07-25-2016, 07:08 | #20 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,422 | Hello. Please check your PM, we have sent You Repair file. Download and install it, then select LG H818P and press "Pinout" button to look at pinout picture. Make Repair and post here the result. Also You can try to make Factory Repair by using LG original firmwares. |
07-25-2016, 12:38 | #21 (permalink) |
Freak Poster Join Date: Jul 2004 Age: 52
Member: 71269 Status: Offline Thanks Meter: 44 | no result with this file phone totaly dead qualcomm hs usb qdloader9008 ande same with Factory Repair by using LG original firmwares Welcome to Medusa Pro Software version 1.1.5. Started. Reader #0: FT SCR2000 0 Reader #1: FT SCR2000 1 Reader #2: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Selected device model: LG H818P. Selected file: C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_H818P_EMMC_032G74.srf. eMMC interface selected. Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Selected device model: LG H818P. Selected file: C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_H818P_EMMC_032G74.srf. eMMC interface selected. Connecting... Page size : 512 b Block size : 512 b Block count : 61071360 Size : 29.12 GB Device : Toshiba eMMC 032G74 -------------------------------------------------------- CID Info CID : 11010030333247373400B9E49E9342DD Manufacturer ID : 0X11 Device/BGA : BGA(Discrete embeded) OEM/Application ID : 0X00 Product name : 032G74 Product revision : 0.0 Product serial number : (hex)B9E49E93 Manufacturing date : 04/2015 -------------------------------------------------------- CSD Info CSD : D02700320F5903FFFFFFFFE78640009B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO -------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Boot partition enable : Device not boot enabled (default) Partition config : 00000000 Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/032G74_25_07_2016_12_35_09.bin. Connect successful. Writting GPT partition... Done. Writting pmic partition... Done. Writting sbl1 partition... Done. Writting tz partition... Done. Writting sdi partition... Done. Writting hyp partition... Done. Writting rpm partition... Done. Writting aboot partition... Done. Writting limits partition... Done. Writting devinfo partition... Done. Writting apdp partition... Done. Writting msadp partition... Done. Writting dpo partition... Done. Writting misc partition... Done. Writting fsg partition... Done. Writting fsc partition... Done. Writting ssd partition... Done. Writting keystore partition... Done. Writting DDR partition... Done. Writting sec partition... Done. Writting laf partition... Done. Writting boot partition... Done. Writting raw_resources partition... Done. Smart Repair is successfully complete. SW: 1.1.5; FW: 1.10. Disconnected |
07-26-2016, 06:55 | #23 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Most likely, phone's flash chip doesn't allow to make repair (eMMC flash chip has write data protection and it doesn't allow to write boot or some other partitions even write process was shown successfully completed). Unfortunately, currently no solution for such devices. |
07-26-2016, 11:04 | #25 (permalink) | |
Member: 71269 Status: Offline Thanks Meter: 44 | Quote:
07-26-2016, 11:15 | #26 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Yes, for such devices repair - change eMMC, make Repair and then repair security area by using Octoplus LG Software to repair security and IMEI. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
10-17-2016, 15:53 | #27 (permalink) |
Junior Member Join Date: Oct 2016
Member: 2638024 Status: Offline Thanks Meter: 0 | LG G4 (818P) stuck at battery percentage! Can you please help me with similar situation? My LG G4 818P was stuck at LG logo previously but now is stuck at battery charging percentage after putting it on charge. And its not going anywhere, even the charging symbol is stuck and not rotating. Thanks in advance! |
10-18-2016, 07:35 | #29 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hi. Here is SRF for LG H818P: https://drive.google.com/file/d/0B67...BkWV9iT0U/view. Download, install it ("Install custom model files(s)" button at "Welcome" tab in the Software), then select LG H818P in the Software list and press "Pinout" button to look at pinout picture. |
The Following 3 Users Say Thank You to Medusa Box For This Useful Post: |
