Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Hardware Repair
HTC Hardware Repair HTC Hardware repair, tutorials, help, solutions
Old 12-15-2014, 11:20   #1 (permalink)
Member: 2152953
HTC M8 No sim detected
Hello friends,
i changed the simslot on a M8 hoping to restore function, but it did not work.
The simslot is ok, the simcard is fine and in place. anybody know what the problem is? could it be software? i have literally no idea at this point, please help
The Following User Says Thank You to black5757 For This Useful Post:
Old 12-17-2014, 10:50   #2 (permalink)
Super Moderator
~Leo~'s Avatar
Member: 224065
Sonork: 100.1577902
Thanks Meter: 7,930
no it can't be related what so ever to software
thread moved to hardware
__________________
USE "THANKS" Button.
Follow Forum Rules
OFFLINE and Away
The Following User Says Thank You to ~Leo~ For This Useful Post:
Old 04-29-2015, 18:21   #3 (permalink)
Member: 1164437
Sonork: 100.1659986
Thanks Meter: 23
i have same problem.my htc m8 showing insert sim
Old 05-02-2015, 12:36   #4 (permalink)
Member: 2136572
Sonork: 100.1653162
Thanks Meter: 41
If the SIM slot is OK and all pins are connected to their points on the board>>>
the problem is related to POWER IC . Try reheat it well and safely
Good Luck
Old 05-04-2015, 08:20   #5 (permalink)
Member: 2377447
it might be sim tray problem if not check all tracks related to sim slot
Old 07-31-2015, 17:30   #6 (permalink)
Member: 1164437
Sonork: 100.1659986
Thanks Meter: 23
htc m8 sim not detected 100% solution
just make this jumper.10000% work.enjoy it.follow the link.
The Following 5 Users Say Thank You to naqvi66 For This Useful Post:
Old 08-10-2015, 10:46   #7 (permalink)
Member: 2436077
Sonork: parneethas
You need to restart your mobile first
The Following User Says Thank You to parneethas For This Useful Post:
Old 02-01-2016, 20:44   #8 (permalink)
Member: 1141290
Sonork: nil
Thanks Meter: 5
Is this for M8 one sim or dual please
Old 02-15-2016, 07:40   #9 (permalink)
Member: 2504814
naqvi66: i tried this and it helped me too. the phone i fixed had the issue but did work if the owner pressed on the phone (slightly below the sim card flex).
Old 03-18-2016, 01:40   #10 (permalink)
Member: 1164437
Sonork: 100.1659986
Thanks Meter: 23
antalpromile,this me attested solution.this problem comes due to flex cable.check and connect jumper again.if problem still remain,then connect flex cable in mother board and check sim conecctor points ,is there any point open ?.if you get other open point ,tell me i will send you its diagramm or u can check and with other m8
Old 06-02-2016, 15:27   #11 (permalink)
Member: 297474
Thanks Meter: 52
link dead..
can someone add the picture again?
Thanks
FLoryneL
Old 06-10-2016, 07:31   #12 (permalink)
Member: 352329
Thanks Meter: 38
please send me a jumber picture..
thanks
Old 06-13-2016, 06:40   #13 (permalink)
Member: 479780
Thanks Meter: 31
Schematic is comming after 3 days
Old 06-13-2016, 23:53   #14 (permalink)
Member: 1164437
Sonork: 100.1659986
Thanks Meter: 23
http://http://www.4shared.com/downlo....jpg?lgfp=1000
Last edited by naqvi66; 06-13-2016 at 23:54. Reason: Follow this image.10000% solution
Old 06-14-2016, 08:59   #15 (permalink)
Member: 352329
Thanks Meter: 38
LINK DEAD please give me a working link
thanks
Page generated in 0.21793 seconds with 8 queries
