Motorola Android based General Motorola Android phones discussion, firmwares, solution, root, help |
08-24-2016, 01:49 | #1 (permalink) |
Crazy Poster Join Date: Apr 2014
Member: 2165256 Status: Offline Thanks Meter: 0 | MOTO E XT1527 ATT frp problem |
08-24-2016, 03:47 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | FRP Motorolas with the new security patch dated March 1, 2016! 1. Turn on the phone and connect to Wifi, get to the point where we ask the google account, display the keyboard and let down the "@" Select "Google Keyboard Settings" then "Spelling" followed by "Personal dictionary" "For all languages" 2. On the next screen we press the + icon that appears above, we will see a space where we can write, you type anything and then we pressed on it to select it, we a submenu where you choose "Share" appears and then choose how to share via text message. 3. We send the messages application, and with the selected word, what we will do is send that text message to the number 112 Hara as the sender, and then send us to the screen dialpad. 4. On that screen delete 112 and type out * # * # 4636 # * # * 5. We sent a menu called "Testing" we enter "Usage Statistics" and came back with the back arrow appears at the top! (Not in the lower keys) In this way we sent to the General Settings menu. (As you will see if we will About phone to try to activate the developer options, it is not possible for us, because when you press on "build number" nothing happens, because with the new security patch, eliminated that option until you have added a Google account.) 6. We enter the section "GOOGLE" then "Search and Now", "Now cards" and then we click on "Show cards" so we activate the option. We now have access to Google search menu, type in Chrome and open the application. 7. Already in the browser look for ways to lower a launcher as "Nova Launcher" either looking the apk, or downloading Aptoide. 8. also downloaded an application called "MultiWindow" both this app as Nova are in Aptoide. 9. When we installed Nova Launcher we can now access the application icons, but yet we can not use the PlayStore that asks us again that we have. Well, so far we have only Byppas, follow the video and you will achieve the frp. It is in Spanish but just follow the images. https://www.youtube.com/watch?v=JGb2xZspSnc |
The Following User Says Thank You to gcceleghg For This Useful Post: |
09-02-2016, 12:09 | #8 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | ByPass ok 100% but it cant full reset because in the last part, Test dpc shows one alternative. Someone knows any news about security April 2016???? https://www.youtube.com/watch?v=J1pyFsRBmOo Regards! |
09-06-2016, 15:49 | #9 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Possible solution Root the phone with kingo root and run terminal emulator and root access and run a command: command: 1st command: su 2nd command: insert content --uri content: // settings / secure --bind name: s: user_setup_complete --bind value: s: 1 |
09-10-2016, 00:57 | #10 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | By Pass / FRP xt1527 AT & T version 5.1 This model of AT & T version 5.1 does not allow unlock bootloader It not allowed to also upload version 6.0 for retail and still has not left the AT & T version. Test the app does not work for this security dpc because it gives the option of encryption as Owner. ByPass: 1. Playing in email and keep pressed the @ until a menu of options. 2. keyboard settings Google 3. orthographic / staff / Dictionary correction for all languages 4. On the next screen tap the magnifying glass and press the letter "c". Several options were deployed and there Google Pinyin Input to choose. On the next screen we chose the same option. 5. Then choose "about" Open Source Licenses yluego 6. On the next screen may maintain finger pressing and the option will appear "Share" to choose "messages" lugo typing 112 and send. At that time the call keyboard appears delete 112 and type * # * # 4636 # * # * 7. On the next screen you can choose info or battery usage statistics. 8. Then go to back with the arrow on the top left 9. ByPass done. 10. Here you can not enable the developer and we can not restore option. It's just bypass Process FRP You have to walk down four aplcaciones Aptoide It is Fike Explorer Kingo Root terminal Emulator The accecibilidad this phone is very poor so that the process is as follows: 1. In the menu go to Usode data / You Tube / Application Settings / About 2. We chose Google Privacy Policy 3. Open Google Chrome and from there bajammos each of the applications. We do not open. 4. Then return to the phone menu with the option "back" 5. We will install the Storage and File Explorer is then opened. 6. From the File Explorer is installed the other applications 7. Open Aptoide and install the Nova Launcher, open and see the phone menu 8. Execute Kingo Root and Root hope to tell us Done 9. Let couple back and look for the Terminal Emulator, we enter and type "SU" to give us the option root access or # 10. Write in the amulador the following command: content insert --uri content: // settings / secure --bind name: s: user_setup_complete --bind value: s: 1 11. After going to back out, we enable developer and OEM Unlock. Let's accounts. We begin with an account and delete the phone. Note: You can add the app Multi Windows that offers a fast accessibility when the process fails and ne have to do all the ByPass again but I have found that failure. He also clarified that does not always go in the first time is because the root with Kingo Root maybe you have to do many sometimes. I hope you serve the process. With Sigma Box: - The new patch lets not share secure - What you have to do is plug in tools bp way as if they were to release sigma because I is properly installed - Open platform tools and take the command window with shift and right click and write adb devices - Check on the phone screen - Asked the footprint and when they put haceptan and the second command and reboot - It starts without account. |
09-10-2016, 18:17 | #11 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | Quote:
09-10-2016, 20:41 | #13 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Clarification!!! In point 11: 11. After going to back out, we enable developer and OEM Unlock. Let's accounts. Put an own account and delete the phone. Not delete before. The first thing you will note is that the "reset" is already in bold. (Do not) because the re start has asked again. If you can not enable developer it does not matter. It will enter their own account from google that are going to be able to do and then if you proceed to delete or restore from their own. Re starts, they put your account again, enable OEM and Depuracion and reestablish again. The phone dont ask account again!!!! Then the phone no longer require any account to re start. It is not easy and you have to make the root more than once. |
09-11-2016, 05:40 | #14 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | You have right, more clear here: Moto E 2nd Gen XT1527 FRP By Pass Google but… | Motorola Moto E |
09-24-2016, 16:59 | #15 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Republica Dominicana Age: 40
Member: 381487 Status: Offline Sonork: 100.1659930 Thanks Meter: 161 | I have a xt1527 that I could in no way be able to root, much less remove frp. kingo root, kingroot any of this have to do root. any suggestions? |
