(guide) how to enable usb debug in moto e2 xt1526 & 1521 1 Attachment(s) |
Doesn't work.....doesn't allow searching |
type english in search you see the google keyboard |
Tested in lollipop 5.1.1 |
does not work sir.plz help me moto e2 1521 |
on my xt1528 dialing *#*#4636#*#* doesn't bring up the menu. anyone got a workaround? |
i have this same unit for months. still cant achieve to remove frp. have tried lots of methods but nothing yet. not even a full web browser or google search box. |
on my xt1526 dialing *#*#4636#*#* doesn't bring up the menu. anyone got a workaround? |
:confused::confused::confused::confused:I just came xt1526 model and managed to put the code on the keyboard calls but does not access the menu ... any solution ? |
*#*#4636#*#* not working on xt1505... |
ByPass: 1. Playing in email and keep pressed the @ until a menu of options. 2. keyboard settings Google 3. orthographic / staff / Dictionary correction for all languages 4. On the next screen tap the magnifying glass and press the letter "c". Several options were deployed and there Google Pinyin Input to choose. On the next screen we chose the same option. 5. Then choose "about" Open Source Licenses" 6. On the next screen may maintain finger pressing and the option will appear "Share" to choose "messages" typing 112 and send. At that time the call keyboard appears delete 112 and type * # * # 4636 # * # * 7. On the next screen you can choose info or battery usage statistics. 8. Then go to back with the arrow on the top left 9. ByPass done. 10. Here you can not enable the developer and we can not restore option. It's just bypass |
Need solution Frp of motorola Xt1528 |
Thought I would share as I struggled to find a way around it for this model and software and had to read and watch various different methods from all over the web with no joy. Tested on XT1506 but may work for other models. For SURNIA I believe there are other methods as they have official 6.0. Prerequisites: Working adb environment. Installing Motorola drivers and adb should suffice and can be found all over the forum. 1. Boot into bootloader (hold vol down and power button while off) and connect to PC via USB. 2. Use vol down to scroll to 'QCOM' and select with vol up. 3. After phone reboots, wait for adb prompt on phone screen and select OK. 4. Open adb command prompt and enterCode: adb shell content insert --uri content://settings/secure --bind name:s:user_setup_complete --bind value:s:1 This should complete the setup wizard. You may have to select the next screen arrow. 5. You now have full access to the settings menu and Backup & reset>Factory data reset> Reset phone is no longer greyed out. Select the option, let the phone reset and you can now set up the phone as new. |
br GONDAL |
