05-05-2017, 13:04 | #1 (permalink) |
Freak Poster Join Date: Jul 2010
Member: 1349375 Status: Offline Thanks Meter: 8 | ARCHOS 50F HELIUM LITE Weak and losing signal I need your help this phone after dropping, has weak signal and sometimes signal dropping from 3/4 bars to 0/1 bar, any ideas how to solve this problem or do you have any service manual for this phones? Thanks, |
05-08-2017, 19:18 | #2 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | I don't found yet it's service manual or schematics but it's quite common problem for any brand . as it's drop down set most probably inner ant connection became loose or not contact properly . so check mobile inner ant pads or connectors for any loose contact . if you found same issue after cheking this then you need to reflow rf section with good solder flux. post result |
