I have entered 10 times, now phone want's PUK. I enter 0000000000, but phone says incorrect. |
Tried with different SIM card and everything is OK ! Thanks !!!! |
just a little help should be I have: ATF, Cyclone, MT... And now bought NSS Annual subcribtion. I can do it or not? Just a short answer, and ask for directions. (I know there is solution to unlock the bootloader) Lumia 800: Init connection...Already in the correct mode. Enter bootloader mode...Done Boot version: 240.116.132.78 Sending certificate...Done. Sending file...Failed(err: 0x30047). ------------------------------------------ Restart and exit flash mode...Done. |
Can this unlock Nokia Lumia 900 at&t network, wish to unlock for gsm networks in UK can this software do it or can anyone send me in the cheapest direction to carry out the unlock, thank you. |
no success in unlock still says Looking for Nand disk ...not found! even with manual restart to OSBL :confused: could anybody share how they unlock their 710 successfully? |
how dumb of me forgot to run as administrator unlock success!! |
any one have unlock the lumia 800? i have 1 in ands with locked bootloader any one have the files for unlock the boot? best regards |
i also hava lumia 800 with locked bootloader. but no solution till now |
Probably those were available for download from Nokia, just nobody knew to download and back them up. So Nokia coders found they mistake and pulled off the files(or replace with correct silently). This is how the 710 loader was found by some Russian guy who just happen to download all and make proper backups. Also those files for sure are on some PC as many 800s came with Qcom loader from the factory. Just need the correct guy to decide to share. BR |
When I try to unlock Lumia 800 I got error: Code: Init connection...Already in the correct mode. |
b.r lieren |
Same here using activated version of NSS 0.51.2 Preparing update...Done. ------------------------------------------ Init connection...Done Enter flash mode...Done Enter bootloader mode...Done Boot version: 240.116.132.78 Sending certificate...Done. Sending file...Failed(err: 0x30047). ------------------------------------------ Restart and exit flash mode...Done. ------------------------------------------ |
I realize it's already been stated this doesn't work with the N900 yet, but I'm not looking to SIM unlock. The brother of a friend of mine passed away and his device is security/pin locked to get into the device. His parents are trying to save his pictures/text messages etc and the default 12345 doesn't work nor any other guesses they could make. Can this tool do that or can someone recommend another method to do this? |
