07-03-2021, 12:34 | #1 (permalink) |
Freak Poster Join Date: Nov 2013 Location: Algeria
Member: 2068893 Status: Offline Thanks Meter: 409 | 1st World Samsung Galaxy Tab S2 9.7 SM-T819 Repair VIA eMMC 1st World Samsung Galaxy Tab S2 9.7 SM-T819 Repair VIA eMMC Code: Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 500073 Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 110100353030303733005A97A039C3D5 Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 500073 Product revision : 0.0 Product serial number : (hex) 5A97A039 Manufacturing date : 12/2016 --------------------------------------------------------------- CSD Info CSD : D07E00320F5903FFFFFFFFE78A4000D1 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 8 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15269888 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/500073_03_07_2021_12_03_33.bin. Connect successful. --------------------------------------------------------------- SW: 2.2.1; FW: 1.24. P00: GPT (00000000, 00400000) 4 MB P01: sbl1 (00400000, 00080000) 512 KB P02: sbl1bak (00480000, 00080000) 512 KB P03: ddr (00500000, 00008000) 32 KB P04: limits (00508000, 00008000) 32 KB P05: aboot (00510000, 00200000) 2048 KB P06: rpm (00710000, 00080000) 512 KB P07: tz (00790000, 00200000) 2048 KB P08: hyp (00990000, 00080000) 512 KB P09: fsg (00A10000, 00300000) 3072 KB P10: sec (00D10000, 00004000) 16 KB P11: keymaster (00D14000, 00040000) 256 KB P12: cmnlib (00D54000, 00040000) 256 KB P13: pad (00D94000, 00A6C000) 10.42 MB P14: modemst1 (01800000, 00300000) 3072 KB P15: modemst2 (01B00000, 00300000) 3072 KB P16: param (01E00000, 00A00000) 10 MB P17: efs (02800000, 00E00000) 14 MB P18: boot (03600000, 02000000) 32 MB P19: recovery (05600000, 02000000) 32 MB P20: bota (07600000, 00700000) 7 MB P21: fota (07D00000, 00500400) 5.001 MB P22: backup (08200400, 005FDC00) 5.991 MB P23: fsc (087FE000, 00300000) 3072 KB P24: ssd (08AFE000, 00002000) 8 KB P25: persist (08B00000, 02000000) 32 MB P26: persistent (0AB00000, 00100000) 1024 KB P27: steady (0AC00000, 00100000) 1024 KB P28: keystore (0AD00000, 00080000) 512 KB P29: config (0AD80000, 00008000) 32 KB P30: mota (0AD88000, 00100000) 1024 KB P31: devcfg (0AE88000, 00040000) 256 KB P32: dsp (0AEC8000, 01000000) 16 MB P33: modem (0BEC8000, 06838000) 104.2 MB P34: apnhlos (12700000, 01800000) 24 MB P35: persdata (13F00000, 00900000) 9 MB P36: system (14800000, 106800000) 4.102 GB P37: cache (11B000000, 0C800000) 200 MB P38: hidden (127800000, 02800000) 40 MB P39: userdata (12A000000, 61DBFB000) 24.46 GB Backuping fsg partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/500073_fsg_0x5080_0x1800_03_07_2021_12_03_33.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.2.1; FW: 1.24. Backuping modemst1 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/500073_modemst1_0xc000_0x1800_03_07_2021_12_03_33.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.2.1; FW: 1.24. Backuping modemst2 partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/500073_modemst2_0xd800_0x1800_03_07_2021_12_03_33.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.2.1; FW: 1.24. Backuping efs partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/500073_efs_0x14000_0x7000_03_07_2021_12_03_33.bin file... Reading. Please wait... Done. Elapsed time 00:00:05 SW: 2.2.1; FW: 1.24. --------------------------------------------------------------- Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 671744 Number of sectors : 8601600 Device Manufacturer : samsung Device Platform : msm8952 Build ID : NRD90M Display Build ID : NRD90M.T819XXU2BRI1 Release ID : 7.0 Device Model : SM-T819 Device Name : gts210veltexx Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : gts210veltexx-user 7.0 NRD90M T819XXU2BRI1 release-keys --------------------------------------------------------------- Code: SAMSUNG_SM-T819_TOSHIBA EMMC 500073_BY_DZGSM_TEAM.srf (BOOT1 SAMSUNG SM-T819) TOSHIBA EMMC 500073.bin (BOOT2 SAMSUNG SM-T819) TOSHIBA EMMC 500073.bin (EXT_CSD SAMSUNG SM-T819) TOSHIBA EMMC 500073.bin (LIVE_LOG_SAMSUNG SM-T819) TOSHIBA EMMC 500073.txt |
The Following 4 Users Say Thank You to DZ-DEVELOPER For This Useful Post: |
