12-29-2014, 06:04 | #1 (permalink) |
No Life Poster Join Date: Aug 2012 Location: India Age: 39
Member: 1792140 Status: Offline Sonork: 100.1618782,gaba Thanks Meter: 6,087 | what are the all image in a mtk rom And what does each image do ? Boot.img : boot.img contains the kernel and ramdisk, critical files necessary to load the device before the filesystem can be mounted. Having a wrong Boot.img on your phone can refuse it to boot ! cache.img Contains the cache data where Android stores frequently accessed data and app components. not really needed and should be unticked when trying to flash a device. Checksum.ini verifies md5 checksum , if you get a checksum error before flashing, just delete it Wink EBR1, EBR2 Are your partitions. 1+2 Means 2 Partitions. You can also edit the size of them. UBOOT (LK.BIN) U-Boot is an universal boot loader for embedded systems, targeting different platforms including ARM. Uboot and BootIMG are important files on your phone. If your device is not booting or your display is not working ( black or stripes ) , you should reflash and check those files. Logo.bin As the name suggests, this is your bootlogo Happy It can be changed using this tutorial MBR Stands for Master-Boot-Record. MBR is generally referred to as first sector (size : 512 bytes) of any partitioned drive whereas volume or partition boot record holds code to initiate booting and is invoked by MBR. So in short words, it defines your partitions. Scatter File : Scatter is a file which is used to describe the loads of regions in a specific android device running MediaTeks ARM architecture. Bascially it tells the flash tool where to flash each image. Preloader : this is really important. The preloader communicates with your PC. It´s needed when you want to flash your device. Due to the preloader your phone should be detected as a port on your pc and should be flashable. Downloading a wrong pre-loader can brick your phone , so be careful ! Never flash the preloader if not needed. There are different states of the pre-loader (like META Mode). Even when you think your phone is bricked, mostly you can revive it. Recovery.img Thats you recovery. It must be "tailored" to each device. You cant flash a recovery image from a different device, but you can create your own CWM recovery using MTK droid tools. Secro.img Is an important file for the baseband and the IMEI. You need to reflash it to rebuild the structure. But anyway you have to restore your IMEI too. System.img As the name suggests, this partition contains the entire Android OS. You can try different system.img from other phones without a problem. just be sure to have a backup when you try them Happy User Data : Contains your personal data (do not share it with a backup) So this partition contains the user’s data like your contacts, sms, settings and all android applications that you have installed. While you are doing factory reset on your device, this partition will wipe out, Then your device will be in the state, when you use for he first time, or the way it was after the last official or custom ROM installation. I hope this helps you to understand the rom structure Br Umesh Gaba Last edited by Prem_India; 12-30-2014 at 10:03. Reason: unnecessary Words Removed |
The Following 26 Users Say Thank You to Umesh_Arora For This Useful Post: |
12-29-2014, 08:19 | #2 (permalink) |
Freak Poster Join Date: Dec 2013 Location: Lahore
Member: 2093017 Status: Offline Sonork: 100.1650959 Thanks Meter: 117 | one Thing Just to Know MR Umesh,i Flashed Many Huwei Mobile Set With sp Tool,one of My Friend Flashed Huwei Set That Was Pattern Locked,After That it,s Show White Display With Stripes Line,i Flashed Booot Many File,s As You Above Describe But Problem Not SOlved,Bro Can you Tell us What is This Error Partition Boot Etc. |
10-03-2015, 22:56 | #6 (permalink) |
Freak Poster Join Date: Apr 2014 Location: ******.amman Age: 39
Member: 2168728 Status: Offline Thanks Meter: 45 | thanx alot bro ... finally i fund it ... i really need it to explain it to my classroom .. thanx agine ... by the way you can fix preloader by force it from board by make jumper between Gnd and kcolo or colo or kolo its depance on board ... BR |
The Following User Says Thank You to majdiahmad For This Useful Post: |
02-12-2017, 19:32 | #8 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | fat means file allocation table . the purpose of the file allocation table is to provide the mapping between clusters – the basic unit of logical storage on a emmc chip at the operating system level – and the physical location of data in terms of cylinders, tracks and sectors . |
02-10-2018, 12:13 | #9 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Inside MTK Age: 38
Member: 248182 Status: Offline Thanks Meter: 786 | There is need to update the information about currently available partition on MTK smartphones .. some example is mention below. pgpt proinfo para expdb seccfg oemkeystore keystore tee1 tee2 metadata flashinfo efuse sgpt |
09-14-2019, 12:36 | #10 (permalink) | |
Major Poster Join Date: Jul 2019 Location: Alabama
Member: 2919981 Status: Offline Thanks Meter: 7 | Quote:
02-04-2023, 15:52 | #11 (permalink) |
Junior Member Join Date: Jan 2023 Location: Bangladesh Age: 23
Member: 3030888 Status: Offline Thanks Meter: 0 | How can I flash sacro.img? How can I flash sacro file? Please recommend me any free flash tool (if needed) or Is there any way to flash the image via fastboot? |
