Go Back   GSM-Forum > Non GSM/Mobile Related Forums > CAR Electronics > Dashboard
Dashboard Servicing all digital dashboards
Old 12-20-2015, 18:51   #1 (permalink)
mobilelatham's Avatar
Member: 306991
Thanks Meter: 62
Audi A4 b8.5 2013 facelift mileage correction
Does anybody know how to change mileage
Is it by dump??
I have digiprog3 and it does >2012 ok but this is facelift car
Thank you for your reply
Sent from my iPhone using Tapatalk
Old 12-20-2015, 19:05   #2 (permalink)
teerak2uk's Avatar
Member: 24791
Thanks Meter: 35
Is it by dump??
If digi don't work then either
Smok
Or
Smelecom are your next options but not cheap options
Or pay someone to do it that has good kit
Old 12-20-2015, 19:08   #3 (permalink)
Member: 306991
Thanks Meter: 62
Thank you so much
Old 12-30-2015, 09:46   #4 (permalink)
Member: 2165331
Avdi or fvdi can do by OBD
Old 12-31-2015, 07:08   #5 (permalink)
Member: 2489020
Thanks Meter: 2
Is it by dump??
You can try with digimaster 3
Old 01-02-2018, 20:34   #6 (permalink)
Member: 2795242
Hello there, I managed to correct the mileage of a 2014 Audi A4. I’m newby on this, so I was wondering: does Digiprog 3 corrects the mileage on all the “modules” (odometer, EPROM?,etc.? Or doni need to do something else in order to completely correct the mileage of the car? I know some cars store mileage in several modules/places, I just don’t know if Audi works this way too, and if Digiprog is capable of doing this via the OBD port.
Thanks in advance!
Old 01-02-2018, 20:45   #7 (permalink)
teerak2uk's Avatar
Member: 24791
Thanks Meter: 35
Originally Posted by navifs View Post
Hello there, I managed to correct the mileage of a 2014 Audi A4. Iím newby on this, so I was wondering: does Digiprog 3 corrects the mileage on all the ďmodulesĒ (odometer, EPROM?,etc.? Or doni need to do something else in order to completely correct the mileage of the car? I know some cars store mileage in several modules/places, I just donít know if Audi works this way too, and if Digiprog is capable of doing this via the OBD port.
Thanks in advance!
In a few places and digiprog wont do them use vcds or odis and it will tell you where km is located
The Following User Says Thank You to teerak2uk For This Useful Post:
Old 01-02-2018, 22:18   #8 (permalink)
Member: 2795242
Thank you very much I will try to find out how.
Hello again buddy, will VAGCOM 12.12 work for this matter? Thanks in advance
Old 01-02-2018, 23:22   #9 (permalink)
Member: 2795242
Sorry, meant to say:
Vagcom 12.12 cable
Vag tacho usb 3.01 cable
Vas 5054a - ODIS cable
Cheers
Old 01-08-2018, 19:31   #10 (permalink)
RRRRR's Avatar
Member: 88823
Thanks Meter: 26
Thanks in advance!
You need AVDI
Old 01-09-2018, 06:32   #11 (permalink)
Member: 2795242
Originally Posted by RRRRR View Post
You need AVDI
Hello! Thanks for replying. I run a full scan with VCDS (vagcom) and it shows no errors and the new mileage I corrected with Digiprog. Some people tell me the mileage showed on VCDS scan is the ECU mileage, so if thatís true then it means Digiprog already corrected mileage in th ECU, is this correct?
Thanks in advance.
Cheers
Old 01-10-2018, 18:30   #12 (permalink)
RRRRR's Avatar
Member: 88823
Thanks Meter: 26
Thanks in advance.
Cheers
open APPLICATION on VCDS and there is edc15-16 millage read button
millage can be in immo, ecu, abs srs, light module, gearbox module ...... etc
if your car is 2008 and up.. there is lot of blocks with millage
Old 01-10-2018, 18:34   #13 (permalink)
Member: 2795242
Hello! I tried that already but a message pops up saying “this action can’t be performed” (well not exactly that, but something similar). I also read somewhere that edc15-16 only works on diesel versions? This is a gasoline.
I went thru all the module options trying to read everything I could but I couldn’t make it for the mileage to pop up anywhere but in the auto scan.
Page generated in 0.17983 seconds with 8 queries
