04-07-2017, 03:51 | #1 (permalink) |
Junior Member Join Date: Oct 2006
Member: 376115 Status: Offline Thanks Meter: 2 | Huawei G526-l11 encrypted i need help with this log. sorry full log not posible. how to repair it? Welcome to Octoplus Pro JTAG Software version 1.3.4. Started. Connecting... Device : Sandisk eMMC SEM04G Page size : 512 B Block size : 512 B Block count : 7733248 Size : 3776.00 MB --------------------------------------------------------------- CID Info CID : 45010053454D303447282516C9F6900B Manufacturer ID : 0X45 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : SEM04G Product revision : 2.8 Product serial number : (hex) 2516C9F6 Manufacturing date : 09/2013 --------------------------------------------------------------- CSD Info CSD : D00F00320F5903FFFFFFFDFF8A4040A7 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 10 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO Last edited by Octopus box; 04-18-2017 at 08:21. |
04-07-2017, 06:25 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. What do You mean under "encrypted"? What is the state (problem) of your device exactly? If You want to repair the device, try to do the following: 1. Install the latest tMedusa Pro Software version (Medusa Box Downloads - Software, Drivers, Manual). 2. Download and install SRF (Smart Repair File) for Huawei G526-L11 from the Support Area (via "Download *.srf" button in Software) . 3. Select Huawei G526-L11 on Software list (model will appear in Software list after SFR installation). 4. Connect the phone to Box and press "Connect" button in Software. 5. When device will be connected successfully (as above in your log), make Smart Repair (press "Smart Repair" button and follow wizard steps). 6. Post here the result. |
