Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help |
10-19-2013, 08:40 | #1 (permalink) | |
Cheater -Don't Deal with him- Join Date: Sep 2010
Member: 1390802 Status: Offline Thanks Meter: 1,101 | Patch to fully enable GSM on Motorola Verizon CDMA phones <======== If you have a Motorola Verizon Global Phone for CDMA Network and you want correctly use it on GSM Network than you have to edit the build.prop file to fully enable the GSM and you have to set APNs to use 3g data. This guide and this patch are only for non US users. To fully enable the GSM you must edit the build.prop with correct settings, here a lot of lines that could be edited: Quote:
You can install the patch on every AOSP ROM, on every Stock Rom and on every Android version. Available Version: Patch to enable GSM on Verizon CDMA Android Phones v1.5 How to install the patch:
The patch should work on every Verizon CDMA Phones and it will enable fully the GSM, for now it has been tested and it will most certainly work on these models:
Wbr, bappy Last edited by ..::MOBILEPARK::..; 10-19-2013 at 08:46. | |
The Following 10 Users Say Thank You to ..::MOBILEPARK::.. For This Useful Post: |
11-09-2013, 17:31 | #3 (permalink) |
No Life Poster Join Date: Jul 2009 Location: Ganimedes
Member: 1067814 Status: Offline Sonork: 100.1618982 Thanks Meter: 82 | do you have a root metod for xt912, my phone but it is on mandaring or japanes language. i want do this on english, if it is posible. BR |
12-14-2013, 19:25 | #4 (permalink) |
Freak Poster Join Date: Jan 2010
Member: 1204194 Status: Offline Thanks Meter: 5 | this work for unlock those models and use GSM of any carrier???? Motorola Droid 4 xt894 Motorola Droid Razr xt912 Motorola Droid Razr Maxx xt912 Motorola Droid Razr M xt907 Motorola Droid Razr HD xt926 |
01-17-2014, 08:56 | #8 (permalink) |
Junior Member Join Date: Dec 2013
Member: 2095964 Status: Offline Thanks Meter: 1 | Re: Patch to fully enable GSM on Motorola Verizon CDMA phones As far as I am concerneed I think this is a patch to fully enable GSM on every Stock Rom, on every AOSP Rom and on every Android version. If you have a Verizon Global Phone for CDMA Network and you want correctly use it on GSM Network than you have to edit the build. |
07-26-2014, 03:02 | #15 (permalink) |
Junior Member Join Date: Jul 2008
Member: 809544 Status: Offline Thanks Meter: 3 | i have an LG VS870 4G Verizon, i applied this patch from xda [PATCH][GUIDE] Patch to fully enable GSM on … | Android | XDA Forum but nothing happens and when i dial #*#*4636*#*# nothing happend too, somone can help me ? thnx |
The Following User Says Thank You to azzo112 For This Useful Post: |
