Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones > Chinese Phones Hardware Repair
Old 08-28-2014, 19:32   #1066 (permalink)
Member: 1883473
Thanks Meter: 11
pls can anybody help me, my china nokia c1 display is not working with normal nokia screen
Old 08-30-2014, 13:32   #1067 (permalink)
Member: 2047179
Thanks Meter: 31
micromax x320
micromax x320 headphone sign show on display solution
Old 09-03-2014, 08:08   #1068 (permalink)
Member: 1820923
My itouch china android mobile has a broken wire. I can tell you its location. I found it broken where the volume down button is fixed and in pcb it was above 2 cms. ofthe battery positive terminal. Wire was fixed by glue at that point, so i think that it must be soldered near the battery + terminal. Help me to fix/solder itand thats why its not charging or not able to give charge to display.
thank you
Old 09-03-2014, 11:52   #1069 (permalink)
Member: 1883473
Thanks Meter: 11
pls can anybody give me china insert sim solution,the name of the phone is tecno T384
Old 09-05-2014, 15:22   #1070 (permalink)
Member: 2239246
Connect me with facebook,com/MicroManash I will try it. Post your mobile image
Old 09-16-2014, 08:31   #1071 (permalink)
Member: 2247270
hello brdr. Mere pas china set he jis me signal bohot low he or bar bar searching show karta he. Solution plz
Old 09-16-2014, 12:13   #1072 (permalink)
helpful-man's Avatar
Member: 1306751
Sonork: 100.1604993
Thanks Meter: 4,916
Bro check antina connection ok
after re solder network section
The Following User Says Thank You to helpful-man For This Useful Post:
Old 09-25-2014, 22:35   #1073 (permalink)
Member: 2263980
dear sir hello,,my problem is for model N7189, board E2001_v2.0,this phone not charging the battery ,if i charge the battery with ps its working fine.
if i plug the gharger nothing so the charge at the screen.
i chek micro usb connector and dc on bord.
do you belive the fault is ic power managment?
do you have schema of this?
thenks.
Old 09-26-2014, 20:00   #1074 (permalink)
Member: 2263980
foto
this is bord to i have no charge problem,i cheking connector is ok,i dont find ic pt 116 on bord,cpu is mtk6589t
Old 10-02-2014, 12:20   #1075 (permalink)
Member: 2267414
chaina g5 displaycomplaint
Old 10-02-2014, 19:19   #1076 (permalink)
Member: 1749539
Sonork: srn_sorinel
Help please sm900 s5 clone
Hy there y need a good picture for base board for sm900 s5 clone because i dont have network ,is burn a ic and not see the valor or name for this ic.help please and if you know a solution for network put here too see.sorry for my english
Old 10-03-2014, 00:51   #1077 (permalink)
Member: 2249798
Thanks Meter: 26
Kimfly mobile
bro China kimfly mobile in network problem Failed to Register please help me IMEI OK..
Old 10-03-2014, 07:21   #1078 (permalink)
Member: 1306751
Sonork: 100.1604993
Thanks Meter: 4,916
re solder network section & Replace pa
Old 10-03-2014, 09:28   #1079 (permalink)
Member: 2249798
Thanks Meter: 26
need to resold all thing in network section and what is pa??? can u tell me how to set a profile pic in id??? plese help....
Old 10-04-2014, 14:21   #1080 (permalink)
Member: 2245346
Hi
i have a problem pls help
E-tel v3
buzzer/ringer one path damage how can i fix the ringer?
if u can pls upload picture to
thanks
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.22597 seconds with 10 queries
