06-02-2021, 22:08 | #1 (permalink) |
Insane Poster Join Date: Mar 2019 Location: Algeria
Member: 2900446 Status: Offline Thanks Meter: 279 | 1st World Condor Smart TV LED55U9000 & LED65U9000 Repair VIA eMMC 1st World Condor Smart TV LED55U9000 Repair VIA eMMC 1st World Condor Smart TV LED65U9000 Repair VIA eMMC Code: Main Board 40-NT67DH-MAB4HG Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 008G92 Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB (7456.00 MB) --------------------------------------------------------------- CID Info CID : 1101003030384739320088E0B3ABB1B9 Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 008G92 Product revision : 0.0 Product serial number : (hex) 88E0B3AB Manufacturing date : 11/2014 --------------------------------------------------------------- CSD Info CSD : D00E00320F5903FFFFFFFFEF92400045 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 1 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 512 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x12) 00010010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use dual data rate in boot operation RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x1 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/008G92_02_12_2020_21_02_31.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.6; FW: 1.24. P00: EXT2FS (00100000, 00800000) 8 MB P01: EXT2FS (00900000, 00800000) 8 MB P02: EXT2FS (01100000, 01800000) 24 MB P03: EXT2FS (02A00000, 03000000) 48 MB P04: EXT2FS (05B00000, 00800000) 8 MB P05: EXT2FS (06400000, 00800000) 8 MB P06: EXT2FS (06D00000, 02000000) 32 MB P07: EXT2FS (08E00000, 02000000) 32 MB P08: EXT2FS (0AF00000, 02000000) 32 MB P09: EXT2FS (0D000000, 10100000) 257 MB P10: EXT2FS (1D200000, 01000000) 16 MB P11: EXT2FS (1E300000, 40000000) 1024 MB P12: EXT2FS (5E400000, 161AFFE00) 5.526 GB --------------------------------------------------------------- Searching Android build info... Not found --------------------------------------------------------------- |
The Following 6 Users Say Thank You to DZGSM-TEAM For This Useful Post: |
