GSMSERVER GSM Shop
Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones > Android based chinese phones
Old 04-25-2020, 10:17   #16 (permalink)
noidodroid's Avatar
Member: 2843734
Thanks Meter: 116
Not what i would use but there are some other places that have some not so nasty tencent variant AIO rootkits.
Old 04-25-2020, 10:19   #17 (permalink)
noidodroid's Avatar
Member: 2843734
Thanks Meter: 116
Originally Posted by ...:::::NP™:::::... View Post
Requirements :
A MediaTek android device (MT65XX)
USB Chord.
Windows PC/Laptop.
Download ADB Drivers : ADB Drivers.
Download MTK Droid Tools for Windows : MTK Droid Tools for Windows.
Video tutorial :- How To Flash ClockworkMod (CWM) Recovery on Any MediaTek (MT65xx) Android Device
1. Download necessary files from above links.
2. Install the downloaded PDANet to your computer. It contains ADB Drivers.
3. Turn on your android device and connect it to your computer using USB Chord. (Make sure to Enable USB Debugging, go to Phone Settings — Developer Options — Enable USB Debugging.)
4. From your computer, open MTK Droid Tools that you have downloaded above and extract it to your desired location.
5. Open MTK Droid Tools.exe from the extracted folder (Run as administrator). Wait for the tool to detect your device. (If UBIFS warning appeared in the status message, this process will not work for you. Only ext4 supported.). Notice on the bottom-left part of the tool, a YELLOW color indicator means that your android device is does not have root shell yet. If it is GREEN already,
6. Click ROOT button to enable root shell your device. Wait for the progress bar on the Status, see your phone to Grant Superuser access. If the color indicator turns GREEN, then you have successfully enabled root shell for your device.
7. Now, select the Root, Backup, Recovery tab and and further choose To Use Boot From Phone from the selections. Click Recovery and Boot, a message prompt will appear “To make CWM recovery automatically”, click YES.
8. Wait for the tool to build the CWM recovery and another prompt will appear “install patched boot to phone?” select NO, wait a little bit more and another prompt will appear again “install created recovery to phone”, now select YES.
9. When the tool ask you to reboot your phone to recovery, click Yes and it will reboot to CWM recovery shortly. Check out your new custom recovery.
Congratulations! You now have Installed ClockworkMod custom recovery on your MediaTek android device. You can now enjoy apps that requires Superuser rights, mods and ROMs that requires flashing from CWM.
Source ==> devs-lab
Maybe i will show a mediatek way that will work on MANY. I've not tested it just yet.
Old 06-29-2020, 17:03   #18 (permalink)
Member: 1034743
Sonork: 100.1619212
Thanks Meter: 171
itel s15 pro how to root android 9
android 9
spd cpu
Page generated in 0.17844 seconds with 7 queries
