05-19-2016, 16:40 | #1 (permalink) |
Freak Poster Join Date: May 2015 Location: Algiers, Algeria
Member: 2399672 Status: Offline Thanks Meter: 187 | Meizu MX5 firmware upgrade Meizu MX5 firmware upgrade Although this is an MTK model; flashing with old method such as Sp flashtool wouldn't work although using the compatible firmware and would return and error because the baseband chip is secured and requires an authentification file. So in order to flash this phone a different upgrading tool would be used. All the files needed for this upgrading or soft unbricking operation are to be found in the download link. With no further do, let's get started. Firmware Upgrade Guide I. Preparations Hardware 1. A computer (recommended: dual-core CPU, 2 GB or larger memory, 250 GB or larger hard disk drive, and Windows 7 operating system) 2. USB cable 3. Meizu phone (with at least 30% of the power) Software (Downloaded from the link below) 1. Flyme firmware package (including both engineering and flyme OS firmwares) 2. Flashing tools (including the complete SFC and MultiUpgradetool) 3. Drivers (including the driver Driver_Auto_Install_v1.352.00 for the mobile phone and the softdog driver) II. Installing Drivers for the Mobile Phone and the Softdog 1. Open drivers folder and browse to Driver_Auto_Installer_v1.352.00 folder and excute the install batch file. (If the driver for the MX4 is installed, skip this step.) The system will display three to four messages. Select Always install the driver every time to proceed with the installation. The interface displays "Install Complete!", indicating that the MTK driver is installed. 2. Install the softdog driver. (If the driver for the MX4 is installed, skip this step.) Open EXE FOR PASSWORD folder and install ePass2003-Setup.exe A message is displayed indicating that the installation is complete. III. Upgrading the Flyme Firmware 1. Open the SFC directory. Run TestPCTool.exe and click Begin. 2. Within UPgrade Tool folder execute SPMultiPortFlashDownloadProject.exe. in the upgrading platform folder, and double-click. 3. Click on the scatter file and browse to the appropriate scater file. You might start with the engineering firmware if the phone is soft bricked and repeat the operation once the flash done with the Flyme os firmware. 4. Select the first N/A+N/A only, leave the type as Firmware upgrade and hit the scan button. A dialog box is displayed. Click Yes. 5. Power off the mobile phone, press the Volume-down button and insert the USB data cable into the mobile phone, until the two ports are detected and Scan Success! is displayed. Then, unplug the data cable. 6. Click Start on the right of the progress bar. The firmware loading window is displayed. 7. After the firmware is loaded (as shown in the figure below), press the Volume-down button of the mobile phone again and plug the USB data cable into the mobile phone. The mobile phone starts upgrading. The upgrade is complete, with START displayed Good luck. For further information you can send me a private message. Download link ====> Meizu MX5 Last edited by ...:::::NP™:::::...; 10-22-2017 at 21:17. Reason: Download link has been correction |
The Following 2 Users Say Thank You to SandyBridge For This Useful Post: |
06-03-2016, 16:53 | #6 (permalink) |
No Life Poster Join Date: Jun 2004 Location: MACEDONIA
Member: 67805 Status: Offline Thanks Meter: 364 | I have one meizu mx5 which ask for password, I don't know what password is that because *******r never put password or maybe aliexpress seller put flyme or what else password/account and now ask for password with note "Phone is locked" enter password. How to remuve password? is flashing this firmware only option or even after flashing it will ask for password again Br |
06-03-2016, 20:47 | #7 (permalink) |
Member: 2399672 Status: Offline Thanks Meter: 187 | It must be the flyme account which is like the iCloud on the iPhone so far u think there isn't a way to bypass this account and I'm not sure if it would be bypassed by flashing the phone |
06-08-2016, 07:56 | #10 (permalink) |
Registered User Join Date: Sep 2007 Location: RO, Bucuresti
Member: 595504 Status: Offline Sonork: 100.1580419 Thanks Meter: 249 | I have the same phone MX5 Meizu, i try to flash and only one com port is open and all the time scanning fail, the phone now is in bootloop, keep restarting all the time. |
06-14-2016, 22:37 | #11 (permalink) |
Crazy Poster Join Date: Nov 2005 Location: Ukraine
Member: 197827 Status: Offline Thanks Meter: 12 | I have a full set for the MX4 firmware devices M2 and M2 note, MX5 and Pro5. But it needs some token key for access to the boot loader. There are ways to do it without a key? |
06-23-2016, 22:47 | #13 (permalink) |
Freak Poster Join Date: Oct 2014 Location: efs Age: 33
Member: 2279944 Status: Offline Sonork: not avaliable Thanks Meter: 167 | all we need is a man who works in meizu...im ready to donation for flash files and procedure, otherway some emmc-boxes can flash mx5 and other devices but need dissemply,replace mainboard,,desolder emmc chip and program it via bga...this is a long procedure we need flashing procedure by usb |
