08-30-2016, 11:17 | #1 (permalink) |
Junior Member Join Date: Oct 2009
Member: 1134923 Status: Offline Thanks Meter: 1 | touch issue. humidity problem. I have elephone p3000s. I'm working with this phone and it good enough for me at this time. but in the work I put it in the pocket and I sweat and all of the pocket was with humidity and suddenly the touch screen start to press alone on many areas. after some outside cleaning it was acting normal but one area on the screen (in the middle) I think it shorted by the humidity. does anyone have some experience with this problem? I opened the phone and clean it with alcohol and also warm the lcd with 240c temp for 2 minutes and nothing. still (confirm or cancel buttons can't be pressed - they are in the middle of the screen) After explaining the problem - does anyone have any idea what can it be? how the touch screen works? were should be the short or something? may i separate the lcd from its own frame and try to dry anything inside? may it help ? I don't want to damage the lcd or something. new lcd is about 68$ and I can't afford it. Thank you a Lot!!! |
10-04-2016, 08:37 | #2 (permalink) |
Freak Poster Join Date: Mar 2012
Member: 1738539 Status: Offline Thanks Meter: 11 | Is that you replace an new touch to the phone? For we offer the solution for the designer,those things happen from time to time. Tuning the software is required. And normally it is not caused by hardware such as dirty... |
10-08-2016, 10:51 | #3 (permalink) |
Member: 1134923 Status: Offline Thanks Meter: 1 | No I didn't try other lcd. I think it would work. I had this problem with so many phones and replacing screen is clearly work but I don't want to buy new lcd Im asking if there a cheaper solution and also understanding how it work actually. Im sure that not software problem. Sent from my P9000 using Tapatalk |
