Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Windows & MeaMo/MeeGo based
Nokia Windows & MeaMo/MeeGo based N900,N9,N950,700,710,N800,800,920,925 etc all linux and WP phones flashing & unlocking only here
Old 05-08-2011, 16:41   #1 (permalink)
Member: 303488
Thanks Meter: 208
Lightbulb Nokia n900 no imei after flash, how to solve?
pls help---------------------------------------------------
Old 05-08-2011, 17:59   #2 (permalink)
Member: 567446
Thanks Meter: 5
Originally Posted by aseer1 View Post
nokia n900 no imei after flash, how to solve?
Pls help---------------------------------------------------
try to flash the lastest file , imei not gone :d
Old 06-05-2011, 11:55   #3 (permalink)
Member: 1522831
Sonork: 1603358
Thanks Meter: 28
Nokia N900 after flash IMEI......................
1. tablets-dev.nokia.com restricted downloads
2. Download PR 1.2 and eMMC content. You’ll need your IMEI
Click tablets-dev.nokia.com restricted downloads
RX-51_2009SE_10.2010.13-2.VANILLA_PR_EMMC_MR0_ARM.bin
RX-51_2009SE_10.2010.19-1_PR_COMBINED_MR0_ARM.bin << Global Release (Will vary depending on which one you download)
3. Move both .bin files to C:\Program Files\maemo\flasher-3.5
4. Turn off N900. Connect MicroUSB cable but not N900. Whilst holding “U” on N900′s keyboard, attach to MicroUSB.
The Nokia logo will appear and a USB icon in top right corner. Do not at any point disconnect the cable or restart N900 until step 9.
5. On the PC, click Start>Run>CMD. You’ll see a black box appear.
6. Type or copy and paste
cd\program files\maemo\flasher-3.5
7. Type of copy and paste PR1.2
flasher-3.5 -F RX-51_2009SE_10.2010.19-1_PR_COMBINED_MR0_ARM.bin -f
note, the file name will differ slightly with each PR1.2 regional variant. The above is for global version.
Leave it for a couple of minutes whilst it flashes your N900 with PR1.2.
Wait until it says “CMT Flashed successfully”.
8. Now copy and paste
flasher-3.5 -FRX-51_2009SE_10.2010.13-2.VANILLA_PR_EMMC_MR0_ARM.bin -f -R
Wait for it to finish it’s thing.
You’ll know it’s finished when it says
“Flashed successfully…..”
N900 will attempt to restart.
9. If N900 hasn’t already restarted, restart it manually. Congratulations, you are now on PR1.2 / Have hard reset N900.
The Following 4 Users Say Thank You to shah.meer7879 For This Useful Post:
Old 06-05-2011, 12:08   #4 (permalink)
azeem781986's Avatar
Member: 503161
Sonork: 100.1584069
Thanks Meter: 474
Thank for help information
br
Old 10-24-2011, 23:15   #5 (permalink)
Member: 293419
Thanks Meter: 29
WORKING 100% WITH THIS FLASH
RX-51_2009SE_10.2010.19-1.003_PR_COMBINED_003_ARM.BIN
HERE LOG
C:\Archivos de programa\maemo\flasher-3.5>flasher-3.5 -F RX-51_2009SE_10.2010.19
-1.003_PR_COMBINED_003_ARM.BIN -f -R
flasher v2.5.2 (Sep 24 2009)
SW version in image: RX-51_2009SE_10.2010.19-1.003_PR_003
Image 'kernel', size 1705 kB
Version 2.6.28-20101501+0m5
Image 'rootfs', size 173696 kB
Version RX-51_2009SE_10.2010.19-1.003_PR_003
Image 'cmt-2nd', size 81408 bytes
Version BB5_09.36
Image 'cmt-algo', size 519808 bytes
Version BB5_09.36
Image 'cmt-mcusw', size 5826 kB
Version rx51_ICPR82_10w08
Image '2nd', size 14720 bytes
Valid for RX-51: 2217, 2218, 2219, 2220, 2120
Version 1.4.14.8+0m5
Image 'xloader', size 14848 bytes
Image 'secondary', size 109440 bytes
Valid for RX-51: 2101, 2102, 2103
Image '2nd', size 14848 bytes
Valid for RX-51: 2307, 2308, 2309, 2310
Valid for RX-51: 2407, 2408, 2409, 2410
Valid for RX-51: 2301, 2302, 2303, 2304, 2305, 2306
Valid for RX-51: 2401, 2402, 2403, 2404, 2405, 2406
Valid for RX-51: 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2112, 2
113, 2114, 2115, 2116, 2117, 2118, 2119
Valid for RX-51: 2501, 2502, 2503, 2504, 2505, 2506
Valid for RX-51: 2607, 2608, 2609, 2610
Valid for RX-51: 2507, 2508, 2509, 2510
Valid for RX-51: 2201, 2202, 2203, 2204, 2205, 2206, 2207, 2208, 2209, 2
210, 2211, 2212, 2213, 2214, 2215, 2216
Valid for RX-51: 2601, 2602, 2603, 2604, 2605, 2606
Suitable USB device not found, waiting.
USB device found found at bus bus-0, device address \\.\libusb0-0001--0x0421-0x0
105.
Found device RX-51, hardware revision 2101
NOLO version 1.4.14
Version of 'sw-release': RX-51_2009SE_3.2010.02-8.002_PR_002
Sending xloader image (14 kB)...
100% (14 of 0 kB, avg. 14 kB/s)
Sending secondary image (106 kB)...
100% (106 of 0 kB, avg. 106 kB/s)
Flashing bootloader... done.
Sending cmt-2nd image (79 kB)...
100% (79 of 0 kB, avg. 79 kB/s)
Sending cmt-algo image (507 kB)...
100% (507 of 0 kB, avg. 507 kB/s)
Sending cmt-mcusw image (5826 kB)...
100% (5826 of 0 kB, avg. 5826 kB/s)
Flashing cmt-mcusw... done.
Sending kernel image (1705 kB)...
100% (1705 of 0 kB, avg. 1705 kB/s)
Flashing kernel... done.
Sending and flashing rootfs image (173696 kB)...
100% (173696 of 0 kB, avg. 173696 kB/s)
Finishing flashing... done
CMT flashed successfully
Old 04-27-2012, 08:57   #6 (permalink)
Member: 397862
Thanks Meter: 176
sir how 2 flesh this this phone plz explain about this....................thanks
Old 06-02-2012, 09:54   #7 (permalink)
robba's Avatar
Member: 16275
Thanks Meter: 10
i have flashed both EMMC and rootfs and i still dont have IMEI on my N900
I
C:\Program Files\maemo\flasher-3.5>flasher-3.5 -F RX-51_2009SE_10.2010.13-2.VANI
Image 'mmc', size 255947 kB
        Version RX-51_2009SE_10.2010.13-2.VANILLA
105.
NOLO version 1.4.14
Version of 'sw-release': RX-51_2009SE_21.2011.38-1.003_PR_003
Booting device into flash mode.
1c8.
Raw data transfer EP found at EP2.
Image(s) flashed successfully in 37.187 s (6882 kB/s)!
C:\Program Files\maemo\flasher-3.5>flasher-3.5 -F RX-51_2009SE_21.2011.38-1.003_
PR_COMBINED_003_ARM.bin -f
SW version in image: RX-51_2009SE_21.2011.38-1.003_PR_003
        Version 2.6.28-20103103+0m5
Image 'rootfs', size 185856 kB
        Version RX-51_2009SE_21.2011.38-1.003_PR_003
        Version BB5_09.36
        Version BB5_09.36
        Version 1.4.14.9+0m5
105.
NOLO version 1.4.14
Sending and flashing rootfs image (185856 kB)...
100% (185856 of 0 kB, avg. 185856 kB/s)
Old 06-10-2012, 13:40   #8 (permalink)
Member: 204105
Thanks Meter: 3
Whenever am trying to flash am getting this error and flashing gets failed
( Sending cmt-mcusw image (5826 kB)...
Flashing cmt-mcusw... Sending request 0x50 failed: No error )
SW version in image: RX-51_2009SE_10.2010.19-1.004_PR_004
Image 'rootfs', size 173440 kB
Version RX-51_2009SE_10.2010.19-1.004_PR_004
Version BB5_09.36
Version BB5_09.36
105.
Found device RX-51, hardware revision 2204
NOLO version 1.4.14
Version of 'sw-release': RX-51_2009SE_21.2011.38-1.004_PR_004
Old 06-11-2012, 07:52   #9 (permalink)
Member: 1719618
Sonork: no id
Thanks Meter: 5
Cool bro downgrade the version
i have same problem with n900 and i downgrade the version it works
Old 06-11-2012, 09:35   #10 (permalink)
sahilfency's Avatar
Member: 1212231
Sonork: 100.1611130
Thanks Meter: 164
flesh with infinity best 100% solved
Old 08-20-2012, 10:17   #11 (permalink)
IM8
Member: 694535
Thanks Meter: 70
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Program Files\maemo\flasher-3.5>flasher-3.5 -F RX-51_2009SE_10.2010.19-1_PR_C
SW version in image: RX-51_2009SE_10.2010.19-1_PR_MR0
Image 'rootfs', size 173568 kB
Version RX-51_2009SE_10.2010.19-1_PR_MR0
Version BB5_09.36
Version BB5_09.36
105.
NOLO version 1.4.14
Version of 'sw-release': RX-51_2009SE_21.2011.38-1_PR_MR0
Sending and flashing rootfs image (173568 kB)...
100% (173568 of 0 kB, avg. 173568 kB/s)
CMT flashing failed
C:\Program Files\maemo\flasher-3.5>flasher-3.5 -FRX-51_2009SE_10.2010.13-2.VANIL
105.
NOLO version 1.4.14
Version of 'sw-release': RX-51_2009SE_10.2010.19-1_PR_MR0
1c8.
[init 20 % 32768 / 255947 kB 9362 kB/s]
any solution ?
Old 08-22-2012, 15:49   #12 (permalink)
robba's Avatar
Member: 16275
Thanks Meter: 10
use service pack 3 but if you still have problems use windows 7
Old 10-06-2012, 12:41   #13 (permalink)
Member: 974285
Thanks Meter: 4
Thanks its works 100%
Old 12-25-2012, 09:31   #14 (permalink)
Member: 1833113
Sonork: 100.1623537
Thanks Meter: 40
it worked thnx 100%.............................tested
The Following User Says Thank You to mobileplazza For This Useful Post:
Old 02-06-2013, 06:48   #15 (permalink)
binshad's Avatar
Member: 1297123
Sonork: 100.1609506
Thanks Meter: 11
brother pls download firmware files that suite your product code from Nokia Firmwares
and try flash with infinity dont forget to erase all ( tick on all fileds root,emmc...etc). if its doesnt recover your imei try from old firmwares one by one. (50% ) it will recover your imei..
or flash n900 emmc first using linux or mac system or windows7...
there are sevral issues to flash emmc of n900 in windows that happened bcoz of driver issue.. its solved if you use linux or mac..
try to flash emmc with old firmwares it will restore the imei if you have luck. or if you know its factory made firmware version not new means bought handset on 2009 and in 2010 its updated to new... u have to flash it with 2009 firmware hope you got what i mean...
and if you guys have no problems with imei always flash it using latest firmwares. downgrades brick your phone.....
infinty is the best dongle for flash n900 and hence mxkey.......
if none of this works private message me... i will help you with my little knowledge....
Page generated in 0.40457 seconds with 10 queries
