Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octoplus JTAG
Old 03-07-2025, 00:23   #1 (permalink)
Member: 2749961
Thanks Meter: 20
A145m ISP Medusa Pro [Answered]
Hello, i tryed to read A145m and it reads once, but after that cant connect
any help?
Welcome to Medusa Pro Software version 2.2.5.6.
Activation type:
Used the activation PRO
Started.
Please disconnect battery and USB cable.
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Wrong adapter type for measure request.
ERROR[001]: Can not connect. No target device present.
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Samsung eMMC DV6DBB
Page size : 512 B
Block size : 512 B
Block count : 244285440
Size : 116.48 GB (119280.00 MB)
CID Info
CID : 15010044563644424200366BFA6AB8DD
Manufacturer ID : 0X15
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : DV6DBB
Product revision : 0.0
Product serial number : (hex) 366BFA6A
Manufacturing date : 11/2021
CSD Info
CSD : D02701320F5903FFF6DBFFEF8E40400D
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.8 (for MMC v5.1)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 16384 Kbytes
Partition config : (0x48) 01001000
Boot partition enable : Boot partition 1
(Bus width = 4Bit)
Boot ACK : Boot acknowledge sent during boot operation Bit
Boot bus conditions : (0x01) 00000001
Boot bus width : x4 (sdr/ddr) bus width in boot operation mode
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x01) RST_n signal is permanently enabled
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 40714240 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/DV6DBB_06_03_2025_01_59_16.bin.
RPMB: Counter of the successful data write requests = 0.
EMMC connected successful.
SW: 2.2.5.6; FW: 1.27.
Part.00: GPT (00000000, 00002000) 4 MB
Part.01: efs (00002000, 0000A000) 20 MB
Part.02: sec_efs (0000C000, 0000A000) 20 MB
Part.03: reserved (00016000, 00002000) 4 MB
Part.04: cpefs (00018000, 00004000) 8 MB
Part.05: steady (0001C000, 00002000) 4 MB
Part.06: param (0001E000, 00004000) 8 MB
Part.07: bota (00022000, 00012000) 36 MB
Part.08: ldfw (00034000, 00004000) 8 MB
Part.09: tzsw (00038000, 00000C00) 1536 KB
Part.10: tzar (00038C00, 00003400) 6.5 MB
Part.11: keystorage (0003C000, 00000400) 512 KB
Part.12: nad_refer (0003C400, 00000800) 1024 KB
Part.13: up_param (0003CC00, 00004000) 8 MB
Part.14: misc (00040C00, 00001000) 2048 KB
Part.15: uh (00041C00, 00001000) 2048 KB
Part.16: uhcfg (00042C00, 00002000) 4 MB
Part.17: blcmd (00044C00, 00000400) 512 KB
Part.18: boot (00045000, 00020000) 64 MB
Part.19: init_boot (00065000, 00008000) 16 MB
Part.20: vendor_boot (0006D000, 00010000) 32 MB
Part.21: recovery (0007D000, 00034000) 104 MB
Part.22: dtb (000B1000, 00004000) 8 MB
Part.23: dtbo (000B5000, 00004000) 8 MB
Part.24: radio (000B9000, 00019000) 50 MB
Part.25: persistent (000D2000, 00000400) 512 KB
Part.26: vbmeta (000D2400, 00000400) 512 KB
Part.27: vbmeta_system (000D2800, 00000400) 512 KB
Part.28: keyrefuge (000D2C00, 00008000) 16 MB
Part.29: keydata (000DAC00, 00008000) 16 MB
Part.30: metadata (000E2C00, 00010000) 32 MB
Part.31: fmp_selftest (000F2C00, 00000008) 4 KB
Part.32: debug (000F2C08, 00040000) 128 MB
Part.33: reserved2 (00132C08, 000013F8) 2556 KB
Part.34: super (00134000, 00E60000) 7.188 GB
Part.35: prism (00F94000, 001B8000) 880 MB
Part.36: optics (0114C000, 0000C000) 24 MB
Part.37: cache (01158000, 00064000) 200 MB
Part.38: omr (011BC000, 00019000) 50 MB
Part.39: cp_debug (011D5000, 00002800) 5 MB
Part.40: userdata (011D7800, 0D71E000) 107.6 GB
Backuping efs partition...
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/DV6DBB_efs_0x2000_0xa000_06_03_2025_01_59_16.bin file...
Reading. Please wait...
ERROR[011]: Read error.
Attempting to read...
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 2.6V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Model Settings:
Interface : eMMC
Voltage : 3.0V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Page size : 512 B
Block size : 512 B
CID Info
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 4Bit)
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/DV6DBB_06_03_2025_02_00_46.bin.
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/DV6DBB_efs_0x2000_0xa000_06_03_2025_02_00_46.bin file...
Reading. Please wait... Done.
Elapsed time 00:00:09
Backuping cpefs partition...
Opening C:/Program Files (x86)/Medusa Pro Software/Backups/DV6DBB_cpefs_0x18000_0x4000_06_03_2025_02_00_46.bi n file...
Elapsed time 00:00:03
Searching Android build info...
Not found
Partition table has been found on device.
Disconnected.
Model Settings:
Interface : eMMC
Voltage : 3.2V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Model Settings:
Interface : eMMC
Voltage : 3.3V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Model Settings:
Interface : eMMC
Voltage : 2.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Model Settings:
Interface : eMMC
Voltage : 3.0V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Old 03-10-2025, 14:56   #2 (permalink)
Member: 2749961
Thanks Meter: 20
Any help?
Any help to read it again?
Old 03-11-2025, 07:14   #3 (permalink)
Octopus support's Avatar
Member: 2891705
Thanks Meter: 2,292
Hello
Please, send us photo of how did you connect and photo of chip, we will check it.
Page generated in 0.19732 seconds with 8 queries
