Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Hardware Repair
HTC Hardware Repair HTC Hardware repair, tutorials, help, solutions
Old 01-11-2013, 14:43   #1 (permalink)
Registered User
Member: 617315
Sonork: Skopje Nord Macedonia
Thanks Meter: 22
HTC One V brightness not working
I have HTC One V and the brightness is not working, i have change another LCD the problem is still the same. Any solution
Old 02-10-2013, 13:44   #2 (permalink)
Member: 611798
i have this problem too i cant change light it is stil low
Old 02-25-2013, 13:36   #3 (permalink)
Member: 403650
Thanks Meter: 3
U mast change light&charge IC
Old 02-25-2013, 16:20   #4 (permalink)
Member: 763356
In one v brightness problem in a main board.
Old 02-27-2013, 11:34   #5 (permalink)
Member: 652685
Sonork: 100.1594842
Thanks Meter: 45
it's fault of any coil. I am also searching for the solution.
Old 03-06-2013, 03:10   #6 (permalink)
Member: 1894890
Very thank you for your message, look forward to your update again
Old 07-20-2013, 11:04   #7 (permalink)
Member: 1835157
i have also same problem here plzzzzz anybdy help us we are totaly stuck
Old 08-29-2013, 11:20   #8 (permalink)
ea12345's Avatar
Member: 130345
Thanks Meter: 10
change charging ic I think
Old 09-19-2013, 04:57   #9 (permalink)
Member: 1930172
One V brightness problem
Sohave you found the solution to this problem?
Old 10-05-2013, 16:16   #10 (permalink)
Member: 392151
Thanks Meter: 80
if aneone of u got solution plz post here very emergency same problem
thanks
Old 10-06-2013, 10:14   #11 (permalink)
Member: 2040985
Sonork: 48075
Old 10-23-2013, 11:08   #12 (permalink)
Member: 411654
change the one v light 220
Old 11-27-2013, 06:57   #13 (permalink)
Member: 1838311
Sonork: 100.1638474
Thanks Meter: 103
change coil 100% done tested by me
Old 11-28-2013, 07:20   #14 (permalink)
Member: 1838311
Sonork: 100.1638474
Thanks Meter: 103
http://www.mediafire.com/view/7a7gs0...127_111024.jpg
Old 02-11-2014, 16:23   #15 (permalink)
Member: 2126186
Htc one v not turning on and overheated
HTC ONE V showing bottom 3 buttons blinking and getting overheated after changing coil while charging it gets really hot and screen not showing NEED HELP!!!!
Page generated in 0.23875 seconds with 8 queries
