Notebooks & Personal Computers Notebook, Personal Computer - repair, disassemble guides, drivers, bios pasword, and problems with pc. |
09-20-2020, 10:56 | #5701 (permalink) | |
Freak Poster Join Date: Feb 2011
Member: 1521901 Status: Offline Sonork: sudan Thanks Meter: 9 | Quote:
I could not change the password of the BIOS system number: 3CR4V3J-595B | |
09-20-2020, 20:25 | #5702 (permalink) | |
Freak Poster Join Date: Jan 2013
Member: 1873660 Status: Offline Thanks Meter: 43 | Quote:
mind the caps! After You have typed the password Press & hold Left Ctrl then press Enter twice to enter the password the code is for QWERTY keyboard only! use external one or press proper keys according to qwerty layout | |
The Following User Says Thank You to 331088 For This Useful Post: |
09-20-2020, 20:32 | #5703 (permalink) | |
alvbbbdo a - alfa ( lowercase ) l - lima ( lowercase ) v - victor ( lowercase ) b - bravo ( lowercase ) b - bravo ( lowercase ) b - bravo ( lowercase ) d - delta ( lowercase ) o - oscar ( lowercase ) IMPORTANT! After typing your password, to accept press left CTRL key and holding this key Press Enter twice | |
09-25-2020, 09:44 | #5705 (permalink) | |
09-29-2020, 10:30 | #5707 (permalink) |
Member: 1873660 Status: Offline Thanks Meter: 43 | 5t2X1p0e52H0n9rO mind the caps! After You have typed the password Press & hold Left Ctrl then press Enter twice to enter the password the code is for QWERTY keyboard only! use external one or press proper keys according to qwerty layout |
10-05-2020, 09:25 | #5710 (permalink) | |
wrLYUD8jgE7a6IA9 mind the caps! After You have typed the password Press & hold Left Ctrl then press Enter twice to enter the password the code is for QWERTY keyboard only! use external one or press proper keys according to qwerty layout | |
10-05-2020, 09:26 | #5711 (permalink) | |
12-21-2020, 19:25 | #5714 (permalink) |
Insane Poster Join Date: Jan 2006
Member: 224473 Status: Offline Thanks Meter: 15 | @K_a_m_i Use NATO phonetic guide under password, followed by holding down CTRL key and ENTER key twice (CTRL-ENTER-ENTER). I’m sure you have done this already. Most likely you are using the master password while inside Setup/BIOS, try using password at the System Password prompt (the one that reads: “This computer system: #xxxxxxx-6FF1 is protected by a password authentication system...”). If System Password is not set, try using Dell CCTK utility (Client Configuration Tool Kit) to set it up, reboot and try password again, this have made a difference for me in a similar situation as yours. DELL Service Tag: 2ZLV5H2-6FF1 password: v8CBZB82fx11sRCi ------------ v - victor ( lowercase ) 8 - 8 ( digit ) C - CHARLIE ( UPPERCASE ) B - BRAVO ( UPPERCASE ) Z - ZULU ( UPPERCASE ) B - BRAVO ( UPPERCASE ) 8 - 8 ( digit ) 2 - 2 ( digit ) f - foxtrot ( lowercase ) x - x-ray ( lowercase ) 1 - 1 ( digit ) 1 - 1 ( digit ) s - sierra ( lowercase ) R - ROMEO ( UPPERCASE ) C - CHARLIE ( UPPERCASE ) i - india ( lowercase ) ------------ |
