06-06-2020, 15:29 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Laghouat, Algeria Age: 30
Member: 1191316 Status: Offline Thanks Meter: 900 | 1st World CRIUS MEA W8 WINDOWS TAB the Ultimate solution here [IMG]****************************/convkey/8e12/om8kq3wzkjw64fszg.jpg?size_id=4[/IMG] MY 1 st HANDS ON THIS TAB SINCE THIS TAB IS BASED ON WINDOWS OS WAS GREAT TO BRING MY OLD EXPERIENCE ON PC's AND MERGE TO THE NEW GSM SKILLS MANY USERS HAS THIS TAB AND THEY THROUGH IT CAUSE NO INFO OR HELP FOUND BUT ON MEDUSA SECTION ALWAYS THE NEW AND POWERFULL WORKS THIS TUTORIAL HAS TO BASES FOR BEGINNER AND DEVELOPERS BEGINNER WHO HAS REPAIRING SHOP LIKE IN MY COUNTRY DEVELOPERS WHO WANTS CHANGE SOME INFO ON UEFI THIS DEVELOPMENT WILL NEVER BE FOUND ON INTERNET JUST RELAX AND CONTINUE READING NOTICE : ALL CREDIT AND COYRIGHTS WENT TO MEDUSA WARNING : ANY ILLEGAL EDIT OF SYSTEM OR UEFI WILL DAMAGE THE DEVICE CAUSE eMMC SECURE ERASE IS ACTIVATED AND NO WAYS TO REVIVE IT INSTEAD ALL UEFI KEYS ARE SAVED TO MY PC MY WORK BASED ON TWO WAYS UEFI DEBRICK & SYSTEM OS LET'S START ON SYSTEM OS THE SYSTEM BASED ON WINDOWS 10-32BITS V2004-OEM FAMILLY EDITION ACTIVATED LICENCE KEY ( MULTIPLE USES ) AND CLOSED ALL WAYS TO HACK OR EDIT DUE THE COPYRIGHTS INCLUDED ALL NECESSARY DRIVERS WITH LAST UPDATE SUCK TOUCH-WIFI- BLUETOOTH AND CAMERA SMARTSCREEN AGENTS ARE DISABLED FOR REASON JUST READ DOWN AND U'LL KNOW WHY NOW LET'S SPEAK WHAT WAS CHANGE ON UEFI UEFI IS UNBRICKED TOTALLY WITH ALMOST HIDDEN FEATURED ( READ THE CHANGE AND IF SOMETHING MISSING PLEASE TRY TO DISCUSE ) UEFI WRITE PROTECT IS LOCKED TO AVOID CLONING DISABLED eMMC WRITE PROTECTION & ENABLED SECURE ERASE UNLOCKED MODEM (ANY SIM CAN WORK) UNLOCKED LIMIT MOUNT OF RAM TO MORE 1GB DDR3 1333MHz (FOR WHO WANTS INSTALL MORE RAMS) UNLOCKED CPU LIMIT AND ENABLED ALL CORES TO AVOID BOOTLOOP OR CRUSHING ENABLING 64 BITS TO WORK WITH 4GB RAMS AND MORE ALL CPU VIRTUALISATION FEATURED ARE ENABLED HANDLE CPU TO USE MINIMAL POWER ENERGY ENABLED CPU STEP AND SET STATE TO C7 ( DEVELOPER ONLY) ALL THOSE DEVELOPMENT MAKE TAB GET A BIT HOT BUT DON'T WORRY CAUSE COVER OF TAB CAN HANDLE THE HOT ENABLED LEGACY USB FOR BOOTING ENABLED UART TO USB PORT ( FOR WHO WANTS TO USE TAB FOR FLASHING OR UNLOCK) DISABLED LIMIT STORAGE TO USE SSD OR HIGH CAPACITY SDCARD VIA USB ADD COMMAND TO ALLOW UEFI CHECK THE BATTERY IF DAMAGED OR INVALID TRICKED UEFI TO SET MAX BATTERY DBI TO 250KOHM ( DEVELOPER ONLY) ACTIVATE POWER SAVING FOR CPU AND GPU UPGRADE UEFI TO SET MAX CPU TEMP TO 80 DEGREES INSTEAD 65 DEGREES HIGHLIGHT GRAPHIC CARD TO 256MB TO AVOID COLLECT FROM 1 GB RAM ALL THOSE STEPS ARE INCLUDED ON SRF FILE SRF FILE CAN DEBRICK UEFI AND DEAD BOOT I'LL SHARE THE SRF FILE HERE BUT PLEASE LET THE SYSTEM AS IT SUCH PICTURES IT'S ONLY ADs FOR OWR WORK CAUSE WE DON'T ASK YOU TO DONATE WHEN YOU COPY THAT THREAD TO OTHER FORUMS JUST MENTION THE SOURCE CAUSE THIS HARD JOB TOOK 2 DAYS FROM ME LIKE CRAZY HERE IMPROVEMENT LOG INFO : Code: Model Settings: Interface : eMMC Brand : Crius MEA Model : W8 SRF : C:/Users/STARKRIMES/Desktop/W8/Crius MEA_W8_eMMC_By_STARKRIMES.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : 50 MHz Connecting... Device : Foresee eMMC NCard Page size : 512 B Block size : 512 B Block count : 30576640 Size : 14.58 GB (14930.00 MB) --------------------------------------------------------------- CID Info CID : 8801034E436172642019FD0C0004C16F Manufacturer ID : 0X88 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X03 Product name : NCard Product revision : 1.9 Product serial number : (hex) FD0C0004 Manufacturing date : 12/2014 --------------------------------------------------------------- CSD Info CSD : D0FFFF320F5903FFFFFFFFE7964000EB CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 80 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 2097152 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/NCard_06_06_2020_10_14_09.bin. Connect successful. --------------------------------------------------------------- SW: 2.1.0; FW: 2.00. P00: GPT (00000000, 00032800) 101 MB P01: Microsoft reserved parti (00032800, 00040000) 128 MB P02: EFI system partition (00072800, 00032000) 100 MB P03: Basic data partition (000A4800, 01BA2800) 13.82 GB P04: (01C47000, 000E1000) 450 MB ---------------------------------------------------------------Searching Android build info... Not found ---------------------------------------------------------------RPMB: RPMB: Authentication Key not yet programmed. SRF FILE HAS ALMOST 5 GB NEED TIME TO UPLOAD IT Download MEDUSA PRO II Software Find out more at: https://medusabox.com/ Download Octoplus PRO JTAG Software Find out more at: www.octoplusbox.com |
The Following User Says Thank You to starkrimes For This Useful Post: |
06-09-2020, 07:57 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,421 | As alwyas huge work was done, keep it up Last edited by Octopus box; 06-10-2020 at 08:09. |
