Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones > Chinese Phones Hardware Repair
Old 11-26-2012, 15:40   #1 (permalink)
muhammad khalid's Avatar
Member: 313337
Sonork: 100.1582697
Thanks Meter: 106
RDA 6625 PA jumper for china mobiles
many china mobiles became short circuit
some mobiles PA blosts remove that shorted PA and jumper as in picture
tested on 02 yestel x2-02
http://img171.imageshack.us/img171/4...25pajumper.jpg
thanks to you all by gsmzaman
Last edited by muhammad khalid; 11-26-2012 at 15:45. Reason: picture was not inserted
The Following 8 Users Say Thank You to muhammad khalid For This Useful Post:
Old 12-04-2012, 06:21   #2 (permalink)
Member: 792254
Sonork: al_jadeed
Thanks Meter: 171
not work for me i chek 2 set
The Following User Says Thank You to asif-rashid For This Useful Post:
Old 12-05-2012, 13:51   #3 (permalink)
Member: 313337
Sonork: 100.1582697
Thanks Meter: 106
As We know that Power amplier can not be jumpered.. because then it will not amplify (boost) the power transmitted.
We technicain knows that jumper is only last solution when ic's are not available in market. if any one have replacement of component then he is not advised to jumper
espacially to amplifiers like audio or RF power ammplifiers.PA
this jumper will give you two limited benefits
1. It is pointing us to fault and It will remove our cell phone shortage when we will remove this ic
2. It will show service on some simcards / operator / mostly near to booster etc
. Telenor Pakistan is tested by me. In your case may be other one, So change sims which ever is your luck.
Thanks to you all by gsmzaman
The Following 2 Users Say Thank You to muhammad khalid For This Useful Post:
Old 12-06-2012, 09:32   #4 (permalink)
Member: 1849106
Sonork: 43015
The Following User Says Thank You to smithjenife For This Useful Post:
Old 12-07-2012, 06:34   #5 (permalink)
Member: 737844
Thanks Meter: 18
ustadg
not work bro plz give me this solution
Old 12-07-2012, 15:38   #6 (permalink)
Member: 1767104
Thanks Meter: 20
this jumpar 100% ok .but network low. whit out ic this jumpar not bad.
The Following User Says Thank You to bappa_gsm For This Useful Post:
Old 12-08-2012, 06:29   #7 (permalink)
Member: 313337
Sonork: 100.1582697
Thanks Meter: 106
please read my post care fully
it is last option when you asure that 6625 RDA is damaged and no replacement of of found, then jumper and found low signal and registered on some network.
if you found no signal that may be your problem is some where else in the circuit.
mostly the circuits become short in this model caused by RDA 6625 shortage, are repaired to replace the ic or jumper like this and get low signals.
May be in your case due to shortage of this ic some where els this circuit is damaged . and this can be checked only by the technicaian have the mobile phone in his hand. So advised to check other hardware also
The Following User Says Thank You to muhammad khalid For This Useful Post:
Old 12-08-2012, 08:24   #8 (permalink)
Member: 492386
Sonork: 100.1601487
Thanks Meter: 63
Keep it up...
Nice shearing about RF-PA it's full meaning is (Radio Frequency Power Amplifier).Your suggestion about this sector is 100% true.give us this kind of necessary articles.Good post.THANKS again.
The Following User Says Thank You to sony kabir For This Useful Post:
Old 12-11-2012, 08:08   #9 (permalink)
Member: 681329
Thanks Meter: 2
above mentioned jumper settings its not working my PA ic number :
RDA
6625
5232A
U92822
any one can help me my mail id is [email protected] pls help i have more than 20 handsets having this problem.
Old 12-11-2012, 08:26   #10 (permalink)
Member: 681329
Thanks Meter: 2
its not working
pls help
Old 12-11-2012, 13:00   #11 (permalink)
Member: 681329
Thanks Meter: 2
Hi Kindly Send The Jumper Settings For The Below Mentioned PA IC
RDA
6625
5232A
U92822
Already I Was Tried Which They Updated In online. So Pls Help Me
Old 12-16-2012, 13:46   #12 (permalink)
Member: 313337
Sonork: 100.1582697
Thanks Meter: 106
write here all detail written on ic
optionally mobile model
May be we can help each other
thanks to you all by gsmzamam
Old 12-20-2012, 09:01   #13 (permalink)
Member: 681329
Thanks Meter: 2
IC DETAILS
RDA
6625
5232A
U92822
CHINA Gmobile J5000 AND X202 No SIgnal Only Searching pls help
Old 12-25-2012, 15:06   #14 (permalink)
imrankhan0143's Avatar
Member: 1796401
Sonork: 100.1623409
Thanks Meter: 56
bhai mere fack solution hai
Old 01-04-2013, 12:31   #15 (permalink)
Member: 681329
Thanks Meter: 2
i tried but still same problem exist
pls help
Page generated in 0.35884 seconds with 8 queries
