05-05-2020, 16:19 | #1 (permalink) |
No Life Poster Join Date: Nov 2014
Member: 2289628 Status: Offline Thanks Meter: 226 | Huawei Mate 20 Lite (SNE-LX1) Dead Boot Repair [Answered] I make dump successfully. 1:- Guide me that in below picture files are correct for make modem security backup or something else ? 2:- There is no option for firmware write for huawei mobile such as UPDATE.APP firmware in Factory Repair tab. Then how can I do write ? Code: Welcome to Medusa Pro Software version 2.0.9. Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 8 bits Bus speed : Auto Connecting... Device : Hynix eMMC hC8aP Page size : 512 B Block size : 512 B Block count : 122142720 Size : 58.24 GB (59640.00 MB) --------------------------------------------------------------- CID Info CID : 90014A68433861503E01671665D72601 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : hC8aP Product revision : 0.1 Product serial number : (hex) 671665D7 Manufacturing date : 02/2019 --------------------------------------------------------------- CSD Info CSD : D02700328F5903FFFFFFFFEF8E400043 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x08) 00001000 Boot partition enable : Boot partition 1 (Bus width = 8Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x02) 00000010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 30531584 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 8f800000 bytes Device sector size : 512 bytes Partition offset : 4620288 Number of sectors : 11534336 Build ID : PPR1.180610.011 Display Build ID : System 9.0.1.25(04FI) Release ID : 9 Architecture ABI : arm64-v8a Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi Build Description : generic_a15-user 9 PPR1.180610.011 eng.root.20190514.041535 test-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/hC8aP_05_05_2020_19_13_05.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.9; FW: 1.24. P00: GPT (00000000, 00000400) 512 KB P01: frp (00000400, 00000400) 512 KB P02: persist (00000800, 00001000) 2048 KB P03: reserved1 (00001800, 00002800) 5 MB P04: reserved6 (00004000, 00000400) 512 KB P05: vrl (00004400, 00000400) 512 KB P06: vrl_backup (00004800, 00000400) 512 KB P07: modem_secure (00004C00, 00004400) 8.5 MB P08: nvme (00009000, 00002800) 5 MB P09: certification (0000B800, 00000800) 1024 KB P10: oeminfo (0000C000, 00020000) 64 MB P11: secure_storage (0002C000, 00010000) 32 MB P12: modem_om (0003C000, 00010000) 32 MB P13: modemnvm_factory (0004C000, 00008000) 16 MB P14: modemnvm_backup (00054000, 00008000) 16 MB P15: modemnvm_img (0005C000, 00011000) 34 MB P16: reserved7 (0006D000, 00001000) 2048 KB P17: hisee_encos (0006E000, 00002000) 4 MB P18: veritykey (00070000, 00000800) 1024 KB P19: ddr_para (00070800, 00000800) 1024 KB P20: reserved2 (00071000, 0000D800) 27 MB P21: splash2 (0007E800, 00028000) 80 MB P22: bootfail_info (000A6800, 00001000) 2048 KB P23: misc (000A7800, 00001000) 2048 KB P24: dfx (000A8800, 00008000) 16 MB P25: rrecord (000B0800, 00008000) 16 MB P26: fw_lpm3_a (000B8800, 00000200) 256 KB P27: reserved3_a (000B8A00, 00001E00) 3840 KB P28: hdcp_a (000BA800, 00000800) 1024 KB P29: hisee_img_a (000BB000, 00002000) 4 MB P30: hhee_a (000BD000, 00002000) 4 MB P31: hisee_fs_a (000BF000, 00004000) 8 MB P32: fastboot_a (000C3000, 00006000) 12 MB P33: vector_a (000C9000, 00002000) 4 MB P34: isp_boot_a (000CB000, 00001000) 2048 KB P35: isp_firmware_a (000CC000, 00007000) 14 MB P36: fw_hifi_a (000D3000, 00006000) 12 MB P37: teeos_a (000D9000, 00004000) 8 MB P38: sensorhub_a (000DD000, 00008000) 16 MB P39: erecovery_kernel_a (000E5000, 0000C000) 24 MB P40: erecovery_ramdisk_a (000F1000, 00010000) 32 MB P41: erecovery_vendor_a (00101000, 00008000) 16 MB P42: kernel_a (00109000, 0000C000) 24 MB P43: ramdisk_a (00115000, 00008000) 16 MB P44: recovery_ramdisk_a (0011D000, 00010000) 32 MB P45: recovery_vendor_a (0012D000, 00008000) 16 MB P46: dts_a (00135000, 0000C000) 24 MB P47: dto_a (00141000, 00004000) 8 MB P48: trustfirmware_a (00145000, 00001000) 2048 KB P49: modem_fw_a (00146000, 0001C000) 56 MB P50: reserved4_a (00162000, 00006000) 12 MB P51: preload_a (00168000, 00004000) 8 MB P52: recovery_vbmeta_a (0016C000, 00001000) 2048 KB P53: erecovery_vbmeta_a (0016D000, 00001000) 2048 KB P54: vbmeta_a (0016E000, 00002000) 4 MB P55: modemnvm_update_a (00170000, 00008000) 16 MB P56: modemnvm_cust_a (00178000, 00008000) 16 MB P57: patch_a (00180000, 00010000) 32 MB P58: version_a (00190000, 00010000) 32 MB P59: vendor_a (001A0000, 0017C000) 760 MB P60: product_a (0031C000, 00060000) 192 MB P61: cust_a (0037C000, 00060000) 192 MB P62: odm_a (003DC000, 00058000) 176 MB P63: cache (00434000, 00034000) 104 MB P64: system_a (00468000, 00B00000) 5.5 GB P65: userdata (00F68000, 06514000) 50.54 GB Backuping nvme partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hC8aP_nvme_0x9000_0x2800_05_05_2020_19_13_05.bin file... Reading. Please wait... Done. Elapsed time 00:00:02 SW: 2.0.9; FW: 1.24. Backuping oeminfo partition... Opening C:/Program Files (x86)/Medusa Pro Software/Backups/hC8aP_oeminfo_0xc000_0x20000_05_05_2020_19_13_05.bin file... Reading. Please wait... Done. Elapsed time 00:00:27 SW: 2.0.9; FW: 1.24. Switched to boot area partition 1. Opening C:/Users/Abu Musa/Desktop/SNE-LX1/Hynix eMMC hC8aP_Boot_Partition_1.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.0.9; FW: 1.24. Switched to boot area partition 2. Opening C:/Users/Abu Musa/Desktop/SNE-LX1/Hynix eMMC hC8aP_Boot_Partition_2.bin file... Reading. Please wait... Done. Elapsed time 00:00:01 SW: 2.0.9; FW: 1.24. Switched to user area. Opening C:/Users/Abu Musa/Desktop/SNE-LX1/Hynix eMMC hC8aP_User_Data_Area.bin file... Reading. Please wait... Done. Elapsed time 00:06:53 SW: 2.0.9; FW: 1.24. Partition table has been found on device. Save to C:/Users/Abu Musa/Desktop/SNE-LX1/Modem folder... Reading partition modem_secure... Done. Reading partition nvme... Done. Reading partition modem_om... Done. Reading partition modemnvm_factory... Done. Reading partition modemnvm_backup... Done. Reading partition modemnvm_img... Done. Reading partition modemnvm_update_a... Done. Reading partition modemnvm_cust_a... Done. Reading is finished. SW: 2.0.9; FW: 1.24. If I am wrong then guide me in correct way. 1:- Erase eMMC 2:- Write Dump (Boot1,Boot2,UserData,ext_csd) 3:- Write Modem Security Backup files 4:- Select "HiSilicon" from Boot Operation mode. 5:- Put back eMMC on PCB OR:- If I do write full and latest firmware on device without do anything then mobile will power on or no ? Last edited by hafiz4saqib; 05-05-2020 at 16:24. |
05-11-2020, 02:26 | #5 (permalink) |
No Life Poster Join Date: Dec 2009 Location: Laghouat, Algeria Age: 30
Member: 1191316 Status: Offline Thanks Meter: 900 | the phone as you said is dead so write the dump back up again then perform repair via huawei tool with board firmware or if you have other working dump just write and see change |
The Following User Says Thank You to starkrimes For This Useful Post: |
06-08-2020, 18:48 | #6 (permalink) | |
Freak Poster Join Date: May 2014 Location: italy
Member: 2188821 Status: Offline Sonork: TECHNOLOGYFORLIFE Thanks Meter: 60 | Quote:
testpoint + board not erase nvm... | |
06-09-2020, 10:16 | #7 (permalink) |
Member: 1191316 Status: Offline Thanks Meter: 900 | there is no way to repair hisilicon device with bord firmware via emmc only if you have working dump otherwise if phone goes to fastboot then try to do repair by huawei tool with APP update |
