HTC Hardware Repair HTC Hardware repair, tutorials, help, solutions |
03-09-2016, 21:18 | #1 (permalink) |
Junior Member Join Date: Jul 2012 Location: France
Member: 1784836 Status: Offline Thanks Meter: 3 | Htc one M8 repair digitizer I broke a component on the motherboard and I would like to replace it because my digitizer does not work fine. Could someone give me the characteristics of the component. Thank you very much http://www.mediafire.com/view/v69wjc...20m8%20AC.jpg# Last edited by sunnday; 03-09-2016 at 21:19. Reason: add picture |
03-15-2016, 14:04 | #7 (permalink) |
Member: 1784836 Status: Offline Thanks Meter: 3 | Hi. Thank you for your answers Resistance is slightly broken but must work because I measure the same value on R1 and R2 = 468 Kohms I analyzed carefully the connector and has 2 pins that are broken , I will try to replace it with a hot air station. It is a place of digitizer does not work. Simple File Sharing and Storage. |
05-12-2016, 22:01 | #10 (permalink) |
Member: 1784836 Status: Offline Thanks Meter: 3 | Hi. Thank you for your help but i broked 2 components. A and B . Finally I soldered the new connector touch screen digitizer with my iron gun. Don't use hot air gun otherwise you will burn the motherboard. My touch screen work but very bad without jumper. Simple File Sharing and Storage. Simple File Sharing and Storage. Simple File Sharing and Storage. I need to know exactly the characteristics of these components please. Yes it's not a resistor because with my multimeter the value change always. I connected A and B as the picture Simple File Sharing and Storage. And now my digitizer don't work . I think the phone is dead for spares. Thank |
06-14-2016, 22:41 | #12 (permalink) |
Member: 1784836 Status: Offline Thanks Meter: 3 | Hi. Before i short circuit 1-2-3 i can read 246 Kohms for A and B After i short circuit 1-2-3 , i read 0 Kohm I think now the motherboard is dead , my touch screen is HS Simple File Sharing and Storage. Thank you for your help |
