[MT6575/6577/MT6572/MT6582/6589]MTK Android Based Phone IMEI Write Tool IMEI&SN Writer Download DB File for MT6572, MT6575, MT657 & MT6589 Download from here 4shared folder - DB file MT6582 DB File Is Here Warning Only For Repair Original IMEI Br, azam |
where is db file can share that also |
bro select db from set is og flash file....... |
scr file not work in this tool this solution not work in mt 6572 |
If any one face any problem post here with screenshot. Br, azam |
sir i need hlp for micromax a67 pattern lock problem! pls hlp me sir thanks in advance! |
Steps: 1,Please power off the phone 2,Then plug in the USB cable USB Bootup Meta_DB Init Start: Meta_DB Init PASS Enter to ModemMeta Start: Enter to ModemMeta PASS Start Write IMEI: WriteIMEI_1: 911202151313301 WriteIMEI is OK !!! From ModemMeta to APMeta Start: From APMeta to ModemMeta PASS It is over !! sir after write ok , phone restart again and imei goes same as old one ,mt6572 |
nokia care plzz help up the thread Quote:
works for mt 6572 100 % |
guide other also |
Steps: 1,Please power off the phone 2,Then plug in the USB cable USB Bootup Meta_DB Init Start: Meta_DB Init PASS Enter to ModemMeta Start: Enter to ModemMeta Fail: It is over !! MT 6589 imei write failed |
works perfect for mtk 6577 model: skk a5 Steps: 1,Please power off the phone 2,Then plug in the USB cable USB Bootup Meta_DB Init Start: Meta_DB Init PASS Enter to ModemMeta Start: Enter to ModemMeta PASS Start Write IMEI: WriteIMEI_1: 359310045241189 WriteIMEI_2: 359310045241197 WriteIMEI is OK !!! From ModemMeta to APMeta Start: From APMeta to ModemMeta PASS It is over !! thanks man!!!..... |
hi thanx for reply all of u guys my s4 i9500 mt6572 problem is solved and my imei is repaired by dis tool and thanx to dat who give me solution this not possible yet on volcano but dis tool make my problem solve so i give dat linkhttp://forum.gsmhosting.com/vbb/f606/mt6572-6575-6577-6589-mtk-android-based-phone-imei-write-tool-1708731/#thisthis tool repaired imei successfully as u see in below pic even serial no an etc i thanks to nokian care http://img89.imageshack.us/img89/6910/zed1.jpg http://img820.imageshack.us/img820/2941/tvs6.jpg |
1 Attachment(s) mito tab t520 mtk 6577 http://forum.gsmhosting.com/vbb/atta...1&d=1380538289 Steps: 1,Please power off the phone 2,Then plug in the USB cable USB Bootup Meta_DB Init Start: Meta_DB Init PASS Enter to ModemMeta Start: Enter to ModemMeta PASS Start Read SN: ReadSN: MT012345678901234567 Read SN is OK !!! Start Write IMEI: WriteIMEI_1: 111111111111111 WriteIMEI_2: 222222222222222 WriteIMEI is OK !!! Start Read IMEI: ReadIMEI_1: 111111111111111 ReadIMEI_2: 222222222222222 ReadIMEI is OK !!! From ModemMeta to APMeta Start: From APMeta to ModemMeta PASS Read BT Address Start: ReadBT: de1246662867 Read BT is OK !!! Read WIFI Address Start: ReadWIFIAddr: 000000000000 Read WIFI Address is OK !!! Read SW Version Start: GetSWVer: ALPS.JB.MP.V1.22 Read SW Version is OK !!! Read Internal SW Version Start: GetSWVer_Internal: GM1503_M10_V1.1 Read Internal SW Version is OK !!! It is over !! |
