Member: 2851795
Thanks Meter: 21 | How to remap memory? TEYES CC2 [Answered] They brought me a teyes cc2 car radio for repair. I replaced the memory with a similar 64GB, but I only have a dump from the 32GB version, now the radio tape recorder works but in the settings the memory is 32GB. How to remap memory? The first log is from the memory that was in the car radio, the second log is from emmc from the 32GB version. Quote:
Model Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Sandisk eMMC DA4064
Page size : 512 B
Block size : 512 B
Block count : 122142720
Size : 58.24 GB (59640.00 MB)
CID Info
CID : 45010044413430363401DAFEEB0E761B
Manufacturer ID : 0X45
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : DA4064
Product revision : 0.1
Product serial number : (hex) DAFEEB0E
Manufacturing date : 07/2019
CSD Info
CSD : D00F00328F5903FFFFFFFFEF8A404023
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 10 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.8 (for MMC v5.1)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 16384 Kbytes
Partition config : (0x08) 00001000
Boot partition enable : Boot partition 1
(Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x01) RST_n signal is permanently enabled
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 19177472 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/DA4064_07_06_2022_16_50_12.bin.
Connect successful.
SW: 2.2.4.6; FW: 1.24.
P00: GPT (00000000, 00000800) 1024 KB
P01: prodnv (00000800, 00002800) 5 MB
P02: miscdata (00003000, 00000800) 1024 KB
P03: recovery (00003800, 00011800) 35 MB
P04: misc (00015000, 00000800) 1024 KB
P05: trustos (00015800, 00000800) 1024 KB
P06: trustos_bak (00016000, 00000800) 1024 KB
P07: secvm (00016800, 00005000) 10 MB
P08: mvconfig (0001B800, 00005000) 10 MB
P09: mobilevisor (00020800, 00005000) 10 MB
P10: uboot (00025800, 00000800) 1024 KB
P11: uboot_bak (00026000, 00000800) 1024 KB
P12: logo (00026800, 00004000) 8 MB
P13: chargelogo (0002A800, 00001000) 2048 KB
P14: l_fixnv1 (0002B800, 00000800) 1024 KB
P15: l_fixnv2 (0002C000, 00000800) 1024 KB
P16: l_runtimenv1 (0002C800, 00000800) 1024 KB
P17: l_runtimenv2 (0002D000, 00000800) 1024 KB
P18: persist (0002D800, 00001000) 2048 KB
P19: wcnmodem (0002E800, 00002800) 5 MB
P20: l_modem (00031000, 0000C800) 25 MB
P21: l_deltanv (0003D800, 00000800) 1024 KB
P22: l_tgdsp (0003E000, 00003000) 6 MB
P23: l_ldsp (00041000, 0000A000) 20 MB
P24: pm_sys (0004B000, 00000800) 1024 KB
P25: boot (0004B800, 0000F000) 30 MB
P26: system (0005A800, 00400000) 2048 MB
P27: cache (0045A800, 0004B000) 150 MB
P28: vendor (004A5800, 0015E000) 700 MB
P29: vbmeta (00603800, 00000800) 1024 KB
P30: vbmeta_bak (00604000, 00000800) 1024 KB
P31: uboot_log (00604800, 00002000) 4 MB
P32: fytdata (00606800, 00005000) 10 MB
P33: fytback (0060B800, 00200000) 1024 MB
P34: userdata (0080B800, 06C707DF) 54.22 GB
Searching Android build info...
Ok
Disk/Image size : 8f800000 bytes
Device sector size : 512 bytes
Partition offset : 370688
Number of sectors : 4194304
Device Manufacturer : SPRD
Build ID : OPM2.171019.012
Display Build ID : OPM2.171019.012 release-keys
Release ID : 8.1.0
Device Model : sp9853i_1h10_vmm
Device Name : sp9853i_1h10_vmmTos
Architecture ABI : x86_64
Architecture ABI List : x86_64,x86,armeabi-v7a,armeabi
Build Description : sp9853i_1h10_vmmTos-user 8.1.0 OPM2.171019.012 48409 release-keys
| Quote:
odel Settings:
Interface : eMMC
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Sandisk eMMC DA4032
Page size : 512 B
Block size : 512 B
Block count : 61071360
Size : 29.12 GB (29820.00 MB)
CID Info
CID : 4501004441343033320122ED880C46C9
Product name : DA4032
Product serial number : (hex) 22ED880C
Manufacturing date : 04/2019
CSD Info
TRAN speed : 26 MHz
EXTCSD Info
(Bus width = 1Bit)
Max enhanced data size: 9584640 Kbytes
Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/DA4032_14_05_2021_13_55_44.bin.
Connect successful.
SW: 2.2.0.1; FW: 1.24.
P34: userdata (0080B800, 032327DF) 25.1 GB
Ok
Disk/Image size : 47c00000 bytes
