Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help |
03-15-2017, 11:09 | #1 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Earth
Member: 1766494 Status: Offline Sonork: 100.1649672 Thanks Meter: 325 | Motorol XT1096 FRP Unlock My Tested Solution (thx to SMflasher) Turn ON Phone Follow These On Activation Screen *Start *Use WIFI (Select WIFI) *Privacy Settings *View Motorola Privacy Policy *Click on Any link (in blue ) *Select any text there (long press for 3 secs) *then you would see search icon on up Right Corner (Click on it) *Type Chrome there & open Chrome app *Download ES File Explorer APK & install (to install go back to search & type Downloads u will find downloaded apk there) *After Installation Completed Type ES file in Search & Open ES File Explorer *Plug OTG Drive with ROOT APK & Terminal Emulator apk *Install Terminal Emulator First then Root File apk *Root with Above root file (press on get root & choose method 1) (Mount & unmount usb storage ) *then open Terminal emulator type below command Code: su content insert --uri content://settings/secure --bind name:s:user_setup_complete --bind value:s:1 Waaaaah Done !!! you can Try above solution on Motorola XT1097 XT1528 (Not tested ) PRESS THANKS BUTTON IF SUCCESS (Dont Post thanks) Last edited by .::TEAM CCS::.; 03-15-2017 at 11:10. Reason: Press Thanks button If Success |
The Following 7 Users Say Thank You to .::TEAM CCS::. For This Useful Post: |
03-15-2017, 12:17 | #2 (permalink) |
Freak Poster Join Date: Mar 2008 Location: pakistan
Member: 730479 Status: Offline Sonork: [email protected] Thanks Meter: 24 | Thumbs up Motorol XT1096 FRP Unlock My Tested Solution First Download Terminal Emulator APK & Root File APK to Computer & Put in a OTG Drive (thx to SMflasher) Turn ON Phone Follow These On Activation Screen *Start *Use WIFI (Select WIFI) *Privacy Settings *View Motorola Privacy Policy *Click on Any link (in blue ) *Select any text there (long press for 3 secs) *then you would see search icon on up Right Corner (Click on it) *Type Chrome there & open Chrome app *Download ES File Explorer APK & install (to install go back to search & type Downloads u will find downloaded apk there) *After Installation Completed Type ES file in Search & Open ES File Explorer *Plug OTG Drive with ROOT APK & Terminal Emulator apk *Install Terminal Emulator First then Root File apk *Root with Above root file (press on get root & choose method 1) (Mount & unmount usb storage ) *then open Terminal emulator type below command Code: su content insert --uri content://settings/secure --bind name:s:user_setup_complete --bind value:s:1 After that go to settings> Developer> Unlock Oem>MAke FActory Reset Waaaaah Done !!! you can Try above solution on Motorola XT1097 XT1528 (Not tested ) PRESS THANKS BUTTON IF SUCCESS (Dont Post thanks) |
05-28-2017, 07:25 | #6 (permalink) | |
No Life Poster Join Date: May 2009
Member: 1024748 Status: Offline Thanks Meter: 53 | Quote:
bro apk file not found in your link . file no longer available | |
06-02-2017, 12:29 | #11 (permalink) | |
Member: 1766494 Status: Offline Sonork: 100.1649672 Thanks Meter: 325 | Quote:
06-04-2017, 06:13 | #13 (permalink) | |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Quote:
G350E_G350EXXU0ANF8.zip need XT1096 root file please | |
06-04-2017, 12:33 | #14 (permalink) | |
Correct Root File APK new DOWNLOAD NOW | |
