Urgent - "CQATest" App Causing HUGE Problems on Urgent - "CQATest" App Causing HUGE Problems on moto g4 plus battery charging only 6 percent network no service pls help |
I have the same problem, I already tried hard reset, disable app, wipe cache, but nothing solved. Does anyone have the solution? |
I notice the app shows when you boot in a certain mode. Usually factory mode. Enter different bootloader modes may work just a suggestion Sent from my SM-G928T using Tapatalk |
I've got that CQATest app too after FRP removal, with no signal. You can make it work temporarily by selecting BPTools in the bootloader menu, but every time you restart, it comes back. After reflashing it with full factory firmware using RDS Lite, the test app went away and the signal came back permanantly. :) |
Here you got solution really so hard is read few topics older than open new one? No need flash anything just simple few steps. http://forum.gsmhosting.com/vbb/f783...orted-2505722/ |
Look I appreciate for pointing out that solution, but there's no need to be an ahole about it. Rest assured if I would have seen, then I wouldn't have posted about it... that's all. Have a nice day. |
