdloader 9008 Model SupportedCredit Goes To Alnajat Soft Team Engineer Mohammed Alshikh H815 H818 H818N H818P H819 LS995 LS991 H811 LG G4 H811 fix.zip H810 Fix By QFIL.zip 1. Download QPST.WIN.2.7-00430-GENERAL Run setup.exe Windows [Start] button >> Allprograms >> QPST >> QFIL installation confirmation 2. Download Qdload9008_HSUSB_Driver Install Drivers 3. D / L via QFIL To force QDloader download mode, connect the FORCED_USB emmc section with a jumper. Or pressing key combination (volup + voldown) and poweron to boot Emergency D / L mode After two points in the red circle are shorted and connected by power or USB connection, Qdloadmode can be entered and connected to QFIL In Emergency D / L mode, check the port in Device Manager after connecting USB -> QS Windows [Start] button >> All programs >> QPST >> Run QFIL Select Port 1. Click the "Select Port" button If you deselect Show Non Diagnostic Port, only the "Diagnostic" or "QDLoader" port will be visible Selecting the port identified by Device Manager MBN file selection 2. Click the "Browse" button Select the file "prog_emmc_firehose_8992_lite_stable.mbn" in the folder where the images are stored. For fusing samples, use images made for fusing. ForFusingDevice: For Fusing Devices -> Download to LAF after recovery NotForFusingDevice: for non-fused devices -> Restore and download Select Build, RawProgram, Patch Check Check RawProgram and Patch settings Check the rawprogram0.xmlpatch0.xml file included in the -Select Build path. firehoseprogrammer MBN selected in the same folder Rawprogram0.xml, patch0.xml are loaded. SWDownload 4. Click the "Download" button - The progress bar below is completed and the Download Succeed -> Finish Download message is confirmed. Last edited by ...:::SHAMIM:::...; 10-25-2017 at 14:59. Reason: New Link Added! |
The Following 67 Users Say Thank You to ...:::SHAMIM:::... For This Useful Post: |
04-05-2017, 16:23 | #2 (permalink) |
Insane Poster Join Date: Aug 2013 Location: Dark Web
Member: 2007622 Status: Offline Sonork: 100.1674569 Thanks Meter: 12 | THANKS BRO ...Recover File for h811-ls995-h818p/n is the same as h818? |
The Following 3 Users Say Thank You to diamand21 For This Useful Post: |
04-07-2017, 15:57 | #5 (permalink) | |
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,713 | Quote:
Whats the Condition on Your H811? What Was The Problem? Does Your Phone Automatic Detected PC Qualcomm hs-usb Qdloader 9008 Port By Wrong Software or Downgraded Flash. Explain Your Details Problem! | |
04-07-2017, 19:52 | #7 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | As for as i knw these files are not official, these file are generated from kdz using UFI Box and added matching cpu emmc firehose.mbn with this i guess. Better go for emmc isp or try via usb repair if supported by jtag boxes, try medusa , ufi etc.. |
The Following 2 Users Say Thank You to jamesjerss For This Useful Post: |
04-08-2017, 09:11 | #8 (permalink) |
Member: 1676524 Status: Offline Sonork: 100.1608473 Thanks Meter: 2,713 | For H811 I Selected LS911. It will back your Download mode and LG Logo only! but You can't Run Your Phone by New Software. If You make flash that phone by H811 Firmware it will become again Brick. Because both of phone Boot partition are not Same! But You can Try to Reflash with phone any professional Device and let us know. Last edited by ...:::SHAMIM:::...; 07-16-2018 at 19:09. |
The Following User Says Thank You to ...:::SHAMIM:::... For This Useful Post: |
04-11-2017, 13:53 | #9 (permalink) | |
Junior Member Join Date: Jul 2015 Location: Dominican Republic
Member: 2424640 Status: Offline Sonork: Nothing Thanks Meter: 5 | Quote:
Download Fail:Sahara FailSahara Fail Finish Download | |
The Following 2 Users Say Thank You to Alber08 For This Useful Post: |
04-11-2017, 15:10 | #10 (permalink) |
Junior Member Join Date: Aug 2015
Member: 2450153 Status: Offline Thanks Meter: 0 | COM Port number:83 Sahara Connecting ... Download Fail:Could not connect to the COMPORT Download Fail:Sahara FailValue cannot be null. Parameter name: key Finish Download any advice ??? |
04-12-2017, 06:20 | #11 (permalink) | ||
04-12-2017, 18:29 | #13 (permalink) |
Junior Member Join Date: Apr 2017
Member: 2706069 Status: Offline Thanks Meter: 0 | I have a LS991 running ZVD and I wish to rollback to ZVB. I have an octopus box but I can't download ZVB firmware from there(I can get firmware from rwilco's repository) but my question is if I rollback to ZVB using Octopus box, will it still result in a hard brick? I know octopus box is a useless box as it only does what LG Flash tools are capable of doing and nothing more. Thanks! |
04-12-2017, 19:33 | #14 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: (United States Of Islam) Age: 37
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | Quote:
The Following User Says Thank You to Faheem Anjum For This Useful Post: |
04-12-2017, 19:35 | #15 (permalink) |
Member: 399832 Status: Offline Sonork: Faheem Anjum Thanks Meter: 24,310 | there are many new boot roms which cant boot via usb only the way to use emmc and repair it the usb method is old and only work for old bootroms phone which handle with usb mod |
The Following 5 Users Say Thank You to Faheem Anjum For This Useful Post: |
