09-05-2019, 14:58 | #1 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Laghouat, Algeria Age: 30
Member: 1191316 Status: Offline Thanks Meter: 900 | 1st World Samsung J410F REPAIR DONE & FRP OFF VIA eMMC [IMG]****************************/convkey/8e12/om8kq3wzkjw64fszg.jpg?size_id=4[/IMG] 1st World SAMSUNG J410F REPAIR DONE & FRP OFF VIA eMMC By THE GEANT OCTOPLUS [IMG]****************************/convkey/694d/qhbpbcwjjy1gcytzg.jpg[/IMG]LOG READ INFO : Code: Welcome to Octoplus Pro JTAG Software version 1.7.7. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: FT SCR2000 2 Reader #3: Generic Usb Smart Card Reader 0 Reader #4: Generic Usb Smart Card Reader 1 Reader #5: Generic Usb Smart Card Reader 3 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC FE62MB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100464536324D420093A3064EC59F Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : FE62MB Product revision : 0.0 Product serial number : (hex) 93A3064E Manufacturing date : 12/2018 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 671744 Number of sectors : 2965504 Device Manufacturer :samsung Build ID :M1AJB Display Build ID :M1AJB.J410FXXU2ASF3 Release ID :8.1.0 Device Model :SM-J410F Device Name :j4coreltejx Architecture ABI :armeabi-v7a Architecture ABI2 :armeabi Architecture ABI List :armeabi-v7a,armeabi Build Description :j4coreltejx-user 8.1.0 M1AJB J410FXXU2ASF3 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/FE62MB_05_09_2019_09_56_30.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.7; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: sbl1 (00002000, 00000400) 512 KB P02: sbl1bak (00002400, 00000400) 512 KB P03: ddr (00002800, 00000040) 32 KB P04: limits (00002840, 00000040) 32 KB P05: aboot (00002880, 00001000) 2048 KB P06: rpm (00003880, 00000400) 512 KB P07: tz (00003C80, 00001000) 2048 KB P08: hyp (00004C80, 00000400) 512 KB P09: devcfg (00005080, 00000200) 256 KB P10: fsg (00005280, 00001800) 3072 KB P11: sec (00006A80, 00000020) 16 KB P12: keymaster (00006AA0, 00000400) 512 KB P13: cmnlib (00006EA0, 00000200) 256 KB P14: cmnlib64 (000070A0, 00000200) 256 KB P15: lksecapp (000072A0, 00000400) 512 KB P16: apdp (000076A0, 00000200) 256 KB P17: msadp (000078A0, 00000200) 256 KB P18: pad (00007AA0, 00000560) 688 KB P19: modemst1 (00008000, 00001800) 3072 KB P20: modemst2 (00009800, 00001800) 3072 KB P21: param (0000B000, 00005000) 10 MB P22: efs (00010000, 00007000) 14 MB P23: steady (00017000, 00002000) 4 MB P24: misc (00019000, 00000800) 1024 KB P25: boot (00019800, 00010000) 32 MB P26: recovery (00029800, 00010000) 32 MB P27: dtbo (00039800, 00004000) 8 MB P28: bota (0003D800, 00003800) 7 MB P29: fota (00041000, 00002802) 5.001 MB P30: backup (00043802, 00002FF6) 5.995 MB P31: fsc (000467F8, 00001800) 3072 KB P32: ssd (00047FF8, 00000010) 8 KB P33: persist (00048008, 00010000) 32 MB P34: persistent (00058008, 00000400) 512 KB P35: keystore (00058408, 00000400) 512 KB P36: config (00058808, 00000040) 32 KB P37: mota (00058848, 00000400) 512 KB P38: dpo (00058C48, 00000200) 256 KB P39: mdtp (00058E48, 00000080) 64 KB P40: dip (00058EC8, 00000800) 1024 KB P41: oem (000596C8, 00000080) 64 KB P42: mcfg (00059748, 00002000) 4 MB P43: dsp (0005B748, 00008000) 16 MB P44: modem (00063748, 0002DCB8) 91.59 MB P45: apnhlos (00091400, 00010000) 32 MB P46: reserved2 (000A1400, 00002C00) 5.5 MB P47: system (000A4000, 002D4000) 1448 MB P48: vendor (00378000, 0007C000) 248 MB P49: odm (003F4000, 00018000) 48 MB P50: cache (0040C000, 00023000) 70 MB P51: hidden (0042F000, 00008000) 16 MB P52: omr (00437000, 0000C000) 24 MB P53: userdata (00443000, 01916FD8) 12.54 GB LOG FRP RESET : Code: Backuping FRP data... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/FRP_0x58008_0x400_05_09_2019_10_07_13.bin file... Reading. Please wait... Done. Elapsed time 00:00:00 SW: 1.7.7; FW: 1.24. Removing FRP. Please wait... Done. SW: 1.7.7; FW: 1.24. LOG REPAIRING : Code: Selected file: C:/Users/STARKRIMES/Desktop/Samsung_J410F_eMMC_SRF/J410F BOARD FIRMWARE/Rawprogram0.xml. Backuping. Please wait... Reading partition modemst1... Done. Reading partition modemst2... Done. Backuping finished. #grenWriting. Please wait... Write data verification is enabled. Writing partition sbl1... Done. Writing partition sbl1bak... Done. Writing partition ddr... Done. Writing partition limits... Done. Writing partition aboot... Done. Writing partition rpm... Done. Writing partition tz... Done. Writing partition hyp... Done. Writing partition devcfg... Done. Writing partition sec... Done. Writing partition keymaster... Done. Writing partition cmnlib... Done. Writing partition cmnlib64... Done. Writing partition lksecapp... Done. Writing partition apdp... Done. Writing partition msadp... Done. Writing partition pad... Done. Writing partition param... Done. Writing partition efs... Done. Writing partition steady... Done. Writing partition misc... Done. Writing partition boot... Done. Writing partition recovery... Done. Writing partition dtbo... Done. Writing partition bota... Done. Writing partition fota... Done. Writing partition backup... Done. Writing partition ssd... Done. Writing partition persist... Done. Writing partition persistent... Done. Writing partition keystore... Done. Writing partition config... Done. Writing partition mota... Done. Writing partition dpo... Done. Writing partition mdtp... Done. Writing partition dip... Done. Writing partition oem... Done. Writing partition mcfg... Done. Writing partition dsp... Done. Writing partition modem... Done. Writing partition apnhlos... Done. Writing partition reserved2... Done. Writing partition vendor... Done. Writing partition odm... Done. Writing partition hidden... Done. Writing partition omr... Done. Writing MBR...Done. Writing primary GPT...Done. Writing partition PrimaryGPT... Done. Writing finished. SW: 1.7.7; FW: 1.24. Disconnected. [IMG]****************************/convkey/a0f5/vd2mwxgkef7cceyzg.jpg[/IMG] [IMG]****************************/convkey/9197/jhqhdgjymje5kuhzg.jpg[/IMG] |
The Following 5 Users Say Thank You to starkrimes For This Useful Post: |
06-04-2020, 14:22 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | If users are really need it, You can share in PM, thx starkrimes for his hard work |
