Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones > Android based chinese phones
Old 09-06-2017, 13:22   #151 (permalink)
Member: 2707033
Thanks Meter: 26
sp flash tool setting guide plz urgant
Old 09-06-2017, 13:23   #152 (permalink)
Member: 2707033
Thanks Meter: 26
mircomax a72 dead after flash sp flash tool full dead not detact in device manager
Old 11-26-2017, 16:33   #153 (permalink)
Member: 2782837
Flash 4022d
مشكلة تفليش Alcatel 4022D
Old 11-26-2017, 16:59   #154 (permalink)
gile@gile's Avatar
Member: 1473716
Thanks Meter: 1,277
https://firmware.gem-flash.com/index...e-info&id=7394
Old 03-22-2018, 13:10   #155 (permalink)
Member: 2823518
Mint fox mc3r
Hi guys, how do I flash Mint Fox mc3r that is stuck at the welcome screen and please send me all the required files
Old 06-07-2018, 09:56   #156 (permalink)
Member: 2842342
I have tried flashing using sp tool (latest version) but the error is SEC DL FORBIDDEN. I searched in google but it results saying that the bootloader is locked and need a special kind of tool (dongle) to flash it.
Old 06-07-2018, 22:11   #157 (permalink)
khan_mobiles's Avatar
Member: 476667
Thanks Meter: 56
Latest Version released Sp Flash Tool v5.1820
Old 09-22-2018, 15:04   #158 (permalink)
Member: 2863557
please help i have huwai G710-U10 there are big problem after starting flashing
[B]brom exception ( error s_brom_download_da_fail (2004)
how to fix this problem i have no idea so please help me any persion
Old 11-20-2018, 15:12   #159 (permalink)
Member: 702498
Thanks Meter: 2
Enable Dram Fail error 0xFC0
Hello
I am trying to flash s color P9 Plus there is an error S_FT_ENABLE_DRAM FAIL (0xFC0) the flash file is from exact model which is working fine can any one help to solve this I have used two different PCs but the error is same please reply it'll be a great help .I have also used volume down button but nothing works
Thanks in Advance
Old 11-25-2018, 15:22   #160 (permalink)
Member: 702498
Thanks Meter: 2
As yet no one has responded to my post but I am still posting lets see if any one still read this thread here is the issue I have s color P9 plus the phone is brick dead someone made working flash from volcano inferno tool & gave to me when I tried to flash different errors come from Sp flash versions ..like SP flash tool 5.1836 gives the error of boundary check ( pic attached ) I used SP flash tool 5.1620 it gives the error of 0xFC0 ..Sp flash tool 5.1752 gives the error of error 4032 please help me how i could fix I have an other working of same model when I connect to detect the RAM sp flash tool reads fine so the driver issue is being ruled out please help me out in this
Old 04-25-2019, 09:08   #161 (permalink)
Member: 1485647
Tecno W5 Lite - Unable to flash
Dear Members,
I have this mobile phone with the following specifications:
Tecno W5 Lite Core Specifications
Model: Tecno W5 Lite
2G Network: Yes
3G Network: HSDPA 850 / 900 / 1900 / 2100
4G Network: LTE 3(1800) / 7(2600) / 20(800)
SIM: Dual mini SIM
Body Dimensions: 153.2 X 76.4 X 7.8 mm
Display Type: IPS capacitive touchscreen with 16,000,000 colors
Display Size: 5.5 inches, 720 x 1280 pixels, 267 pixels per inch (PPI)
SD Card slot: MicroSD card, up to 32GB
Internal Memory: 16GB
OS: Android 6.0 Marshmallow
Processor: 1.3GHz quad-core Cortex-A53
CPU: MediaTek MT6580 chipset, Mali-T720 GPU
RAM: 1GB
WIFI: Wi-Fi 802.11 b/g, WIFI hotspot
Bluetooth: Version 4.0
GPS: A-GPS
NFC: No
USB: MicroUSB v2.0
Primary Camera: 13MP, up to 4128 x 3096-pixel pictures, HDR, autofocus, Geo-tagging,
panorama camera with LED flash
Video: 1080@30fps
Secondary Camera: 5MP, up to 2592 x 1944-pixel pictures, LED flash
Battery Capacity: 3000mAh Li-Ion battery
It used to hang on logo or but later it was not booting, i have tried several times to flash with no success. i have tried to use these two firmwares:
1. Tecno_W5_Lite_MT6580_6.0_H8010A1-M-161014V147
2. W5Lite-H8010B1-M-EG-161115V93
I always get this Message: "BROM ERROR : S_FT_ENABLE_DRAM_FAIL (4032) [EMI] Enable DRAM fail".
Can my phone be revived?. When i connect it to the PC, i hear a sound twice after every few seconds as if the phone is connected to the PC and then disconnects.
The files i see on Device Manager:
MediaTek Preloader USB VCOM (Android)
MediaTek DA USB VCOM (Android)
MediaTek USB Port
MediaTek USB VCOM
Thanking you in advance.
Old 11-02-2019, 11:49   #162 (permalink)
Member: 2302116
Sp Flash Tool
ERROR : S_DL_WRITE_PT_FAIL (5072)
need solution
Old 09-14-2020, 12:17   #163 (permalink)
Member: 2967731
where can I find download link?
Old 09-23-2020, 13:34   #164 (permalink)
Member: 164422
Thanks Meter: 24
k8 note flash error
I have a few lenovo k8 note witch gives this error while trying to flash using sp tool.hat could be the cause of this.is it a softare issue or an hardware issue.
Page generated in 0.22482 seconds with 9 queries
