Dashboard Servicing all digital dashboards |
09-13-2016, 04:09 | #1 (permalink) |
Junior Member Join Date: Aug 2016
Member: 2609757 Status: Offline Thanks Meter: 0 | Xterra'01 mileage correction w/S220 93c56 chip I'm attaching the file if someone can read it correctly and can adjust it, I need 122,415 miles. I couldn't attach the file, but if someone can help I'll send it on PM Thanks in advance |
09-13-2016, 12:02 | #2 (permalink) | |
Moderator Join Date: Mar 2007 Location: WALES
Member: 469145 Status: Offline Thanks Meter: 5,153 | Quote:
wbr | |
09-13-2016, 19:44 | #5 (permalink) | |
wbr | |
09-13-2016, 21:27 | #9 (permalink) | |
I have this info for you: 0km = String #1 = 3DB77B6EF6DCEDB9 String #2 = 7B6EF6DC 206000km = String #1 = 3EA87D50FAA0F541 String #2 = 7B50F6A0 122415km = String #1 = 54AEA95C52B9A572 String #2 = A75C4EB9 Just not sure of dump location for you wbr | |
09-14-2016, 03:37 | #10 (permalink) |
Member: 2609757 Status: Offline Thanks Meter: 0 | I really appreciate all the help and time you spent. I'm going to try to identify the dump location and make the necessary adjustments, the weird thing is that in the car reads 206,000 and when I read it I get a different number, Do you know any free or cheap software to read the hex code and see the real mileage, Mine is the CPT dash. By chance do you have the pinout to power this up? so I don't have to run to the car every time I make a change (Nissan Xterra 2001). Thanks again Thanks for all your help. I'll locate the dump and try this again. Do you know any software free or cheap to read and translate the hex code to real numbers, probably the problem is the programmer I'm using (CPT dash service tool). Also do you have the pinout to power this Instrument cluster up? so I don't have to run to the car every time I make an adjustment. Thanks again Last edited by shooting@orange; 09-14-2016 at 09:13. Reason: Merge Posts |
09-14-2016, 09:12 | #11 (permalink) | |
I sent you a file in PM to try wbr | |
09-14-2016, 18:49 | #13 (permalink) |
Member: 2609757 Status: Offline Thanks Meter: 0 | On this data you sent me, where do I locate the string in which line from 000 to 0F0. Thanks 0km = String #1 = 3DB77B6EF6DCEDB9 String #2 = 7B6EF6DC 206000km = String #1 = 3EA87D50FAA0F541 String #2 = 7B50F6A0 122415km = String #1 = 54AEA95C52B9A572 String #2 = A75C4EB9 |
09-14-2016, 19:34 | #14 (permalink) | |
Try the dump I sent you wbr | |
