Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Motorola > Motorola Android based
Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help
Old 09-22-2024, 22:33   #16 (permalink)
Member: 1043909
Thanks Meter: 61,444
Originally Posted by Stoyan View Post
Phone totally dead after using official Rescue software, not even Dead Boot Fix Pac works.
Also Wipe Partition does not fix the situation, tried global pac also - nothing.
Any help?
Do you have any info what was firmware ver before flash?
What firmware was used for flashing?
What is with the device now?
Old 09-25-2024, 04:49   #17 (permalink)
Member: 282238
Hello. Same phone, same similar problem, I tried frp with Chimera and it died. I downloaded the .pac file and the other one and brought it back to life, then I tried to make a ubda5e with the original software and it died. It connects with the spd driver without restarting. I redid the entire recovery procedure but without result. Can someone help me bring it back to life? Thank you!
Old 09-28-2024, 19:33   #18 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 8,026
Read this thread - post #5 and #8 has links with working files.
i wasted couple of days, and at the end, had to buy Pandora to revive this crap phone.
Devices with new security ... no easy way to revive, only pandora has updated loaders which dont erase device.
Dont waste time with other tools. There are steps to be done, even with pandora, to make it alive, but it works.
Imei repair/security repair not possible with any tool at the moment. Just revival.
b.r.
Alex
__________________
Always press THANKS button if my post was helpful!
Please DO NOT send me PM's for help, You can ask for help on forum
Do not post THANKS posts - use thanks button !
ALWAYS use SEARCH button before posting!
The Following User Says Thank You to Brka For This Useful Post:
Old 10-22-2024, 06:33   #19 (permalink)
Mr.3.'s Avatar
Member: 962029
Sonork: OEM Lock : ON
Thanks Meter: 4,138
XT2341-4 supported these files ?
Old 10-22-2024, 08:24   #20 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 4,138
i power on the phone with this pac file SHIPPING_LLD35185_TLBS33.78-258-3_0730_SIGNED
but hang on first screen and no fastboot mode
any help team ..thanks
Old 10-25-2024, 14:12   #21 (permalink)
Member: 120579
Thanks Meter: 190
How to write Motorola G14 XT2341-3 using EFT ? Not in the list of supported Cpus and using custom loader I`m unable to select flash, just service.
Originally Posted by byteforce2016 View Post
So I contacted a hungry for money indian on the youtube and now I give the whole procedure for free.
These SPD phones are such rubbish phones so that they can be dead just when the wind b l o ws. But if it happens to you below are the steps to fix it and the file download links.
Old 10-25-2024, 15:21   #22 (permalink)
Member: 120579
Thanks Meter: 190
Exclamation
Originally Posted by Brka View Post
maybe it's wrong system image (super),
you can try with SoftwareFix client and see what will happen ...
select data correctly (recovery), region etc.
b.r.
Alex
SoftwareFix connects using fastboot?
Phone is now stuck in SPD DIag
Old 10-25-2024, 18:21   #23 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 4,138
Mobile recovered, but no imei
Old 10-25-2024, 20:40   #24 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 8,026
If you powered it on with that (very OLD / Android 13 version),
then you are lucky ... you have older version of device.
On that version, even imei can be fixed with Pandora.
Newer version devices, shipped with android 14 ... no such luck.
(ARB fuse enabled, new security, bla bla).
b.r.
Alex
__________________
Old 10-26-2024, 11:03   #25 (permalink)
Member: 120579
Thanks Meter: 190
How did you recover it ?
I managed to write .pac but it gets stuck on blue Motorola logo.
Old 10-26-2024, 17:28   #26 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 4,138
keep press volume down Key till fast boot mode and flash fastboot file
Old 10-26-2024, 17:36   #27 (permalink)
Mr.3.'s Avatar
Member: 962029
Thanks Meter: 4,138
Long press volume down Key and power button till fast boot mode and flash fastboot file
Old 10-27-2024, 13:53   #28 (permalink)
Member: 120579
Thanks Meter: 190
Doesn`t work.
Nest I could do is flash complete dump: phone starts but hangs with Motorla logo
Old 10-27-2024, 22:54   #29 (permalink)
Moderator
Brka's Avatar
Member: 163
Thanks Meter: 8,026
Originally Posted by tintome View Post
Doesn`t work.
lets make this story short :
on dead (erased device),
- it accepts only splloader and splloderbak, so flash them once (1st time)
- after that, write full dump with necessary partitions (which are not present in factory .pac) (no need for super, cache and userdata)
- after that device WILL HAVE fastboot.
- simply flash via fastboot some latest android 13 fastboot rom
or ...
- after 1st and 2nd flash, device is powering on
- simply flash some latest android 13 pac
device will power on.
as i already said ... if on android 13 - imei can be patched with pandora,
and pandora only.
if you can not roll back (or device came from factory with android 14),
there is no fixing imei YET.
b.r.
Alex
__________________
The Following 3 Users Say Thank You to Brka For This Useful Post:
Old 10-29-2024, 17:27   #30 (permalink)
Member: 120579
Thanks Meter: 190
Red face
Unable to write splloader_bak.bin
FLASH Selected Platform : Tiger T616_64_2_Bypass
Connect Testpoint or hold VOL DOWN! Instruction here!
Waiting for device... COM177 (SPRD U2S Diag)
USB : USB\VID_1782&PID_4D00\6&1DDC1F8E&2&2
Initializing loader... OK
Protocol : SPRD3
Sending payload... OK
Sending auth data... OK
Sending preloader1... OK
Sending preloader2... OK
Booting loader, please wait... OK
Boot ver: Spreadtrum Boot Block version 1.1
Sending FDL1... OK
Sending FDL2... OK
Reading Serial Number... N.A
Reading partitions info... OK [71] [8192]
Reading device info... SKIP [EROFS]
Writing splloader.bin [4 MiB] -> splloader [4 MiB]... OK
Writing splloader_bak.bin [4 MiB] -> splloader_bak [4 MiB]... FAIL
[0x8A] Download size error!
UNLOCKTOOL 2024.10.24.0
Elapsed time : 28 seconds
After this, i tried flashing full dump
FLASH Writing avbmeta_rs_a.bin [1 MiB] -> avbmeta_rs_a [1 MiB]... OK
Writing avbmeta_rs_b.bin [1 MiB] -> avbmeta_rs_b [1 MiB]... OK
Writing blackbox.bin [500 MiB] -> blackbox [500 MiB]... OK
Writing boot_a.bin [64 MiB] -> boot_a [64 MiB]... OK
Writing boot_b.bin [64 MiB] -> boot_b [64 MiB]... OK
Writing cache.bin [64 MiB] -> cache [64 MiB]... OK
Writing common_rs1_a.bin [8 MiB] -> common_rs1_a [8 MiB]... OK
Writing common_rs1_b.bin [8 MiB] -> common_rs1_b [8 MiB]... OK
Writing common_rs2_a.bin [16 MiB] -> common_rs2_a [16 MiB]... OK
Writing common_rs2_b.bin [16 MiB] -> common_rs2_b [16 MiB]... OK
Writing dtbo_a.bin [8 MiB] -> dtbo_a [8 MiB]... OK
Writing dtbo_b.bin [8 MiB] -> dtbo_b [8 MiB]... OK
Writing dtb_a.bin [8 MiB] -> dtb_a [8 MiB]... OK
Writing dtb_b.bin [8 MiB] -> dtb_b [8 MiB]... OK
Writing elabel.bin [20 MiB] -> elabel [20 MiB]... OK
Writing fbootlogo.bin [8 MiB] -> fbootlogo [8 MiB]... OK
Writing hypervsior_a.bin [10 MiB] -> hypervsior_a [10 MiB]... OK
Writing hypervsior_b.bin [10 MiB] -> hypervsior_b [10 MiB]... OK
Writing init_boot_a.bin [8 MiB] -> init_boot_a [8 MiB]... OK
Writing init_boot_b.bin [8 MiB] -> init_boot_b [8 MiB]... OK
Writing logo.bin [8 MiB] -> logo [8 MiB]... OK
Writing l_agdsp_a.bin [6 MiB] -> l_agdsp_a [6 MiB]... OK
Writing l_agdsp_b.bin [6 MiB] -> l_agdsp_b [6 MiB]... OK
Writing l_deltanv_a.bin [1 MiB] -> l_deltanv_a [1 MiB]... OK
Writing l_deltanv_b.bin [1 MiB] -> l_deltanv_b [1 MiB]... OK
Writing l_fixnv1_a.bin [1 MiB] -> l_fixnv1_a [1 MiB]... OK
Writing l_fixnv1_b.bin [854.03 KiB] -> l_fixnv1_b [854.03 KiB]... OK
Writing l_fixnv2_a.bin [1 MiB] -> l_fixnv2_a [1 MiB]... OK
Writing l_gdsp_a.bin [10 MiB] -> l_gdsp_a [10 MiB]... OK
Writing l_gdsp_b.bin [10 MiB] -> l_gdsp_b [10 MiB]... OK
Writing l_ldsp_a.bin [20 MiB] -> l_ldsp_a [20 MiB]... OK
Writing l_ldsp_b.bin [20 MiB] -> l_ldsp_b [20 MiB]... OK
Writing l_modem_a.bin [25 MiB] -> l_modem_a [25 MiB]... OK
Writing l_modem_b.bin [25 MiB] -> l_modem_b [25 MiB]... OK
Writing l_runtimenv1.bin [1.13 MiB] -> l_runtimenv1 [1.13 MiB]... OK
Writing l_runtimenv2.bin [1.13 MiB] -> l_runtimenv2 [1.13 MiB]... OK
Writing metadata.bin [64 MiB] -> metadata [64 MiB]... OK
Writing misc.bin [1 MiB] -> misc [1 MiB]... OK
Writing miscdata.bin [1 MiB] -> miscdata [1 MiB]... OK
Writing persist.bin [2 MiB] -> persist [2 MiB]... OK
Writing pgpt.bin [5.2 KiB] -> pgpt [5.2 KiB]... FAIL
Writing phone_info.txt [547 bytes] -> phone_info [547 bytes]... FAIL
Writing pm_sys_a.bin [1 MiB] -> pm_sys_a [1 MiB]... OK
Writing pm_sys_b.bin [1 MiB] -> pm_sys_b [1 MiB]... OK
Writing prodnv.bin [64 MiB] -> prodnv [64 MiB]... OK
Writing sml_a.bin [1 MiB] -> sml_a [1 MiB]... OK
Writing sml_b.bin [1 MiB] -> sml_b [1 MiB]... OK
Writing sysdumpdb.bin [10 MiB] -> sysdumpdb [10 MiB]... OK
Writing teecfg_a.bin [1 MiB] -> teecfg_a [1 MiB]... OK
Writing teecfg_b.bin [1 MiB] -> teecfg_b [1 MiB]... OK
Writing trustos_a.bin [6 MiB] -> trustos_a [6 MiB]... OK
Writing trustos_b.bin [6 MiB] -> trustos_b [6 MiB]... OK
Writing uboot_a.bin [3 MiB] -> uboot_a [3 MiB]... OK
Writing uboot_b.bin [3 MiB] -> uboot_b [3 MiB]... OK
Writing uboot_log.bin [16 MiB] -> uboot_log [16 MiB]... OK
Writing vbmeta_a.bin [1 MiB] -> vbmeta_a [1 MiB]... OK
Writing vbmeta_b.bin [1 MiB] -> vbmeta_b [1 MiB]... OK
Writing vbmeta_odm_a.bin [1 MiB] -> vbmeta_odm_a [1 MiB]... OK
Writing vbmeta_odm_b.bin [1 MiB] -> vbmeta_odm_b [1 MiB]... OK
Writing vbmeta_product_a.bin [1 MiB] -> vbmeta_product_a [1 MiB]... OK
Writing vbmeta_product_b.bin [1 MiB] -> vbmeta_product_b [1 MiB]... OK
Writing vbmeta_system_a.bin [1 MiB] -> vbmeta_system_a [1 MiB]... OK
Writing vbmeta_system_b.bin [1 MiB] -> vbmeta_system_b [1 MiB]... OK
Writing vbmeta_system_ext_a.bin [1 MiB] -> vbmeta_system_ext_a [1 MiB]... OK
Writing vbmeta_system_ext_b.bin [1 MiB] -> vbmeta_system_ext_b [1 MiB]... OK
Writing vbmeta_vendor_a.bin [1 MiB] -> vbmeta_vendor_a [1 MiB]... OK
Writing vbmeta_vendor_b.bin [1 MiB] -> vbmeta_vendor_b [1 MiB]... OK
Writing vendor_boot_a.bin [100 MiB] -> vendor_boot_a [100 MiB]... OK
Writing vendor_boot_b.bin [100 MiB] -> vendor_boot_b [100 MiB]... OK
Total files : 71
Total size : 1.34 GiB
Elapsed time : 1 minute 11 seconds
Page generated in 0.24039 seconds with 9 queries
