Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Notebooks & Personal Computers
Notebooks & Personal Computers Notebook, Personal Computer - repair, disassemble guides, drivers, bios pasword, and problems with pc.
Old 05-05-2013, 06:08   #1771 (permalink)
Member: 1732171
Tried code but invalid.....any other codes? Thanks in advance
Old 05-05-2013, 06:12   #1772 (permalink)
Member: 1732171
inspiron 5100 bios code
Sorry....forget on the reply to tell you which service tag.....7Q9RN21 ...the first code did not work... Thanks.....
Old 05-05-2013, 15:58   #1773 (permalink)
edgsam's Avatar
Member: 1855998
Thanks Meter: 191
Try one of these:
tpjxue84
wf6l126Vx5yruRL0
-small L between 6 and 1, ends with zero-
Instructions:
Passwords are for QWERTY keyboard only (standard US). Case sensitive. Some units only require pressing <enter> after password, some require pressing <ctrl>+<enter> after password and some require holding down <ctrl> while pressing <enter> once or twice.
Please report back with results. Good luck.
Old 05-05-2013, 20:05   #1774 (permalink)
Member: 1732171
service tag 7Q9RN21
Tried all 3 codes as described....still locked. ???? I really appreciate the help.
Old 05-05-2013, 20:17   #1775 (permalink)
edgsam's Avatar
Member: 1855998
Thanks Meter: 191
That's not good. Are you sure it's a bios lock and not hard drive lock?
It's possible might be -595B algo2, which is rare but possible. If so I'm unable to help.
Old 05-06-2013, 00:12   #1776 (permalink)
Member: 1732171
I'm sure its the bios......how do I know if its the one you mentioned? 595b?
Old 05-06-2013, 01:04   #1777 (permalink)
edgsam's Avatar
Member: 1855998
Thanks Meter: 191
On the password request screen it should display a service tag number with suffix. Example: 7Q9RN21-595B
Unless it has a generic bois. Then after 3 wrong password attemps it will give a 5 digit error code. You are in luck if it does, post that code.
Old 05-06-2013, 02:06   #1778 (permalink)
Member: 1732171
After 3 attempts it says: system disabled 12996
Old 05-06-2013, 02:19   #1779 (permalink)
edgsam's Avatar
Member: 1855998
Thanks Meter: 191
Alright! One of these should work:
ulwot --small L between u and w--
gqwpjds
mzrqqti
totirmn
cxsmxa
Same instructions.....
The Following User Says Thank You to edgsam For This Useful Post:
Old 05-06-2013, 02:49   #1780 (permalink)
Member: 1732171
Got into the bios!!!! So many thanks.....now has hard drive lock......can I reset that without a password or can I just re format the drive to erase it??? Thanks again
Old 05-06-2013, 02:51   #1781 (permalink)
Member: 1732171
It gives me a secondary master HDD password prompt for S/N. HKA014AH
Old 05-06-2013, 03:06   #1782 (permalink)
edgsam's Avatar
Member: 1855998
Thanks Meter: 191
Bummer! Ok, try this password:
42h9054i
If it doesn't work I'm afraid you'll need to replace Hard drive. Reformatting will not work.
Hold on, got an idea>
try one of these:
nnnnnuun
42h9054i
w04acgvx -zero between w and 4-
s4zi42OzfWkQbgf4 -o as in Olive between 2 and z-
u7fcpz03 -zero between z and 3-
Old 05-06-2013, 03:26   #1783 (permalink)
Member: 1732171
I tried...but did not work..... Does this mean I can replace the hard drive and I'll be OK? Will the old hard drive be unusable in another computer? Thanks for all your help.
Old 05-06-2013, 03:35   #1784 (permalink)
edgsam's Avatar
Member: 1855998
Thanks Meter: 191
Yeah, replace the hard drive and it'll be fine. But sorry, old hhd won't be usable in anything.
Old 05-06-2013, 03:55   #1785 (permalink)
Member: 1732171
OK, thanks again for your help.
Page generated in 0.21133 seconds with 9 queries
