07-12-2021, 10:03 | #1 (permalink) |
Insane Poster Join Date: Mar 2019 Location: Algeria
Member: 2900446 Status: Offline Thanks Meter: 279 | 1st World Condor Smart TV 43SD520 Repair VIA eMMC 1st World Condor Smart TV 43SD520 Repair VIA eMMC Android TV Version 9.0 Code: Main Board JUC7.820.00236289 HLS91F J-I-1 Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Operations with eMMC restricted(Bus Mode : 1b) Connecting... Device : Toshiba eMMC 008G30 Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 11010030303847333000814244D72637 Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 008G30 Product revision : 0.0 Product serial number : (hex) 814244D7 Manufacturing date : 02/2019 --------------------------------------------------------------- CSD Info CSD : D02700328F5903FFFFFFFFE7864000A7 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x0A) 00001010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + High Speed timings in boot operation RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/008G30_12_07_2021_08_22_45.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.1; FW: 2.00. --------------------------------------------------------------- Searching Android build info... Not found --------------------------------------------------------------- |
The Following 9 Users Say Thank You to DZGSM-TEAM For This Useful Post: |
