ECU & IMMO Diagnostic, Immobilizer, Chip Tuning |
05-19-2016, 05:38 | #6 (permalink) |
Junior Member Join Date: May 2016 Location: Romania
Member: 2574507 Status: Offline Thanks Meter: 4 | Hi If you have only one multi plug then that is just plug and play , but, if its got two multi plugs then that will have to be programmed and matched to your immobiliser system. After you have fitted your new pump connect your opcom and get communication with your Engine ECU . 1) Go to Program Option and Enter your new pump Pin Code ( Donner Pump Pin) then click on Engine ECU Reset......by doing so you will now reset your donner pump . 2) Log out of Engine ECU and now log in to Immobiliser System and Enter your Original Car Pin Code after doing this go to program option and now select Replaced Engine ECU after doing this you have now matched your donner pump to your car immobiliser system. Most of the time you don't need to program your keys again but, if needed you can then reprogram your all keys again. Program all the Variant System as per your old Pump , and also your High Can, Mid Can, and Low Can system Finally clear all fault codes and start your car. Make sure second hand pump is for Zafira and not from Vectra C and with Carprog you extract secutity code from both pumps |
The Following User Says Thank You to king kong1 For This Useful Post: |
05-20-2016, 21:55 | #7 (permalink) | |
Member: 2568045 Status: Offline Thanks Meter: 0 | Quote:
need same programing method ? | |
05-21-2016, 00:44 | #8 (permalink) |
Member: 2574507 Status: Offline Thanks Meter: 4 | need same programing method ?[/QUOTE] Diesel Pump Programming Astra-G / Zafira-A Donor-car Remove dieselpump from donor-car Attention: You will need donor-car's Security Code! Car where donor-pump needs to be installed Install dieselpump in the car Set up communication with ECM Select [Programming] Select [Reset ECU] Enter donor-car's Security Code This will reset the previously learnt security code. Then, your engine ECU (which is inside the pump) will be resetted, so you can learn it to the new car. Set up communication with Immobilizer module Select [Programming] Enter Security Code of car where you have installed the dieselpump Select [Immobilizer Function Programming] Select [ECM (Motor Module) replaced] This will learns the new Security Code to the engine control module. Astra-G and Zafira-A can also be installed with a VP44/PSG5 for Y20DTH. These PSG5 units don't need to be reset. Vectra-C / Signum PSG16 Donor-car Remove the diesel pump from donor-car Attention: You will need donor-car's Security Code! Car where donor-pump needs to be installed Install diesel pump in the car Set up communication with ECM Select [Programming] Select [Reset ECU] Enter donor-car's Security Code This will reset the previously learnt security code. Then, your engine ECU (which is inside the pump) will need to be reset, so you can learn it to the new car. Set up communication with CIM module Select [Programming] Enter Security Code of car where you have installed the diesel pump Select [Immobilizer Function Programming] Select [ECM (Motor Module) replaced] This will learns the new Security Code to the engine control module. Reset immobilizer related controllers Then, you need to go into each module, for which you have a corresponding fault code stored in the CIM module (see below), and do a reset/programming cycle with the security code of the car. IPC Instrument B3925 -00 Wrong Environment Identifier Received IPC REC Rear Electrical Centre B3929 -00 Wrong Environment Identifier Received REC BCM Body Control Module B3924 -00 Wrong Environment Identifier Received BCM DDM Driver Door Module B3926 -00 Wrong Environment Identifier Received DDM PDM Passenger Door Module B3927 -00 Wrong Environment Identifier Received PDM After the reset, you need to wait at least 10 seconds with the ignition OFF, to allow the car to learn the new identifier. Now select ECM and check programming of: Highspeed CAN bus Variant configuration Tyresize Last edited by king kong1; 05-21-2016 at 00:50. |
05-21-2016, 14:38 | #9 (permalink) |
Member: 2568045 Status: Offline Thanks Meter: 0 | Diesel Pump Programming Astra-G / Zafira-A Donor-car Remove dieselpump from donor-car Attention: You will need donor-car's Security Code! Car where donor-pump needs to be installed Install dieselpump in the car Set up communication with ECM Select [Programming] Select [Reset ECU] Enter donor-car's Security Code This will reset the previously learnt security code. Then, your engine ECU (which is inside the pump) will be resetted, so you can learn it to the new car. Set up communication with Immobilizer module Select [Programming] Enter Security Code of car where you have installed the dieselpump Select [Immobilizer Function Programming] Select [ECM (Motor Module) replaced] This will learns the new Security Code to the engine control module. Astra-G and Zafira-A can also be installed with a VP44/PSG5 for Y20DTH. These PSG5 units don't need to be reset. Vectra-C / Signum PSG16 Donor-car Remove the diesel pump from donor-car Attention: You will need donor-car's Security Code! Car where donor-pump needs to be installed Install diesel pump in the car Set up communication with ECM Select [Programming] Select [Reset ECU] Enter donor-car's Security Code This will reset the previously learnt security code. Then, your engine ECU (which is inside the pump) will need to be reset, so you can learn it to the new car. Set up communication with CIM module Select [Programming] Enter Security Code of car where you have installed the diesel pump Select [Immobilizer Function Programming] Select [ECM (Motor Module) replaced] This will learns the new Security Code to the engine control module. Reset immobilizer related controllers Then, you need to go into each module, for which you have a corresponding fault code stored in the CIM module (see below), and do a reset/programming cycle with the security code of the car. IPC Instrument B3925 -00 Wrong Environment Identifier Received IPC REC Rear Electrical Centre B3929 -00 Wrong Environment Identifier Received REC BCM Body Control Module B3924 -00 Wrong Environment Identifier Received BCM DDM Driver Door Module B3926 -00 Wrong Environment Identifier Received DDM PDM Passenger Door Module B3927 -00 Wrong Environment Identifier Received PDM After the reset, you need to wait at least 10 seconds with the ignition OFF, to allow the car to learn the new identifier. Now select ECM and check programming of: Highspeed CAN bus Variant configuration Tyresize[/QUOTE] Thank you so much man |
09-19-2016, 09:18 | #10 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2063311 Status: Offline Thanks Meter: 1 | Only one advice from my experience. Use Carprog only to extract PINCODE. To reset pump ( or any other module ) best use Opcom/Tech2 etc... Sometimes when resetting with Carprog you can experience many problem while matching to new car. Hope it heps. |
The Following User Says Thank You to GolfmkI For This Useful Post: |
