Go Back   GSM-Forum > Non GSM/Mobile Related Forums > CAR Electronics > Dashboard
Dashboard Servicing all digital dashboards
Old 05-17-2023, 14:43   #16 (permalink)
Member: 3038294
No brother the alphardsele file is the one i saved before editing as i told you earlier i saved the 8 bit file which is alphardsele without editing, later when i saw the problem of blinking i reprogrammed the eprom back with the 8bit dump and read the eprom with 16bit which i saved as alphardfile2.
Old 05-17-2023, 16:33   #17 (permalink)
Moderator
shooting@orange's Avatar
Member: 469145
Thanks Meter: 5,153
Originally Posted by Farooqmohammed View Post
I have sent u image and the file i had saved without editing
92149km
And brother does wrong bit editing make rev counter not to work?
Try this 16bit dump, it's same cluster but read correctly .. pass in PM
(Dump Edited with you desired Km)
wbr
File Type: rar 93C56-16bit 52496km.rar (361 Bytes, 1 views)
__________________
Do NOT pm me for code, use the forum like everyone else
Old 05-17-2023, 22:22   #18 (permalink)
Member: 3038294
Brother its still blinking and it reads 69835km, have sent u the pic, what does cause the odo to blink?
File Type: jpg 20230518_001849.jpg (157 Bytes, 8 views)
Old 05-18-2023, 06:32   #19 (permalink)
Moderator
Member: 469145
Thanks Meter: 5,153
Blinking shows corrupt data.
Because you wrote to it you don't have a correct original
I suggest it now needs to go to a specialist for repair.
wbr
__________________
Old 05-18-2023, 09:33   #20 (permalink)
Member: 3038294
wbr
Ok ket me try to get the original and will let you now bro
Old 05-18-2023, 09:50   #21 (permalink)
Moderator
Member: 469145
Thanks Meter: 5,153
If you wrote to the chip then there is no way to get your original
wbr
__________________
Old 05-18-2023, 14:41   #22 (permalink)
Member: 3038294
wbr
What if i get another alphard same year and copy dump from its cluster and redo this one?
Old 05-18-2023, 15:47   #23 (permalink)
Moderator
Member: 469145
Thanks Meter: 5,153
Has to be exact numbers etc., but yes it's possible.
The file I sent you was from the exact car and it didn't work,
but maybe the numbers weren't the same
wbr
__________________
Old 05-18-2023, 17:24   #24 (permalink)
Member: 3038294
wbr
I checked something the mileage code which you edited its fir alphard but it read 69xxxkm, when i tried to use hilux 2006 mileage code it reads 52xxxkm,
Old 05-19-2023, 06:41   #25 (permalink)
Moderator
Member: 469145
Thanks Meter: 5,153
It's problem with byte-swap, this is why you need original dump
wbr
__________________
Page generated in 0.19377 seconds with 9 queries
