Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones > Android based chinese phones
Old 03-15-2018, 00:02   #1 (permalink)
Member: 1925987
Sonork: dearlex
Thanks Meter: 130
Download Infinix clone copy Firmware (flash file)
On this page, we have contained the official link to download Infinix clone Stock Firmware ROM ( flash file) on your Computer. which can be used to download and load stock firmware on your Infinix copy clone.
How To Flash Infinix clone copy?
MediaTek devices are being used and become popular massively you should understand about flashing and have precise knowledge and understanding about flashing MTK chipset, therefore, you should know some important points before the start...
Backup your previous data info.
Unzip Downloaded Flash File.
Download Smartphone (SP) Flash Tool From @here.
Download Mediatek (MTK) Update Android USB Cable Driver.
Load Scatter From Download File in Smartphone (SP) Flash Tool.
Charge Battery Minimum 50% Up.
Setup Android USB Cable Vcom Driver.
Press Flash Start Button.
Insert USB Cable & Wait For Flash Done.
Follow the How-to Flash Manual to Flash the Firmware on your Infinix A88 Device.
Follow Detailed Guidelines
Readme Once:
[*] Take a Backup: If you are going to flash the above Firmware on your Infinix A88 device, then take a backup of everything as because your personal data will be deleted after flashing the stock ROM.
[*] The firmware shared on this page is officially released by the company and helps you to recover your device if you ever got bootloop, software error, update error, hanging and dead issue.
HERE IS THE FIRMWARE COLLECTION LINKS
Infinix A88 Flashing Solution Original Firmware (New flash file)
Infinix Hot V2 Pac Firmware (flash file)
Infinix A8900 Stock Firmware -Marvell (flash file)
Infinix M8 Stock Firmware (flash file)
Infinix Hot V4 MT6592 Stock Firmware (flash file)
INFINIX X552 CLONE Stock Firmware (flash file)
Infinix X509 Huawei Clone stock Firmware (flash file)
Infinix AL68 Stock Firmware (flash file)
Infinix P2 Stock Firmware (flash file)
Infinix X557 Hot 4 Clone Stock Firmware (flash file)
Infinix X601 Note 3 Clone Stock Firmware (flash file)
Infinix K1 aka X551 Clone Stock Firmware (flash file)
Infinix Hot V4 MT6735M Stock Firmware (flash file)
Infinix Hot V3 MT6735M Stock Firmware (flash file)
Infinix F818 stock Firmware (flash file)
Infinix V3800 Stock Firmware (flash file)
Infinix X1 Stock Fimrware (flash file)
Infinix F98 Stock Firmware (flash file)
Infinix X557 SpreadTrum Pac Firmware (flash file)
Firmware Fixed Below Issues
Pattern Lock solution.
Password Lock Problem Fixed.
Privacy Lock Solution.
Application Lock Solution.
Screen Lock Problem Fixed.
FRP Lock (Google Account Lock) (Type Email & Password & Press Next) Problem Fixed.
Hang On Logo Problem Fixed.
Dead phone Recovery.
Unfortunately, Any Apps has Been Stoped.
Heat Problem Fixed.
Auto On Off Problem Solution.
White Screen Problem Solution.
Blank OR Black Screen Problem Fixed.
What are Ram and Rom? Check here:*
Old 06-20-2018, 00:50   #2 (permalink)
Member: 2705368
hi, i need help with this file (SP7731GEA_scx35_sp7731gea_5.1_LMY47D_release-keys_X551), i have searched almost everywhere but i found none... thanks in advance
Old 08-10-2018, 03:49   #3 (permalink)
Member: 847906
Sonork: 1654522
Thanks Meter: 5
Infinix Note 4 X572 Firmware (Stock ROM)
MediaTek MT6735 CPU thanks advance
Old 11-20-2018, 15:44   #4 (permalink)
Member: 1677653
Thanks Meter: 2,769
Originally Posted by engdearlex View Post
on this page, we have contained the official link to download infinix clone stock firmware rom ( flash file) on your computer. Which can be used to download and load stock firmware on your infinix copy clone.
how to flash infinix clone copy?
mediatek devices are being used and become popular massively you should understand about flashing and have precise knowledge and understanding about flashing mtk chipset, therefore, you should know some important points before the start...
Unzip downloaded flash file.
Download smartphone (sp) flash tool from @here.
Download mediatek (mtk) update android usb cable driver.
Load scatter from download file in smartphone (sp) flash tool.
Charge battery minimum 50% up.
Setup android usb cable vcom driver.
Press flash start button.
Insert usb cable & wait for flash done.
Follow the how-to flash manual to flash the firmware on your infinix a88 device.
Follow detailed guidelines
readme once:[*] take a backup: If you are going to flash the above firmware on your infinix a88 device, then take a backup of everything as because your personal data will be deleted after flashing the stock rom.[*] the firmware shared on this page is officially released by the company and helps you to recover your device if you ever got bootloop, software error, update error, hanging and dead issue.
here is the firmware collection links
infinix a88 flashing solution original firmware (new flash file)
infinix hot v2 pac firmware (flash file)
infinix a8900 stock firmware -marvell (flash file)
infinix m8 stock firmware (flash file)
infinix hot v4 mt6592 stock firmware (flash file)
infinix x552 clone stock firmware (flash file)
infinix x509 huawei clone stock firmware (flash file)
infinix al68 stock firmware (flash file)
infinix p2 stock firmware (flash file)
infinix x557 hot 4 clone stock firmware (flash file)
infinix x601 note 3 clone stock firmware (flash file)
infinix k1 aka x551 clone stock firmware (flash file)
infinix hot v4 mt6735m stock firmware (flash file)
infinix hot v3 mt6735m stock firmware (flash file)
infinix f818 stock firmware (flash file)
infinix v3800 stock firmware (flash file)
infinix x1 stock fimrware (flash file)
infinix f98 stock firmware (flash file)
infinix x557 spreadtrum pac firmware (flash file)
firmware fixed below issues
pattern lock solution.
Password lock problem fixed.
Privacy lock solution.
Application lock solution.
Screen lock problem fixed.
Frp lock (google account lock) (type email & password & press next) problem fixed.
Hang on logo problem fixed.
Dead phone recovery.
Unfortunately, any apps has been stoped.
Heat problem fixed.
Auto on off problem solution.
White screen problem solution.
Blank or black screen problem fixed.
What are ram and rom? Check here:*
brother why do you uploaded password firmware on gsm hosting?
Admin should act on this
Old 11-21-2018, 04:42   #5 (permalink)
Member: 2873666
Sonork: 100.1681658
hi i cannot download a rom
Old 05-09-2019, 17:10   #6 (permalink)
Member: 2901958
Thanks Meter: 9
Model Name : s10c_q28
Model Brand : XLTEL
Model Device: s10c_q28
AndrVersion : 6.0
BaseBand CPU: S10C_Q28
CompileDate : 1/19/2018 11:43:33 AM
Project Ver : Android_6.0_V10
Model Ext : TECNO-J8
help me with that file
Old 11-26-2019, 11:07   #7 (permalink)
Member: 1825908
Sonork: juju
Thanks Meter: 60
Model Brand : XLTEL
AndrVersion : 6.0
i've this problem too
Old 11-26-2019, 13:58   #8 (permalink)
Member: 1029926
Sonork: Tufail4463
Thanks Meter: 17
Need X522 Clone Firmware
Old 04-16-2022, 08:54   #9 (permalink)
Member: 1527968
Sonork: 100.1651182
Thanks Meter: 483
need infinix x690 not 7 spd firmware......
Old 11-15-2022, 11:51   #10 (permalink)
Member: 2076914
Sonork: 100.1627656
need infinix clone x683 firmware
Page generated in 0.22052 seconds with 9 queries
