07-09-2018, 01:22 | #1 (permalink) |
Junior Member Join Date: Jul 2017 Location: Argentina
Member: 2742114 Status: Offline Thanks Meter: 0 | SM-G532M repair question [Answered] There's Log info below. Model Settings: Interface : eMMC Brand : Samsung Model : SM-G532M SRF : C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_SM-G532M_EMMC,srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q316BB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100513331364242003511CEF0745D Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q316BB Product revision : 0.0 Product serial number : (hex) 3511CEF0 Manufacturing date : 07/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/Q316BB_08_07_2018_21_18_37,bin. Connect successful. --------------------------------------------------------------- SW: 1.6.3; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: bota0 (00002000, 00002000) 4 MB P02: nvram (00004000, 00004000) 8 MB P03: lk (00008000, 00001000) 2048 KB P04: bota1 (00009000, 00001000) 2048 KB P05: secro (0000A000, 00003800) 7 MB P06: seccfg (0000D800, 00000400) 512 KB P07: efuse (0000DC00, 00000400) 512 KB P08: tee1 (0000E000, 00003000) 6 MB P09: bota2 (00011000, 00003000) 6 MB P10: efs (00014000, 00004000) 8 MB P11: nvdata (00018000, 00010000) 32 MB P12: param (00028000, 00004000) 8 MB P13: recovery (0002C000, 00008000) 16 MB P14: boot (00034000, 00008000) 16 MB P15: md1img (0003C000, 00010000) 32 MB P16: md1dsp (0004C000, 00002000) 4 MB P17: keystore (0004E000, 00004000) 8 MB P18: omekeystore (00052000, 00001C00) 3584 KB P19: proinfo (00053C00, 00001400) 2560 KB P20: para (00055000, 00000400) 512 KB P21: persistent (00055400, 00000400) 512 KB P22: steady (00055800, 00000800) 1024 KB P23: protect1 (00056000, 00004000) 8 MB P24: protect2 (0005A000, 00004000) 8 MB P25: reserve2 (0005E000, 00002000) 4 MB P26: system (00060000, 00604000) 3080 MB P27: cache (00664000, 000C8000) 400 MB P28: hidden (0072C000, 0001E000) 60 MB P29: userdata (0074A000, 0160E000) 11.03 GB Kind regards! Last edited by Octopus box; 07-09-2018 at 04:30. |
07-09-2018, 04:30 | #2 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hi. Quote:
07-09-2018, 04:46 | #3 (permalink) | |
Member: 2742114 Status: Offline Thanks Meter: 0 | Quote:
Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC Q316BB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100513331364242003511CEF0745D Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : Q316BB Product revision : 0.0 Product serial number : (hex) 3511CEF0 Manufacturing date : 07/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Octoplus Pro JTAG Software/EXT_CSD Backups/Q316BB_09_07_2018_00_42_24,bin. Connect successful. --------------------------------------------------------------- SW: 1.6.3; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: bota0 (00002000, 00002000) 4 MB P02: nvram (00004000, 00004000) 8 MB P03: lk (00008000, 00001000) 2048 KB P04: bota1 (00009000, 00001000) 2048 KB P05: secro (0000A000, 00003800) 7 MB P06: seccfg (0000D800, 00000400) 512 KB P07: efuse (0000DC00, 00000400) 512 KB P08: tee1 (0000E000, 00003000) 6 MB P09: bota2 (00011000, 00003000) 6 MB P10: efs (00014000, 00004000) 8 MB P11: nvdata (00018000, 00010000) 32 MB P12: param (00028000, 00004000) 8 MB P13: recovery (0002C000, 00008000) 16 MB P14: boot (00034000, 00008000) 16 MB P15: md1img (0003C000, 00010000) 32 MB P16: md1dsp (0004C000, 00002000) 4 MB P17: keystore (0004E000, 00004000) 8 MB P18: omekeystore (00052000, 00001C00) 3584 KB P19: proinfo (00053C00, 00001400) 2560 KB P20: para (00055000, 00000400) 512 KB P21: persistent (00055400, 00000400) 512 KB P22: steady (00055800, 00000800) 1024 KB P23: protect1 (00056000, 00004000) 8 MB P24: protect2 (0005A000, 00004000) 8 MB P25: reserve2 (0005E000, 00002000) 4 MB P26: system (00060000, 00624000) 3144 MB P27: cache (00684000, 000C8000) 400 MB P28: hidden (0074C000, 0004B000) 150 MB P29: userdata (00797000, 06CE3000) 54.44 GB Repairing from file "C:/Program Files (x86)/Octoplus Pro JTAG Software/firmwareFolder/SAMSUNG_SM-G532M_EMMC,srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to boot area partition 2. Writing BOOT2 partition... Done. Switched to user area. Writing GPT partition... Done. Writing bota0 partition... Done. Writing lk partition... Done. Writing secro partition... Done. Writing efuse partition... Done. Writing tee1 partition... Done. Writing param partition... Done. Writing recovery partition... Done. Writing boot partition... Done. Writing md1img partition... Done. Writing md1dsp partition... Done. Smart Repair is successfully complete. | |
07-09-2018, 05:06 | #4 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Accordingly to your Software log, Repair process was done successfully. Probably, boot loaders in SFR "SAMSUNG_SM-G532M_EMMC.srf" can be not compatible with your phone (boot loaders are older (lower) version, than should be in your phone, and phone can't go into Download Mode because of enabled boot downgrade protection). Try to do "Factory Repair" using proper PIT file and the latest original Samsung firmwares for SM-G532M. Then try to put the phone into Download Mode manually. Also try to put the phone into Download Mode using JIG cable. Also, look here: http://forum.gsmhosting.com/vbb/f664.../#post12952181. |
07-11-2018, 00:20 | #5 (permalink) | |
07-29-2018, 10:26 | #8 (permalink) | |
Member: 2742114 Status: Offline Thanks Meter: 0 | Phone's alive but "failed to mount" errors appears.. Quote:
Greatings! PD: Please be patient with my english, im from argentina che | |
07-29-2018, 11:17 | #9 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Try to write EFS backup for SM-G535F (in the Medusa Support Area there are three EFS backup files). Also, if You have Octoplus Samsung Software, after writing EFS backup, try to perform "Repair Security" operation. Last edited by Octopus box; 07-29-2018 at 11:24. |
