01-03-2017, 10:24 | #1 (permalink) |
No Life Poster Join Date: Mar 2016 Location: MWA
Member: 2541648 Status: Offline Thanks Meter: 166 | samsung gt-s5830 repair but phone cant work Welcome to Octoplus JTAG Box Software version 1.9.5 Connecting to server Retrieving files list Downloading file "C:\Program Files\Octoplus\Octoplus_JTAG\Firmware\Samsung_GTS5 830_FullFlash.rar"... Operating Mode: EasyRepair Mode Selected device model: Samsung GT-S5830 Connecting. Please wait... Checking data... VREF = 0.0V is less than required level. Please check target device power supply. ERROR[035]: Target device has been powered off during connect. Please connect the target device and power it on... Checking data... VREF = 0.0V is less than required level. Please check target device power supply. MI: RTCK reaction time 189 ns, average speed 5291 KHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 503C10E1, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : Auto (RTCK). VREF level : 2.59 V CPU : Qualcomm MSM7227T Core ID : 503C10E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000135. MI: Detailed server caps: FLASH, ECC, WDOG, DWP, IOCTL MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0xB0EC0050. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000135 Flash device: Samsung OneNAND KFG4GH6Q4M Flash ID : 00EC0050 Page size : 4096 bytes Block size : 64 pages (256 Kb) Block count: 2048 Flash size : 512 Mb Write protection disabled. Opening "C:\Program Files\Octoplus\Octoplus_JTAG\Firmware\Samsung_GTS5 830_FullFlash\Samsung_GTS5830_FullFlash.bin" file... Writing BOOT section. Please wait... MI: Server status 0x00000001 (not STAT_IDLE). ERROR[018]: Logical block operation failed at 352 Kb (Hex address 0x00058000). Reason: Synchronization failed. Checking data... VREF = 0.0V is less than required level. Please check target device power supply. MI: RTCK reaction time 189 ns, average speed 5291 KHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 503C10E1, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : Auto (RTCK). VREF level : 2.61 V CPU : Qualcomm MSM7227T Core ID : 503C10E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000135. MI: Detailed server caps: FLASH, ECC, WDOG, DWP, IOCTL MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0xB0EC0050. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000135 Flash device: Samsung OneNAND KFG4GH6Q4M Flash ID : 00EC0050 Page size : 4096 bytes Block size : 64 pages (256 Kb) Block count: 2048 Flash size : 512 Mb Write protection disabled. Opening "C:\Program Files\Octoplus\Octoplus_JTAG\Firmware\Samsung_GTS5 830_FullFlash\Samsung_GTS5830_FullFlash.bin" file... Writing BOOT section. Please wait... MI: Server status 0xFFFFFFFF (not STAT_IDLE). ERROR[018]: Logical block operation failed at 352 Kb (Hex address 0x00058000). Reason: Connection lost. Checking data... VREF = 0.0V is less than required level. Please check target device power supply. MI: RTCK reaction time 189 ns, average speed 5291 KHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 503C10E1, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : Auto (RTCK). VREF level : 2.26 V CPU : Qualcomm MSM7227T Core ID : 503C10E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000135. MI: Detailed server caps: FLASH, ECC, WDOG, DWP, IOCTL MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0xB0EC0050. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000135 Flash device: Samsung OneNAND KFG4GH6Q4M Flash ID : 00EC0050 Page size : 4096 bytes Block size : 64 pages (256 Kb) Block count: 2048 Flash size : 512 Mb Write protection disabled. Opening "C:\Program Files\Octoplus\Octoplus_JTAG\Firmware\Samsung_GTS5 830_FullFlash\Samsung_GTS5830_FullFlash.bin" file... Writing BOOT section. Please wait... MI: Server status 0xFFFFFFFF (not STAT_IDLE). ERROR[018]: Logical block operation failed at 352 Kb (Hex address 0x00058000). Reason: Connection lost. Checking data... VREF = 0.0V is less than required level. Please check target device power supply. MI: RTCK reaction time 189 ns, average speed 5291 KHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 503C10E1, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : Auto (RTCK). VREF level : 2.61 V CPU : Qualcomm MSM7227T Core ID : 503C10E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000135. MI: Detailed server caps: FLASH, ECC, WDOG, DWP, IOCTL MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0xB0EC0050. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000135 Flash device: Samsung OneNAND KFG4GH6Q4M Flash ID : 00EC0050 Page size : 4096 bytes Block size : 64 pages (256 Kb) Block count: 2048 Flash size : 512 Mb Write protection disabled. Opening "C:\Program Files\Octoplus\Octoplus_JTAG\Firmware\Samsung_GTS5 830_FullFlash\Samsung_GTS5830_FullFlash.bin" file... Writing BOOT section. Please wait... MI: Server status 0xFFFFFFFF (not STAT_IDLE). ERROR[018]: Logical block operation failed at 352 Kb (Hex address 0x00058000). Reason: Connection lost. Checking data... VREF = 0.0V is less than required level. Please check target device power supply. MI: RTCK reaction time 189 ns, average speed 5291 KHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 503C10E1, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : Auto (RTCK). VREF level : 2.61 V CPU : Qualcomm MSM7227T Core ID : 503C10E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000135. MI: Detailed server caps: FLASH, ECC, WDOG, DWP, IOCTL MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0xB0EC0050. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000135 Flash device: Samsung OneNAND KFG4GH6Q4M Flash ID : 00EC0050 Page size : 4096 bytes Block size : 64 pages (256 Kb) Block count: 2048 Flash size : 512 Mb Write protection disabled. Opening "C:\Program Files\Octoplus\Octoplus_JTAG\Firmware\Samsung_GTS5 830_FullFlash\Samsung_GTS5830_FullFlash.bin" file... Writing BOOT section. Please wait... Done Writing EFS section. Please wait... Done Writing APPBOOT section. Please wait... Done Writing UPCH section. Please wait... Done Repairing IMEI... Done Disconnected I have tried repair and even fullflash. the phone was displaying ram dump error and restarts on and off. I thought the phone will work after, because the usb base not working. is there a solution. Ofcourse maybe i would say i dont understand what jtag is |
01-03-2017, 11:14 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Write Full flash from Advanced Mode (not from EasyRepair Mode) and post here the result. Also, look here: http://forum.gsmhosting.com/vbb/f664.../#post10898860, http://forum.gsmhosting.com/vbb/f664.../#post10319078, http://forum.gsmhosting.com/vbb/9756192-post606.html, http://forum.gsmhosting.com/vbb/f664...1/#post9754260. |
01-07-2017, 09:52 | #3 (permalink) |
Member: 2541648 Status: Offline Thanks Meter: 166 | now displaying nothing only detected in jtag Log started at 1/5/2017 8:01:36 PM ... Welcome to Octoplus JTAG Box Software version 1.9.5.1 Operating Mode: Advanced Mode Selected device model: Samsung GT-S5830 Connecting. Please wait... Checking data... VREF = 0.0V is less than required level. Please check target device power supply. MI: RTCK reaction time 189 ns, average speed 5291 KHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 503C10E1, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : Auto (RTCK). VREF level : 2.59 V CPU : Qualcomm MSM7227T Core ID : 503C10E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000135. MI: Detailed server caps: FLASH, ECC, WDOG, DWP, IOCTL MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0xB0EC0050. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000135 Flash device: Samsung OneNAND KFG4GH6Q4M Flash ID : 00EC0050 Page size : 4096 bytes Block size : 64 pages (256 Kb) Block count: 2048 Flash size : 512 Mb Write protection disabled. Connect successful. ECC Mode enabled. ERROR[028]: Target device has been disconnected ... Disconnected Operating Mode: Advanced Mode Selected device model: Samsung GT-S5830 Connecting. Please wait... Checking data... VREF = 0.0V is less than required level. Please check target device power supply. MI: RTCK reaction time 189 ns, average speed 5291 KHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 503C10E1, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : Auto (RTCK). VREF level : 2.61 V CPU : Qualcomm MSM7227T Core ID : 503C10E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000135. MI: Detailed server caps: FLASH, ECC, WDOG, DWP, IOCTL MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0xB0EC0050. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000135 Flash device: Samsung OneNAND KFG4GH6Q4M Flash ID : 00EC0050 Page size : 4096 bytes Block size : 64 pages (256 Kb) Block count: 2048 Flash size : 512 Mb Write protection disabled. Connect successful. ECC Mode enabled. ERROR[028]: Target device has been disconnected ... Disconnected Operating Mode: Advanced Mode Selected device model: Samsung GT-S5830 Connecting. Please wait... Checking data... VREF = 0.0V is less than required level. Please check target device power supply. MI: RTCK reaction time 189 ns, average speed 5291 KHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 503C10E1, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : Auto (RTCK). VREF level : 2.62 V CPU : Qualcomm MSM7227T Core ID : 503C10E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000135. MI: Detailed server caps: FLASH, ECC, WDOG, DWP, IOCTL MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0xB0EC0050. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000135 Flash device: Samsung OneNAND KFG4GH6Q4M Flash ID : 00EC0050 Page size : 4096 bytes Block size : 64 pages (256 Kb) Block count: 2048 Flash size : 512 Mb Write protection disabled. Connect successful. ECC Mode enabled. ERROR[028]: Target device has been disconnected ... Disconnected Operating Mode: Advanced Mode Selected device model: Samsung GT-S5830 Connecting. Please wait... Checking data... ERROR[034]: RTCK signal does not respond. Defaulting to 1 MHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 503C10E1, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : 1000 KHz. VREF level : 2.63 V CPU : Qualcomm MSM7227T Core ID : 503C10E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000135. MI: Detailed server caps: FLASH, ECC, WDOG, DWP, IOCTL MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0xB0EC0050. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000135 Flash device: Samsung OneNAND KFG4GH6Q4M Flash ID : 00EC0050 Page size : 4096 bytes Block size : 64 pages (256 Kb) Block count: 2048 Flash size : 512 Mb Write protection disabled. Connect successful. ECC Mode enabled. Erasing BOOT section. Please wait... Done Erasing FIRMWARE section. Please wait... Done Opening "C:\Program Files\Octoplus\Octoplus_JTAG\Firmware\Samsung_GTS5 830_FullFlash\Samsung_GTS5830_FullFlash.bin" file... Writing BOOT section. Please wait... Done Writing FIRMWARE section. Please wait... Done ERROR[028]: Target device has been disconnected ... we have electricity problems thats why i have not been able to post |
01-09-2017, 11:26 | #4 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Try to make Erase Full flash and then make EasyRepair using "SAMSUNG_GTS5830_Repair.mf" file. After repairing try to put the phone in Download Mode (DM) manually: reconnect battery, press and hold "Vol-" + "Home" + "Power ON" keys and connect USB cable. If the phone doesn't go into DM, try to put it into DM using Samsung JIG cable, maybe one of phone's button is not working. |
01-10-2017, 09:29 | #5 (permalink) |
Member: 2541648 Status: Offline Thanks Meter: 166 | gt-s5830 DM mode [FONT=Century Gothic]The first time that i used Easy Mode it was possible to put the phone in DM mode after used Easy mode, but the phone did not boot. Was displaying some light on the display. But never boot properly. So I will do the instructions and give feedback. The other thing the usb base cable is damaged. Will it not be possible to recover it using the soldered jtag pinout? |
01-10-2017, 10:06 | #6 (permalink) | |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Quote:
01-11-2017, 19:06 | #7 (permalink) |
Member: 2541648 Status: Offline Thanks Meter: 166 | phone now displays something Log started at 1/10/2017 3:44:05 PM ... Welcome to Octoplus JTAG Box Software version 1.9.5.1 Operating Mode: Advanced Mode Selected device model: Samsung GT-S5830 Connecting. Please wait... Checking data... MI: RTCK reaction time 189 ns, average speed 5291 KHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 503C10E1, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : Auto (RTCK). VREF level : 2.61 V CPU : Qualcomm MSM7227T Core ID : 503C10E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000135. MI: Detailed server caps: FLASH, ECC, WDOG, DWP, IOCTL MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0xB0EC0050. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000135 Flash device: Samsung OneNAND KFG4GH6Q4M Flash ID : 00EC0050 Page size : 4096 bytes Block size : 64 pages (256 Kb) Block count: 2048 Flash size : 512 Mb Write protection disabled. Connect successful. ECC Mode enabled. Erasing BOOT section. Please wait... Done Erasing FIRMWARE section. Please wait... Done Disconnected Operating Mode: EasyRepair Mode Selected device model: Samsung GT-S5830 Connecting. Please wait... Checking data... MI: RTCK reaction time 189 ns, average speed 5291 KHz. Medusa JTAG Firmware version 1.1.0. Medusa JTAG Hardware S256 revision D. Detected TAP ID: 503C10E1, IR Length = 4. MI: Halting target, attempt 1. JTAG speed : Auto (RTCK). VREF level : 2.61 V CPU : Qualcomm MSM7227T Core ID : 503C10E1 MI: Loading Medusa Device Server V1.2. MI: Starting... MI: Received status 0x0000F00F, cycle 0. MI: Received server capabilities 0x00000135. MI: Detailed server caps: FLASH, ECC, WDOG, DWP, IOCTL MI: Watchdog configuration: 0xB800010C, 0x00000001... ok MI: Server init. MI: Received flash ID 0xB0EC0050. MI: Flash geometry set. MI: Recheking settings... ok Server caps : 00000135 Flash device: Samsung OneNAND KFG4GH6Q4M Flash ID : 00EC0050 Page size : 4096 bytes Block size : 64 pages (256 Kb) Block count: 2048 Flash size : 512 Mb Write protection disabled. Opening "C:\Users\STEPHANO NSUPE\Documents\SAMSUNG_GTS5830_Repair.mf" file... Writing BOOT section. Please wait... Done Writing EFS section. Please wait... Done Writing APPBOOT section. Please wait... Done Writing UPCH section. Please wait... Done Repairing IMEI... Done Disconnected After than i can get in download mode and when i just normal power on the phone i get a factory message. see the image in the link: https://postimg.org/image/i47sly1i5/ I have difficulties when uploading an image but thought internet works fine. So i just need to fix the usb base inorder to use the phone right? |
01-12-2017, 07:32 | #8 (permalink) | ||
The Following User Says Thank You to Medusa Box For This Useful Post: |
01-12-2017, 11:12 | #9 (permalink) |
Member: 2541648 Status: Offline Thanks Meter: 166 | But for some phone models the phone automatically works, because i was watching some of your tutorials LG D851 Repair with Octoplus JTAG when phone worked. |
01-25-2017, 18:37 | #10 (permalink) |
Member: 2541648 Status: Offline Thanks Meter: 166 | flashing successful but phone not working after successful repair using jtag i flashed the phone with original flashfile but phones shuts off after displaying the S5830 logo. and when switched on again, keeps on that. i used this flashfile: S5830ZSKPD_S5830OZSKPD_S5830XXKPO. could this be using wrong file. |
01-25-2017, 18:46 | #11 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Try to write different firmwares. Also, your phone may has HW issues. |
