Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help |
09-04-2016, 17:20 | #1 (permalink) |
No Life Poster Join Date: Jan 2016 Location: Pakistan Age: 27
Member: 2511027 Status: Offline Sonork: 100.1662953 Thanks Meter: 1,113 | Moto E No service Solution 5.1 Updated Instrcutions: With the SIM you want to use the the phone : 1. Put the phone into Airplane mode (I'm not sure this is needed, but it doesn't hurt) 2. Go to Settings -> About Phone and tap on "Build Number" until it says you are in Developer Mode (~10 times) 3. Go back one menu, and right above About Phone there should now be an option for Developer Options, go into that. 4. Turn on USB Debugging 5. Connect the phone to your computer and type "adb shell" in your CMD window 6. Run the following commands in adb shell : pm clear com.android.providers.telephony settings put global preferred_network_mode 9 settings put global preferred_network_mode1 9 settings put global preferred_network_mode2 9 7. Turn off Airplane mode 8. Power off and Restart the phone 9. Open up the settings app, go to the mobile networks panel, select "Prefered Network Mode" and change it to "4G" 10. Input the appropriate APNs for your specific carrier |
The Following 6 Users Say Thank You to KAS HIF For This Useful Post: |
09-05-2016, 13:24 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | Its work till you not Restart or Chang Sim asap Phone restart or chang sim you lost Signals |
The Following User Says Thank You to Mohsin-* For This Useful Post: |
